[Mapbender_dev] [Mapbender] #819: WMC Update to 2.7
mapbender_dev at lists.osgeo.org
Thu Apr 28 07:01:22 EDT 2011
Reporter: marc | Owner: dev
Type: defect | Status: new
Priority: major | Milestone: 2.7.2 release
Component: installation | Version: 2.7.1
Keywords: |
The Update Script to 2.7 threw some error when wmc entries already
existing in table mb_user_wmc.[[BR]]
Therefor some new WMC Tables will not be created.[[BR]]
Here's an abstract of my error.log [[BR]]
psql:pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql:605: ERROR:
ERROR: column "wmc_serial_id" contains null values
psql:pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql:618: ERROR:
psql:pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql:626: ERROR:
relation "wmc_keyword" does not exist
psql:pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql:2385:
ERROR: there is no unique constraint matching given keys for referenced
table "mb_user_wmc"
psql:pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql:2403:
table "mb_user_wmc"
psql:pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql:2418:
table "mb_user_wmc"
psql:pgsql/UTF-8/update/update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql:2431:
table "mb_user_wmc"
the first error is thrown because the new constraint cannot be set.
(This is Code of update_2.6.2_to_2.7rc1_pgsql_UTF-8.sql from line 615.)
--adopt mb_user_wmc to store a serial column too!
ALTER TABLE mb_user_wmc DROP CONSTRAINT pk_user_wmc;
ALTER TABLE mb_user_wmc DROP CONSTRAINT mb_user_wmc_pkey; --for older
implementations
--DROP SEQUENCE mb_user_wmc_wmc_serial_id_seq cascade;
CREATE SEQUENCE mb_user_wmc_wmc_serial_id_seq;
ALTER TABLE mb_user_wmc ADD COLUMN wmc_serial_id INTEGER;
ALTER TABLE mb_user_wmc ADD COLUMN wmc_timestamp_create INTEGER;
ALTER TABLE mb_user_wmc ALTER COLUMN wmc_serial_id SET DEFAULT
nextval('mb_user_wmc_wmc_serial_id_seq');
--UPDATE mb_user_wmc SET wmc_serial_id =
NEXTVAL('mb_user_wmc_wmc_serial_id_seq'); TODO: this is only for older
installations - if a serial column exists before, the serial ids will be
updated - that is not what we want cause this are the references!
-- Constraint: pk_user_wmc
ADD CONSTRAINT pk_user_wmc PRIMARY KEY(wmc_serial_id);
the other errors occurs because following new tables reference's to it.
CREATE TABLE wmc_keyword (
fkey_keyword_id INTEGER REFERENCES keyword(keyword_id) ON DELETE
CASCADE ON UPDATE CASCADE,
fkey_wmc_serial_id INTEGER REFERENCES mb_user_wmc(wmc_serial_id)
ON DELETE CASCADE ON UPDATE CASCADE
ALTER TABLE ONLY wmc_keyword
ADD CONSTRAINT pk_wmc_keyword PRIMARY KEY (fkey_wmc_serial_id,
fkey_keyword_id);
--adopt relation for old implementations:
--create a new one and drop the old!
--new categories for publishing -> custom , inspire ?
-- Table: wmc_custom_category
CREATE TABLE wmc_md_topic_category
fkey_wmc_serial_id integer NOT NULL,
fkey_md_topic_category_id integer NOT NULL,
CONSTRAINT wmc_topic_category_fkey_wmc_serial_id_fkey FOREIGN KEY
(fkey_wmc_serial_id)
REFERENCES mb_user_wmc (wmc_serial_id) MATCH SIMPLE
ON UPDATE CASCADE ON DELETE CASCADE,
CONSTRAINT wmc_topic_category_fkey_md_topic_category_id_fkey FOREIGN KEY
(fkey_md_topic_category_id)
REFERENCES md_topic_category (md_topic_category_id) MATCH SIMPLE
CREATE TABLE wmc_custom_category
fkey_custom_category_id integer NOT NULL,
CONSTRAINT wmc_custom_category_fkey_wmc_serial_id_fkey FOREIGN KEY
CONSTRAINT wmc_custom_category_fkey_custom_category_id_fkey FOREIGN KEY
(fkey_custom_category_id)
REFERENCES custom_category (custom_category_id) MATCH SIMPLE
-- Table: wmc_inspire_category
CREATE TABLE wmc_inspire_category
fkey_inspire_category_id integer NOT NULL,
CONSTRAINT wmc_inspire_category_fkey_wmc_serial_id_fkey FOREIGN KEY
CONSTRAINT wmc_inspire_category_fkey_inspire_category_id_fkey FOREIGN
KEY (fkey_inspire_category_id)
REFERENCES inspire_category (inspire_category_id) MATCH SIMPLE
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/819>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev
