AW: AW: [Mapbender_dev] build of Mapbender 2.7.2 is planned for thisweek
Manns, Marc Marc.Manns at remscheid.de
Wed Jul 20 04:03:15 EDT 2011
His Astrid,
no, i didn't use the new template print.
I'll do some bugfixing this evening.
On Thursday i won't have time.
Marc
-----Ursprüngliche Nachricht-----
Von: mapbender_dev-bounces at lists.osgeo.org [mailto:mapbender_dev-bounces at lists.osgeo.org] Im Auftrag von Astrid Emde
Gesendet: Dienstag, 19. Juli 2011 17:36
An: Mapbender Developer List
Betreff: Re: AW: [Mapbender_dev] build of Mapbender 2.7.2 is planned for thisweek
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hello Marc,
thanks for your help.
And thanks for trying to fix the tickets.
I merged with trunk today. But you are right. We have to check, whether everything still works and we did not loose functionality.
By the way: Do you use the new template print? The legend is not present in the output and I do not know why?
I won't have time tomorrow. But I will go on with Mapbender 2.7.3 on Thursday.
Every help is welcome
Astrid
Manns, Marc schrieb:
> Hi Astrid,
> good to hear MB 2.7.2 is on the way.
> I'll try fix folowing tickets this week.
> #765
> #820
> #840
> #841
> I've seen many merge requests with trunk today.
> Hope, this won't crash other things :-) .
> Maybe we should investigate some time for testing this week.
> I will test a little bit in IE8.
> Marc
> Emde
> Gesendet: Dienstag, 19. Juli 2011 10:15
> Betreff: [Mapbender_dev] build of Mapbender 2.7.2 is planned for this
> week
> Hello devs,
> I plan to get Mapbender 2.7.2 ready this week. So is you could support me with bugfixes it would be great.
> You can find the bugs at:
> http://trac.osgeo.org/mapbender/milestone/2.7.2%20release
> All bugs which will not be fixed for 2.7.2 will be moved to Mapbender
> 2.7.3 Milestone.
> If you have enhancements which are not documented in a ticket yet, please add a ticket.
> I plan to build Mapbender 2.7.2 on thursday 21th july 2011.
> Astrid
Mapbender_dev mailing list
Mapbender_dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Mit freundlichen Grüßen
Astrid Emde
INTERGEO 2011
27.-29. September 2011 in Nürnberg
Treffen Sie die WhereGroup in Halle 7, Stand E75 www.intergeo.de
Aufwind durch Wissen!
Qualifizierte OpenSource-Schulungen
bei der www.foss-academy.eu
 Astrid Emde
 WhereGroup GmbH & Co.KG
 Eifelstraße 7
 53119 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 19
 Fax: +49(0)228 90 90 38 - 11
 astrid.emde at wheregroup.com
 www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
 pgp-public key:
 http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
  Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
  Signed and/or encrypted mail is highly appreciated -----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAk4lpHoACgkQBtpS1y1RUoSTqgCgsZsMH3Xb7mkA71D4zsNDytTx
Qn0AoJCrmWwAU0syV3o2riJMEYRFpB4f
=NFlM
-----END PGP SIGNATURE-----
More information about the Mapbender_dev mailing list
