[Mapbender_dev] Re: [Mapbender] #727: LoadWms: Create bboxes for
all supported srs
mapbender_dev at lists.osgeo.org
Fri Nov 26 05:49:30 EST 2010
#727: LoadWms: Create bboxes for all supported srs
Reporter: verenadiewald | Owner: dev
Type: enhancement | Status: new
Priority: major | Milestone: 2.7 release
Component: wmc | Version: 2.7 rc1
Keywords: bbox |
Comment(by verenadiewald):
define the SRS_ARRAY in mapbender.conf with all srs which you want to
serve in Mapbender
define("SRS_ARRAY", "4326, 31466, 31467, 31468, 25832, 25833")
all srs which are supported by the loaded wms and are part of the
SRS_ARRAY are then defined as supported layer epsg and get a calculated
bbox for this epsg in table layer_epsg
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/727#comment:2>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev
