[Mapbender_dev] bug & patch with geoserver 2.1 using SRS_ARRAY
zorg
zorg at probesys.com
Fri Jun 3 10:34:58 EDT 2011
Hello
trying to use define SRS_ARRAY in mapbender.conf are not working with
geoserver (for me 2.1)
because the parent layer have no name (you can see the example i have send
I solved the problem with this patch
hope it could be integrated
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20110603/a0bb1dd9/geo.bin
Type: text/xml
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20110603/a0bb1dd9/geo.xml
More information about the Mapbender_dev
