[Mapbender-dev] [Mapbender] #632: checkPermission
mapbender_dev at lists.osgeo.org
Sun Apr 11 07:14:24 EDT 2010
Reporter: tbaschetti | Owner: dev
Type: defect | Status: new
Priority: major | Milestone: 2.6.1
Component: administration | Version: 2.6
Keywords: |
When CHECK is set to true in mapbender.conf:
define ("CHECK",true)
a security check is run on all Modules via mod_validatePermission.php
Only Modules which are part of a gui can succeed this check, so modules
which are loaded later will fail, e.g. mod_loadwms.php (used by
mod_loadCapabities) and mod_loadCSW.php (used by
mod_loadCatalogCapabilities.php).
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/632>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev
