[Mapbender_dev] [Mapbender] #856: Edit element variables of template applications ignores permissions
Mapbender mapbender_dev at lists.osgeo.org
Fri Jul 22 08:29:15 EDT 2011
 Reporter:  Uli             |       Owner:  dev
     Type:  defect          |      Status:  new
 Priority:  blocker         |   Milestone:
Component:  administration  |     Version:  2.7.1
 Keywords:                  |
 if you edit the element variable of template elements in the application-
 element-administration and click the return button, the template
 application is in edit mode. This happens also if you have only read
 permissions on the template application.
 There has to be a client- and serverside validation of permissions.
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/856>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
