[Mapbender-dev] Column names
Karim Malhas
karim at malhas.de
Sun May 2 10:24:52 EDT 2010
Hi Christoph,
> I prefer to have column names as less redundant as possible, so would
> like to have wms.id rather than the current wms.wms_id. It's the same
> with methods and attributes in OOP.
This my opinion as well.
> Currently I'm building a complex metadata form. I have to get data from
> various tables, display them in web forms, and then store the data again
> in the db. I want to make this as easy as possible, with as little
> mapping as possible. This would mean that I should hve a naming
> convention which would allow me to identify the table name as well as
> the column name when updating the db.
> I think this problem is related to what Karim mentioned. What would be
> the alternative? I didn't give it too much thought yet to be honest.
Consider for example:
CREATE TABLE wms {
id INTEGER,
name TEXT
CREATE TABLE example_a {
id INTEGER,
wms_id INTEGER,
location TEXT,
FOREIGN KEY wms_id REFERENCES wms (id)
CREATE TABLE example_b {
id INTEGER,
wms_id INTEGER,
location TEXT,
SELECT * FROM wms JOIN example_a ON wms.id = example_a.wms_id JOIN example_b.wms_id;
This will result in an 'ambigous column name "id", "location"' error
There are a couple of solutions to this problem:
A) Prefixing each column name with it's columnname
Output:
wms_name | example_b_location | example_a_location
B) Select precisely the columns you need, omitting conflicting column
nmes
SELECT wms.name, example_b.location FROM wms INNER JOIN example_a ON wms.id = example_a.wms_id INNER JOIN example_b.wms_id;
Output:
name | location
C) Alias where neccessary
SELECT wms.name, b_location example_b.location, a_location example_a.location FROM wms INNER JOIN example_a ON wms.id = example_a.wms_id INNER JOIN example_b.wms_id;
Output:
name | b_location | a_location
Or perhaps more even more explicit:
SELECT wms.name, 'example_b.location' example_b.location, 'example_a.location' example_a.location FROM wms INNER JOIN example_a ON wms.id = example_a.wms_id INNER JOIN example_b.wms_id;
name | example_b.location | example_a.location
D) ?
I think B) should always be used insted of "SELECT *", and I lean
towards aliasing when neccessary instead of prefixing each column name.
Are you familiar on how the 'object-relational' part of postgres deals
with this? I am sure we're not the first ones finding this problem.
Regards,
Karim
More information about the Mapbender_dev
