[Mapbender_dev] [Mapbender] #831: Dynamic print frame: scale modification
Mapbender mapbender_dev at lists.osgeo.org
Tue May 17 03:28:25 EDT 2011
 Reporter:  astrid_emde  |       Owner:  dev
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  2.7.2 release
Component:  print        |     Version:  2.7.1
 Keywords:               |
 if you change the scale in the textfield 1 is changed to 0 so you can't
 write maybe 1000 it always ends up to 0000
 for more information about the process of the dynamic print have a look at
 #455
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/831>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
