[Mapbender_dev] Re: [Mapbender] #827: Dynamic print frame: provide
possibility to cancel a running print
mapbender_dev at lists.osgeo.org
Mon Jul 11 08:47:55 EDT 2011
#827: Dynamic print frame: provide possibility to cancel a running print
Reporter: astrid_emde | Owner: dev
Type: defect | Status: closed
Priority: major | Milestone: 2.7.2 release
Component: print | Version: 2.7.1
Resolution: fixed | Keywords:
Changes (by verenadiewald):
* status: new => closed
* resolution: => fixed
Comment:
for 2.7: http://trac.osgeo.org/mapbender/changeset/7926[[BR]]
while print is running, there is no possibility to stop the server action
-> to have a bit of control you can now set the element var timeout, so
you can define the maximum time a print action can take (reaching the
defined timeout will stop the ajax request)
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/827#comment:1>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev
