[Mapbender_dev] OpenLayers Template
Christoph Baudson (Wheregroup)
christoph.baudson at wheregroup.com
Wed Jun 23 09:15:18 EDT 2010
Hi there,
after 12 days I finally managed to add the report of the final day in
Bolsena [1].
I have checked in the demo application [2]. Unfortunately, I was unable
to install it anywhere, as I can't connect to mapbender.telascience.org [3].
You can create the application with the SQL, but you still have to load
WMS. For my installation, I have loaded an OSM WMS [4]. As we have also
created a setBBox like module, you can now zoom to a defined extent on
start up, like [5].
Any questions? Please let us know
Christoph
[1] http://www.osgeo.org/blog/mapbender
[2]
http://trac.osgeo.org/mapbender/export/6422/trunk/mapbender/resources/db/openlayersSql.sql
[3] http://trac.osgeo.org/osgeo/ticket/595
[4]
http://osm.prtr.bund.de/cgi-bin/mapserv?map=/data/umn/osm/osm_s_10k_opt_agg.map&VERSION=1.1.1&REQUEST=GetCapabilities&SERVICE=WMS
[5]
http://localhost/test27/frames/login.php?name=root&password=xxxxxx&mb_user_myGui=template_openlayers&mb_myBBOX=7,50.79,7.2,50.68
AGIT 2010
7.-9. Juli 2010 in Salzburg
Treffen Sie die WhereGroup an Stand Nr. 30
http://www.agit.at
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
