[Mapbender-dev] [Mapbender] #552: treeGDE - element_var openfolder
does not have any effect on treeGDE
mapbender_dev at lists.osgeo.org
Tue Nov 10 12:20:29 EST 2009
#552: treeGDE - element_var openfolder does not have any effect on treeGDE
Reporter: astrid_emde | Owner: dev
Type: defect | Status: new
Priority: major | Milestone: 2.6.1
Component: treeGDE | Version: 2.6
Keywords: treeGDE |
If you set the element_var openfolder for treeGDE this does not have any
effect on the tree. The folder is not opened
* The var openfolder is correct in map.php (if you examine with firebug)
Do we have sychronisation problems in this case due to the change from
iframe to div?
Have a look at the similar ticket:
* http://trac.osgeo.org/mapbender/ticket/548
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/552>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev
