[Mapbender-dev] [GSOC09] CSW: demo requests
    Mifan Careem
    mifan at opensource.lk
    Thu May 28 09:08:05 EDT 2009
Thanks Christoph,
Yep - had a look at Armin's information - thanks. Will try out the demos
with the credentials.
Regards
Mifan
On Thu, 2009-05-28 at 14:55 +0200, Christoph Baudson wrote:
> Mifan,
> Armin Retterath has provided additional information on the wiki site CSW
> requirements [1]. You'll find some demo requests [2], and a script that
> will help to perform the requests [3]. You can also use the online
> version [4] (it is secured by password, I'll send you the credentials).
> I hope this helps,
> Christoph
> [1] http://www.mapbender.org/CSW_Requirements
> [2] http://www.mapbender.org/CSW_Requirements#Demo_REQUESTs
> [3] https://svn.osgeo.org/mapbender/trunk/mapbender/tools/send_post_curl.php
> [4] http://www.gdi-rp-dienste3.rlp.de/mapbender/tools/send_post_curl.php
More information about the Mapbender_dev
