[Mapbender_dev] [Mapbender] #871: WFS-Search: Use actual SRS from mapframe/changeEPSG
Mapbender mapbender_dev at lists.osgeo.org
Thu Oct 13 05:22:10 EDT 2011
 Reporter:  frankjaeger                     |       Owner:  dev
     Type:  enhancement                     |      Status:  new
 Priority:  major                           |   Milestone:  2.7.3 release
Component:  wfs                             |     Version:  2.7.1
 Keywords:  WFS-Search,SRS,EPSG,changeEPSG  |
 WFS-Search positions the Mapframe in the "initial" SRS of the gui.
 That's wrong, when the SRS has changed by using the "changeEPSG" gui
 element.
 Let WFS-search ask for the actual SRS before processing a search. Then use
 actual SRS for positioning the mapframe.
 See ALKIS (PostNAS) Mapbender-Plugin in
 http://trac.wheregroup.com/PostNAS/browser/trunk/data/mapbender/http/nav
 for var "$epsg" and "function sendGuiEpsg ()".
 See also Ticket #712
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/871>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
