[Mapbender-dev] template_basic for 3_dev
Astrid Emde astrid.emde at wheregroup.com
Sun May 9 13:01:01 EDT 2010
Hello devs,
I nearly finished integration of template_basic. I decided to check in the
application-sql and the modified scripts so you can have a look.
* don't get shocked: I added navigation buttons to the application. This
is only temporary only to test the buttons.
* doubleclickZoom causes error "b is undefined"
* mousewheelZoom causes error "Point is not defined"
* selArea1 causes error "getMapObjByName is not defined"
How to add the application to your Mapbender 3_dev:
1.) the SQL will create the application and assign the application to the
user root [1]
2.) add a WMS (f.e. germany) to the application
3.) open application [2]
[1]
http://svn.osgeo.org/mapbender/branches/3_dev/resources/template_basic.sql
[2]
http://localhost/3_dev/frames/index.php?name=root&password=apfel&mb_user_myGui=template_basic#
Best regards
Astrid
More information about the Mapbender_dev mailing list
