[Mapbender_dev] [Mapbender] #794: Digitize/update feature shows all configured Featuretypes
Mapbender mapbender_dev at lists.osgeo.org
Mon Feb 28 04:07:12 EST 2011
 Reporter:  kmq             |       Owner:  dev
     Type:  defect          |      Status:  new
 Priority:  major           |   Milestone:  2.7.1 release
Component:  administration  |     Version:  2.7
 Keywords:                  |
 when you want to update a geometry (let's say a point) and choose the
 attribute dialog you could save your objects in all wfs featuretype confs
 that are available (poin,line,polygon) and not only in the featuretype
 confs of the geometrytype of the geometry (in his case point). SO I could
 try to save a point as a polygon, which does not make sense
     * this worked in version 2.6.*
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/794>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
