[Mapbender-dev] GSoC 2010 Project - RESTful API for Mapbender [RFC]
Christoph Baudson (Wheregroup) christoph.baudson at wheregroup.com
Thu May 6 02:46:22 EDT 2010
Hi Vikash,
welcome aboard! If you need anything, let us know. I assume you and
Arnulf are already communicating, I wouldn't mind monitoring the
progress on this list. So anytime you want to discuss, report, need
feedback, please feel free to use this list.
Christoph
Vikash Banjara wrote:
> Hi all,
> I just completed my exams. Will start working on the project from
> tomorrow onwards.
> Regards
> Vikash
> On Tue, Apr 27, 2010 at 12:30 PM, Astrid Emde
> <astrid.emde at wheregroup.com <mailto:astrid.emde at wheregroup.com>> wrote:
>     Hello Vikash,
>     welcome to the Mapbender project and a good Summer of Code for you.
>     All the best for your exams and see you after May 6th.
>     Astrid
>     On Mon, April 26, 2010 8:48 pm, Vikash Banjara wrote:
>     > Hi,
>     > Thanks to all of you.
>     > I am officially accepted for the GSoC 2010. I will work on
>     "Restful API
>     > for Mapbender".
>     > P.S.: I will not be available before 6th May, because of exams
>     at the
>     > university. I will start soon after the exams are over.
>     > Regards
>     > Vikash
>     > On Tue, Apr 6, 2010 at 5:45 PM, Vikash Banjara
>     > <vikashbanjara at gmail.com <mailto:vikashbanjara at gmail.com>>wrote:
>     >> Seven,
>     >> Thanks for your suggestions. I have made proper changes to the
>     >> application. You can check out once again.
>     >> On Tue, Apr 6, 2010 at 4:14 PM, Seven (aka Arnulf)
>     >> <seven at arnulf.us <mailto:seven at arnulf.us>>wrote:
>     >>> -----BEGIN PGP SIGNED MESSAGE-----
>     >>> Hash: SHA1
>     >>>> Hello devs,
>     >>>> I have submitted my proposal for GSoC 2010 project - RESTful API
>     >>>> for Mapbender at http://socghop.appspot.com under the
>     Organization
>     >>>> OSGeo.
>     >>>> Please  go through the proposal and suggest me changes. I
>     still have
>     >>> time
>     >>>> till 9th April 2010 to edit the proposal. I will be really
>     grateful
>     >>>> to
>     >>> you
>     >>>> people for reviewing the application.
>     >>>> Anticipating response,
>     >>>> Regards
>     >>>> Vikash
>     >>> Vikash,
>     >>> thank you for submitting the proposal. Before submitting my
>     comments
>     >>> to the GSoC site please consider the following details:
>     >>> I have a question and suggestion wrt the work plan. Why do you
>     want
>     >>> to first implement the client side request of the API and then the
>     >>> server side?
>     >>> I was wrong when I said that client side should be designed first.
>     >>> Logical
>     >> thing will be to design the server side processing.
>     >> Regards
>     >> Vikash
>     >>> We should also clean out terminology, what is the client side and
>     >>> what is the server side, what is the back end. We could add
>     this as a
>     >>> work package to the first three week design period.
>     >>> After GSoC starts - First three weeks -
>     >>> Add:
>     >>> ... "Update the Glossary of the project to describe the use of the
>     >>> terms "client", "server", "back end", "application", etc. in the
>     >>> context of the project"
>     >>> After first three weeks to Mid-term -
>     >>> Add:
>     >>> ... "We will use a test driven development method and follow
>     the Scrum
>     >>>  process with daily scrums (as the availability of mentor and
>     student
>     >>>  will allow).
>     >>> Please consider answering for this question:
>     >>> "How does your SoC task benefit the OSGeo member project, and more
>     >>> generally the OSGeo Foundation as a whole?"
>     >>> Suggestion:
>     >>> "The REST-API project will make it easier to integrate
>     Mapbender with
>     >>> other projects. It will also allow machine access to the
>     management
>     >>> back end data and improve the use of the project as centralized
>     >>> management back end for spatial data infrastructures. This will
>     >>> further improve the USP of the project."
>     >>> "Please provide details of previous GIS experience"
>     >>> I suggest you say: "None". This will not be a problem for us
>     (as you
>     >>> already say further down). The project and tasks involved do not
>     >>> require you to have up front knowledge of GIS.
>     >>> I will talk over the proposal with Christoph but as far as I am
>     >>> concerned this is already a good proposal. I am happy with it.
>     >>> Best regards,
>     >>> Arnulf.
>     >>> Arnulf Christl
>     >>> Exploring Space, Time and Mind
>     >>> http://arnulf.us
>     >>> -----BEGIN PGP SIGNATURE-----
>     >>> Version: GnuPG v1.4.9 (GNU/Linux)
>     >>> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
>     >>> iEYEARECAAYFAku7EIUACgkQXmFKW+BJ1b0nNACfTBiLwnHBQ+ATT0gEhJ1oTha4
>     >>> SOkAn0nmFrIVS4OUXJ9ign+rV1oi58VC
>     >>> =SZ5N
>     >>> -----END PGP SIGNATURE-----
>     >>> _______________________________________________
>     >>> Mapbender_dev mailing list
>     >>> Mapbender_dev at lists.osgeo.org
>     <mailto:Mapbender_dev at lists.osgeo.org>
>     >>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
>     > Mapbender_dev at lists.osgeo.org <mailto:Mapbender_dev at lists.osgeo.org>
>     Mit freundlichen Grüßen
>     Astrid Emde
>     Aufwind durch Wissen!
>     Qualifizierte OpenSource-Schulungen
>     bei der www.foss-academy.eu <http://www.foss-academy.eu>
>      Astrid Emde
>      WhereGroup GmbH & Co.KG
>      Siemensstraße 8
>      53121 Bonn
>      Germany
>      Fon: +49(0)228 90 90 38 - 19
>      Fax: +49(0)228 90 90 38 - 11
>      www.wheregroup.com <http://www.wheregroup.com>
>     Amtsgericht Bonn, HRA 6788
>     Komplementärin:
>     WhereGroup Verwaltungs GmbH
>     vertreten durch:
>     Olaf Knopp, Peter Stamm
AGIT 2010
7.-9. Juli 2010 in Salzburg
Treffen Sie die WhereGroup an Stand Nr. 30
http://www.agit.at
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Komplementärin:
vertreten durch:
More information about the Mapbender_dev mailing list
