[Mapbender-dev] Mapbender3 Git Branches
Christian Wygoda
christian.wygoda at wheregroup.com
Wed Jul 31 07:24:20 PDT 2013
as of today the git branches for Mapbender3 in the following
repositories have been reorganized to utilize the Git Flow [1] workflow:
* https://github.com/mapbender/mapbender-starter.git
* https://github.com/mapbender/mapbender.git
* https://github.com/mapbender/fom.git
* https://github.com/mapbender/owsproxy3.git
Basically that means that daily development happens in the branch
"develop", while the "master" branch will contain only the published
releases as marked by their tags. Right now the master branch is missing
until the next release tag has been created.
All old branches which are not used for that workflow have been renamed
to "deprecated/<name>" and will be deleted by the end of this year.
THIS DOES NOT MEAN that any commits or tags are lost - or will be lost
-, just the branch names have been changed.
This is also reflected in the conventions chapter in the Mapbender3
documentation. If you have any questions, don't hesitate to ask me.
Cheers,
Christian
[1] http://nvie.com/posts/a-successful-git-branching-model/
AGIT25 Symposium und Expo 2013
03.-05. Juli 2013 in Salzburg
www.agit.at
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Germany
Christian Wygoda
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
info at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
URL: <http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20130731/a00cf9f7/attachment.html>
More information about the Mapbender_dev
