[Mapbender_dev] Raphaeljs not bubbling
Astrid Emde astrid.emde at wheregroup.com
Mon Jun 7 05:52:28 EDT 2010
Hello Karim,
the first idea you mentioned seems more reasonable to me. Maybe we can
use grouped elements in a canvans in other cases too.
Best regards
Astrid
Karim Malhas schrieb:
> Dear List,
> I am trying to modify the loadkmlgeorss module, which uses the Marker
> class, to respond to click events to display a balloon popup.
> If the Raphaeljs library is included this doesn't seem possible right
> now.
> The Problem as I understand it:
> Each marker instantiates it's own 'canvas' - in Raphael this means a new
> <svg> element is added to the DOM.
> So if multiple markers are present, multiple <svg> appear stacked above
> each other.
> The problem is, that events don't seem to come through the topmost
> svg element, meaning that only a click on the marker that was add last
> will bring the desired result.
> Possible solutions:
> - Create a global canvas element.
>   If all elements are in a single canvas, event propagation works
>   however because canvas.clear() is called a couple of times
>   in the code, a global canvas doesn't work without changes.
>   This could be modifyed to grouping elements using 'canvas.set()',
>   and set.remove().
>   I am not 100% sure how feasable that is, though.
> - Create a common canvas element for the markers only
>   drawback: the markers will work, but it can' t be used with any other
>   modules that need a canvas
> ideas?
> Regards,
> Karim
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Mit freundlichen Grüßen
Astrid Emde
AGIT 2010
7.-9. Juli 2010 in Salzburg
Treffen Sie die WhereGroup an Stand Nr. 30
http://www.agit.at
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Siemensstraße 8
 53121 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
