[Mapbender_dev] Mapbender3 documentation with rst-file and Sphinx
Andreas Schmitz schmitz at occamlabs.de
Fri Feb 24 04:10:38 EST 2012
Astrid Emde wrote:
> Christian and I discussed about how to write the Mapbedner3
> documentation for workshops.
> My idea was to write the documentation in rst like it is done in the
> OSGeo-Live-project [1]. I wrote the documentation for Mapbender 2.7.x
> like this [2]
> We would write a rst-textfile which we can compile to html or pdf with
> Sphinx [3]. We can keep this file at github and Christian mentioned that
> github supports rst-files and can display them as html.
> This is how the rst-file looks for mapbender_quickstart.rst in
> OSGeo-Live [4].
> An advantage would be that we could easily provide the documentation for
> OSGeo-Live if we want to add Mapbender3 to the OSGeo-Live project. And
> also we can easily use the documentation as a template for customized
> workshops.
> What do you think about this idea?
I think it's a good choice. We've also played around with sphinx a bit
for deegree and found it to be quite suitable, looks like we're going to
use it for our handbook as well.
Best regards,
Andreas Schmitz
Occam Labs UG (haftungsbeschränkt)
Godesberger Allee 139
53175 Bonn, Germany
+49 228 937 988 65
http://www.occamlabs.de
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20120224/6d56c845/attachment.bin
More information about the Mapbender_dev mailing list
