[Mapbender-dev] Tying IP addresses to Sessions
Arnulf Christl (Seven)
seven at arnulf.us
Wed Oct 21 19:58:04 EDT 2009
Karim,
thanks for this insight, this is really good background information.
We are currently putting together an Interoperability Experiment at OGC
and I am pretty sure that this will be of interest to a wider audience. I
will try to keep up to date and follow up later.
Best regards,
Arnulf.
> Dear List,
> When writing this, it got rather long, so I figured I would put a
> summary at the top:
> In this weeks IRC meeting we very briefly discussed that mapbender ties
> a php session to the client IP address. And that this behaviour
> causes some problems.
> Associating Sessions to IP addresses is not really a security feature ad
> creates problems by mixing HTTP with IP.
> We should drop it.
> The idea behind it is that if a client's IPaddress changes within a
> session, this must mean the sessionID was stolen and the Session
> must be closed
> This forces the stateless HTTP protocol to respect some kind of ad hoc
> idea of a session, which creates these problems:
> - One of the advantages HTTP is, that data can be cached. This is done
> via proxyservers. If a client makes a request through a proxyserver
> the server sees the IP address of the proxy, not the client.
> So if a client uses more than one proxy in one session, he
> invalidates his session, because it's ip address changed.
> - Another problem involving proxies and Sessions which is not migitated
> by tying IP addess and SessionID together, is that an attacker behind
> the
> same proxy as the User can still steal a Session, because he has the
> same IP address
> - The same is true for any other kind of proxy, say, a socks proxy, or
> someone connecting via tor[1]
> - There are some other reasons why an IP address might change between each
> HTTP connection.
> We are really trying to protect a Ressource on a server from
> unauthorized access.
> So whom are we trying to protect it from?
> - Anyone who is between the Webbrowser and Our Server
> If we assume that a proxy or a NAT device is involved, we can
> differentiate between two kinds of attackers:
> Outsider Attackers: between the Server and the Proxy/NAT
> This is where the tuple of SessionID and IPaddress helps a little
> Inside Attackers: between the Client and the Proxy/NAT
> Here SessionID,IPaddress do not help create security, because the
> attacker has the same IP address as the User
> (There are other attacks, but they are not in focus here)
> So here's how we can try to prevent an attack, without usinng the
> IPaddress check:
> Right now we want to protect a ressource on the server by having
> a user log in once, and then keep sending some kind of
> token to prove, that she is the same user that logged in at the
> beginning.
> We therefore need this token to be protected from unauthorized use by an
> attacker.
> Some definitions:
> C A HTTP client sending data to Server.
> S A HTTP Server sending data to Client
> User The client we want to grant access to a ressource
> Attacker The client we want to prevent from accessing a ressource
> We assume that an attacker can read all the communication between the
> Client and the Server (it is after all, the attacker)
> 1) This is the normal case:
> Client authenticates, and receives SessionID:
> 1.1 C: GET /login HTTP/1.1
> Host: example.com
> Authorization: Basic eW91c286c25lYWt5
> 1.2 S: HTTP/1.1 200 OK
> Cookie: SessionID=blafasel_1
> <additional headers and data>
> 1.a Attacker steals SessionID here
> Client sends Same SessionID for each requested Ressource
> 1.3 C: GET /secret HTTP/1.1
> Host: example.com
> 1.4 S: HTTP/1.1 200 OK
> <headers and data>
> Client or attacker send next request
> 1.5 C: GET /ohsoverysecret HTTP/1.1
> Host: example.com
> 1.6 S: HTTP/1.1 20O OK
> <headers and data>
> After 1.a the server can't be sure wether requests come from the same
> client that authenticated in 1.1 because now two clients could know the
> sessionID
> We introduce a SessionID, that is not constant over a Session but
> changes with each request (like for example the php function
> session_regenerate_id)
> 2.1 C: GET /login HTTP/1.1
> Host: example.com
> 2.2 S: HTTP/1.1 200 OK
> Client sends Request with SessionID, Sever answers with data and
> new SessionId
> 2.3 C: GET /secret HTTP/1.1
> Host: example.com
> 2.a Attacker steals SessionID here
> 2.4 S: HTTP/1.1 20O OK
> Cookie: SessionID=blafasel_RANDOM5678
> 2.b Attacker steals SessionID here
> Client sends next Request
> 2.5 C: GET /ohsoverysecret HTTP/1.1
> Host: example.com
> Cookie: SessionID=blafasel_RANDOM5648
> 2.6 S: HTTP/1.1 200 OK
> Cookie: SessionId=blafasel_RANDOM1234
> The SessionID stolen at 2.a is now useless to the attacker, because it
> is only good for one single request
> If the attacker steals it at 2.b however he can use it to to generate a
> valid request if he can do it faster the the User. If he does that, he
> will receive the next valid SessionID and the User will not,
> effectively locking the User out of his own session.
> If we continue like this we could try to come up with some kind of
> scheme that makes the SessionID a kind of cryptographic Token,
> but this squeezes the SessionID into a function it was not really
> supposed to have, and maybe impossible to do, because the client can't
> really do any calculations on it which might be neccessary.
> oooor we could use one of the following already existing ideas to this
> problem:
> - use HTTPS: Best Idea of course when accessing protected ressources
> - HTTP Digest authentication:
> If you noticed, I used Basic auth in my example, this of course a
> bad idea if not using HTTPS
> Digest authentication solves our problem by using a cryptographically
> sound token to authenticate the User in each request
> The following is a pretty good summary of how this could be done:
> http://www.peej.co.uk/articles/http-auth-with-html-forms.html
> As a last remark: If we assume that an attacker can read all our
> communication (which is the assumption behind tying SessionID and
> IPaddress), then we don't even have to go through all this trouble,
> because right now, the login form sends our password in the clear
> anyway and an attacker does not need to highjack a session.
> she can just use the password to create a new one.
> thx for reading this far,
> Karim
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Arnulf Christl
Exploring Space, Time and Mind
http://arnulf.us/
More information about the Mapbender_dev
