[Mapbender_dev] [Mapbender] #850: FeatureInfo Dialog jumping arround
Mapbender mapbender_dev at lists.osgeo.org
Thu Jul 7 08:35:07 EDT 2011
 Reporter:  frankjaeger     |       Owner:  dev
     Type:  defect          |      Status:  new
 Priority:  minor           |   Milestone:  2.7.2 release
Component:  user interface  |     Version:  2.7.1
 Keywords:  featureinfo     |
 Select 2 WMS for FeatureInfo and klick a position, where you get results
 for both.
 2 Dialogs are arranged at cascading positions (ticket #792).
 If you select '''the one in the background''' an close ist by X or OK-
 button, or resize it, then the the one in the forground jumps up to a
 position, where you can only see its bottom.
 At resize it jumps back to the mittle of the mapframe.
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/850>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
