[Mapbender_dev] Mapbender , mapserver and WMS service getreatureinfo problem!!
Dominik Helle liste at der-helle.de
Fri Aug 27 10:10:57 EDT 2010
Hi List,
yes the mapproxy can cascade getfeatureinfo requests.
Am 27.08.2010 um 11:36 schrieb Michael Schulz:
> if there is a problem loading mapproxys getcapabilities, then we
> should investigate this.
The capbilities documents from mapproxy should be valid. :-)
We check this with the xml shema.
If you like you can test the mapproxy with our demo wms:
http://osm.omniscale.net/proxy/service?
Best regards,
Dominik
Dominik Helle <helle ( at ) omniscale.de>
Omniscale, Dominik Helle, Oliver Tonnhofer GbR
Nadorster Straße 60, 26123 Oldenburg
Tel: +49(0)441/9392774-1 (Fax: 9)
More information about the Mapbender_dev mailing list
