[Mapbender_dev] Re: [Mapbender] #825: Dynamic print frame: export sketches to output (like in the old print module)
Mapbender mapbender_dev at lists.osgeo.org
Tue Sep 13 02:45:15 EDT 2011
module)
  Reporter:  astrid_emde  |       Owner:  dev
      Type:  defect       |      Status:  closed
  Priority:  major        |   Milestone:  2.7.3 release
 Component:  print        |     Version:  2.7.1
Resolution:  fixed        |    Keywords:
Changes (by verenadiewald):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 is now implemented, can be integrated as follows:
  * edit the gui element printPDF and integrate a new hidden field for the
 permanentImage into the Content html field
 <input type="hidden" name="mypermanentImage" />
  * add a new element to the json config files for print templates into the
 pages -> elements-section
 "permanentImage" : {
         "type" : "permanentImage"
  * please note: images for permanentHighlight should be of size 80*80px
 and have their marker point in the center at 40*40px, so that they can be
 positioned correctly
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/825#comment:4>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
