[Mapbender_dev] Mapbender , mapserver and WMS service getreatureinfo problem!!
Michael Schulz mschulz at webgis.de
Fri Aug 27 05:36:44 EDT 2010
if there is a problem loading mapproxys getcapabilities, then we
should investigate this. I doubt that there are a lot of wms "servers"
that allow for cascaded getfeatureinfos. Is your mapproxy instance
reachable via internet?
Cheers, Michael
2010/8/27 necipakca <necipakca84 at hotmail.com>:
> thank you for your quick reply,I have tried mapproxy but unfortunatly it's
> wms capbilities can not be loaded on mapbender.I dont know why because it
> does not throw any exception(I have looked up php.log mapbender.log  and
> javascript) and as a result all parameters are coming null.
> Thanks your for advise,your idea was worth to try :D
> I think i must find different way for my project.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mapbender-mapserver-and-WMS-service-getreatureinfo-problem-tp5461648p5468621.html
> Sent from the mapbender-dev mailing list archive at Nabble.com.
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-academy.eu/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_dev mailing list
