[Mapbender_dev] [Mapbender] #741: Resize mapsize partially defect
Mapbender mapbender_dev at lists.osgeo.org
Wed Dec 15 01:01:21 EST 2010
 Reporter:  armin11  |       Owner:  dev
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:  2.7 release
Component:  core     |     Version:  2.7 rc1
 Keywords:           |
 The resize mapsize module - mod_resize_mapsize.js has a little problem.
 When activated and set to auto, the started gui views as and streched map.
 This would be, cause the x and y axes get other scale factors. If s.o.
 will zomm in by zoombox aftewards, the map will be shoen correct. The
 normal zoom doesn't alter the wrong map. Maybe there must be checked, if
 the map must be refreshed automaticcaly after the resize mapsize module
 has done its job. I think it will not be a big problem to fix this ;-)
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/741>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
