[Mapbender-dev] Regarding Scale calculation for non-metric SRS
Abhishek Singh
singhabhishek.bit at gmail.com
Fri May 14 15:17:46 EDT 2010
I am currently working on Scale Calculation for Non-metric SRS, I went
through the manual link at
http://www.mapbender.org/User_talk:Abhishek#Scale_calculation_for_non-metric_SRS.
I had implemented that in c++
#include<iostream>
using namespace std;
#define PI 3.1416
#define radius 6378137
#define standard 0.00028
int main()
float xa_length;
float ya_length;
float x_pixels;
float y_pixels;
float std_scale_dr;
cout<<"Enter the xa_length(angular units): ";
cin>>xa_length;
cout<<"Enter the ya_length(angular units): ";
cin>>ya_length;
float xl_length;
float yl_length;
cout<<"Considering standardized rendering pixel size to be 0.28mm ×
0.28mm (millimeters) "<<endl;
cout<<"and radius of earth = 6378137m "<<endl;
xl_length = (xa_length * (2 * PI * radius))/360;
yl_length = (ya_length * (2 *PI * radius ))/360;
cout<<"map extent is : " << xl_length << "m x " <<yl_length<<" m
"<<endl;
cout<<" Enter the x_pixels (no. of pixels on horizontal axis) ";
cin>>x_pixels;
cout<<" Enter the y_pixels (no. of pixels on vertical axis) ";
cin>>y_pixels;
std_scale_dr = ((xl_length / x_pixels)/ standard);
cout<<"standard scale denominator will be : "<< std_scale_dr<<endl;
return 0;
Now the next step for me is to understand what is going on in file
mapbender/http/javascripts/map_obj.js in the functions getScale , checkScale
and repaintScale and thereafter implement the above sample code's
functionality in the aforesaid file.
But currently I am having problem with getScale function variables.I am
stating some of my questions below:
1 . why is lat_from = ((parseFloat(bbox[3]) - parseFloat(bbox[1]) / 2) *
Math.PI) / 180
2 . why actually we are dividing by 2 parseFloat(bbox[1])
3 . Please explain the underlying reason for this var lat_to =
((parseFloat(bbox[3]) - parseFloat(bbox[1]) / 2 + pxLeny) * Math.PI) / 180;
4 . Even though the number of longitudes is twice the number of latitudes
but still the formula for both of them are the same
5 . Please explain dist = 6371229 * Math.acos(Math.sin(lat_from) *
Math.sin(lat_to) + Math.cos(lat_from) * Math.cos(lat_to) * Math.cos(lon_from
- lon_to))
6 . what does mb_resolution and scale refer to? please explain the
expression scale = (dist / Math.SQRT2) * (mb_resolution * 100)
7 . please explain xtenty = parseFloat(bbox[3]) - parseFloat(bbox[1]) and
scale = (xtenty / this.getHeight()) * (mb_resolution * 100)
Thanks,
Abhishek Kumar Singh
BE/1349/2007
Information Technology
6th SEMESTER
BIT MESRA
URL: http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20100515/40cd87ba/attachment.html
More information about the Mapbender_dev
