[Mapbender-dev] use of deprecated function "split" in file
"http/classes/class_locale.php"
Marc Jansen
jansen at terrestris.de
Thu Apr 29 10:49:37 EDT 2010
Hi devs,
in file "http/classes/class_locale.php" we use "split", which is
deprecated as of PHP 5.3 [1]. The patch below replaces "split" with
"explode", which should be what is meant there (we didn't split by a
complicated regular expression but a simple string). If we decide on
leaving "split" in there, some CMS embedding Mapbender will display ugly
warnings (Typo3 in my particular case). The ticket for this is [2].
I was afraid of directly commiting this, so decide whether you want that
change in trunk or not. BTW whats the policy for commits? I think I
still have rights to commit.
Regards,
Marc
[1] http://php.net/manual/en/function.split.php
[2] http://trac.osgeo.org/mapbender/ticket/635
Index: http/classes/class_locale.php
--- http/classes/class_locale.php (revision 6042)
+++ http/classes/class_locale.php (working copy)
@@ -257,7 +257,7 @@
function setBrowserLanguages () {
$this->browserLanguages = array();
- $bLangs = split(',', $_SERVER["HTTP_ACCEPT_LANGUAGE"]);
+ $bLangs = explode(',', $_SERVER["HTTP_ACCEPT_LANGUAGE"]);
foreach ($bLangs as $lang) {
if (strpos($lang, ';') === false)
array_push($this->browserLanguages,
$lang);
More information about the Mapbender_dev
