[Mapbender_dev] Installation trunk
Christoph Baudson christoph at baudson.de
Mon Jan 31 16:39:37 EST 2011
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi there,
currently I'm running into problems when installing Mapbender from trunk.
The problem is in the applications gui1 and gui2. They simply don't
load. There are no errors whatsoever, not in PHP or JS. I assume it must
have something to do with the WMC that is generated on start-up, as both
applications use EPSG:31467.
I'm running Ubuntu 10.04 with Postgres 8.4, PostGIS 1.5 and PHP 5.3. The
mapbender_setup.php is all green.
Another problem I stumbled upon was in template_openlayers: Here there
are still references to the minified jQuery UI files. The reason is that
the INSERT of the application is after the UPDATE of the minified files.
I have moved the UPDATE to the end of the SQL and committed it to trunk.
I also replaced some occurences of split by explode, as split is deprecated.
If you have any ideas why gui1 and gui2 don't load, please share.
Talk to you soon,
Christoph
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk1HLBQACgkQGtMIfbycMX6mZwCfU2kWF2m3Ypie94irOdRBZSgz
zzMAnj+DlK4+f/8YDHuNy+CNNcu6MsIr
=HXoi
-----END PGP SIGNATURE-----
More information about the Mapbender_dev mailing list
