[Mapbender-dev] [Mapbender] #597: WFS setSpatialRequest - bug in select by polygon at high scale
Mapbender mapbender_dev at lists.osgeo.org
Fri Feb 19 03:58:17 EST 2010
 Reporter:  astrid_emde     |       Owner:  dev
     Type:  defect          |      Status:  new
 Priority:  major           |   Milestone:  2.7 release
Component:  user interface  |     Version:  2.7 rc1
 Keywords:                  |
 Bugs
  * the polygon is not drawn on top of all WMS images
  * when you use "select by polygon" for spatial request the red line which
 should diplay the ploygon is not drawn (this effect does only appear in
 high scale  (appears in gui_digitize)
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/597>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
