AW: AW: [Mapbender_dev] demis WMS which is used in Mapbender
templated application is not available
Manns, Marc
manns at str.de
Thu Apr 14 01:44:51 EDT 2011
wasn't an effort (just a click) :-)
-----Ursprüngliche Nachricht-----
Von: mapbender_dev-bounces at lists.osgeo.org [mailto:mapbender_dev-bounces at lists.osgeo.org] Im Auftrag von Astrid Emde
Gesendet: Mittwoch, 13. April 2011 18:12
An: Mapbender Developer List
Cc: mapbender_users at lists.osgeo.org
Betreff: Re: AW: [Mapbender_dev] demis WMS which is used in Mapbender templated application is not available
Hi marc,
demis is back.
Thanks for your effort.
Astrid
On Wed, April 13, 2011 11:24 am, Manns, Marc wrote:
> looks like a temporary problem! the link works for me...
> regards Marc
> Emde
> Gesendet: Mittwoch, 13. April 2011 08:01
> An: mapbender_dev at lists.osgeo.org
> Betreff: [Mapbender_dev] demis WMS which is used in Mapbender
> Hello,
> Looks like the server does not exist anymore http://www2.demis.nl/
> --> BAD REQUEST (invalidd hostname)
> MapRequest:
> http://www2.demis.nl/wms/wms.asp?wms=WorldMap&VERSION=1.1.1&REQUEST=Ge
> tMap
> &SERVICE=WMS&LAYERS=Bathymetry,Countries,Topography,Hillshading,Builtu
> p%2
> 0areas,Coastlines,Waterbodies,Inundated,Rivers,Streams,Railroads,Highw
> ays
> ,Roads,Trails,Borders,Cities,Settlements,Spot%20elevations,Airports,Oc
> ean
> %20features&STYLES=,,,,,,,,,,,,,,,,,,,&SRS=EPSG:4326&BBOX=-181.3130081
> 300
> 813,-80,155.3130081300813,89&WIDTH=245&HEIGHT=123&FORMAT=image/png&BGC
> OLO
> R=0xffffff&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage
> Can someone check why and have a look for the new demis? We have to
> update our demos, as most of them use demis as background WMS.
> Astrid
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Mit freundlichen Grüßen
Astrid Emde
AGIT 2011
6.-8. Juli 2011 in Salzburg
Treffen Sie die WhereGroup an Stand Nr. 30 http://www.agit.at
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
astrid.emde at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
