[Mapbender-dev] [Fwd: Re: Fwd: Re: [SAC] Preparation of GRASS VM?]
Arnulf Christl (OSGeo)
arnulf at osgeo.org
Tue May 4 06:08:35 EDT 2010
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
fyi: follow up on the dead telascience server ticket #566 [1].
Please check the parameters for hd size, RAM, SWAP and processors at:
http://wiki.osgeo.org/wiki/Infrastructure_Transition_Plan_2010#osgeo4
I guess we will be happy with the proposed Base Image [2] Debain VM
template? Other opinions? Need anything else?
Regards,
Arnulf.
[1]
http://wiki.osgeo.org/wiki/Infrastructure_Transition_Plan_2010#Base_Image
[2] http://trac.osgeo.org/osgeo/ticket/566
- -------- Original Message --------
Subject: Re: Fwd: Re: [SAC] Preparation of GRASS VM?
Date: Tue, 04 May 2010 11:34:10 +0200
Reply-To: arnulf at osgeo.org
Organization: OSGeo
To: System Administration Committee Discussion/OSGeo <sac at lists.osgeo.org>
CC: Tyler Mitchell (OSGeo) <tmitchell at osgeo.org>,
astrid.emde at wheregroup.com
References: <4BDF0E53.3080801 at osgeo.org>
the Mapbender project has added the requirements of the Mapbender VM to
the transition plan[1].
The old telascience server has been offline for more than a week. This
is turning into a major blocker for development. With most of the demos
down it also reflects badly on the project. There is a ticket [2] which
also applies for MapServer tutorials and GeoNetwork demo server both
have been running on the same dead telascience blade.
Regards,
Arnulf.
[1]
http://wiki.osgeo.org/wiki/Infrastructure_Transition_Plan_2010#osgeo3_.26_osgeo4
Tyler Mitchell (OSGeo) wrote:
> Following up from my last note. Can you see below (Markus has same
> troubles) - and add your thoughts for a mapbender virtual machine - hard
> drive and memory requirements, so we can get you started on a migration
> ASAP...
> Tyler
> Subject: Re: [SAC] Preparation of GRASS VM?
> Date: Sun, 02 May 2010 23:07:35 -0700
> From: Alex Mandel <tech_dev at wildintellect.com>
> Reply-To: tech at wildintellect.com, System Administration Committee
> Markus Neteler wrote:
>> Hi SAC,
>> since the OS on xblade14 is pretty old, we are having increasing troubles
>> to keep stuff running.
>> Would it be possible to obtain the "template" VM in order to start
>> with the
>> preparation for the migration?
>> thanks
>> Markus
> Please fill out an entry in the table with the hard drive requirements
> for such a VM.
> http://wiki.osgeo.org/wiki/Infrastructure_Transition_Plan_2010#Final_Plan
> I'll add it to the set of VMs that will likely be made this week.
> Thanks,
> Alex
> Sac mailing list
> Sac at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/sac
Arnulf Christl
President OSGeo
http://www.osgeo.org
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAkvf8iMACgkQXmFKW+BJ1b2nkwCfQK9SDoaVvqZ1GX6JuysK4FFj
TCMAnRjjqdeFdeVtF/2uda7WutuZ0wEl
=3zZB
-----END PGP SIGNATURE-----
More information about the Mapbender_dev
