[Mapbender_dev] [Mapbender] #809: load application takes very long
and throws an alert when lot of WMS are loaded
mapbender_dev at lists.osgeo.org
Wed Mar 30 04:32:36 EDT 2011
#809: load application takes very long and throws an alert when lot of WMS are
loaded
Reporter: astrid_emde | Owner: dev
Type: task | Status: new
Priority: major | Milestone: 2.7.1 release
Component: user interface | Version: 2.7
Keywords: |
When you have an application with lot of WMS and Layer (> 20) the
application takes a long time to open.
In IE an alert opens whith a notice that a script produces a delay and
whether you want to stop the script.
kmq already found out that the problem is treeGDE which needs too much
time to build the tree up.
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/809>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev
