[Mapbender-dev] [Mapbender] #623: Add image to print frame to show which side is the top side
Mapbender mapbender_dev at lists.osgeo.org
Mon Mar 8 10:44:15 EST 2010
 Reporter:  christoph  |       Owner:  dev
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:  2.7 release
Component:  print      |     Version:
 Keywords:             |
 you can easily print your map upside down if you rotate excessively
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/623>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
