[Mapbender-dev] New navigation controls
Christoph Baudson (Wheregroup)
christoph.baudson at wheregroup.com
Tue Jan 5 12:35:34 EST 2010
At the jQuery UI demo at Telascience [1] you can see a new navigation
control. Check the top, left, bottom and right of the map, where I have
placed tiny arrows (they are highlighted when you are close), which pan
the map.
The new module is documented here [2]
Christoph
[1]
http://mapbender.telascience.org/mapbender_trunk/frames/login.php?name=demo&password=demo&mb_user_myGui=template_jquery_ui
[2]
https://svn.osgeo.org/mapbender/trunk/mapbender/documents/api_js/files/plugins/mb_navigation-js.html
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
