[Mapbender_dev] [Mapbender] #885: Conflicts between owsproxy and mb js cache
Mapbender mapbender_dev at lists.osgeo.org
Mon Dec 10 03:40:57 PST 2012
 Reporter:  obgr      |       Owner:  dev
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:
Component:  core      |     Version:  2.7.3
 Keywords:            |
 When using the mb js cache, there is a conflict with owsproxy services.
 The problem is, the service address is stored in the cache files like
 add_wms('1408','1.1.1','Bundesrepublik Deutschland - BW','brd with
 shapes','http://80.72.141.177/owsproxy/r41eianskrkug5alam75c61gg6/a991293e8c4ff2b24c8f2471624a7e84?','http://80.72.141.177/owsproxy/r41eianskrkug5alam75c61gg6/a991293e8c4ff2b24c8f2471624a7e84?','','','image/png','text/html','application/vnd.ogc.se_xml','EPSG:31467','1','100','');wms_add_data_type_format('map','application/x-pdf');
 So, when the session the ows proxy uses is expired, the services don't
 work anymore.
 Is there a way to solve that?
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/885>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
