[Mapbender-dev] [Mapbender] #891: Set WMS-Layer-Priority in GUI back to the WMS-Default
mapbender_dev at lists.osgeo.org
Fri Mar 8 00:17:15 PST 2013
Reporter: FrankJaeger | Owner: dev
Type: enhancement | Status: new
Priority: minor | Milestone: 2.7.4 release
Component: administration | Version: 2.7.3
Keywords: Layer-Priority |
After insert of Layers in an existing WMS and an Update in Mapbender it is
sometimes usefull to sort the Layer-Priorty as it is designed by the
developer of the WMS.
In Mapbender the Priority stay on the old position, because it may be set
manually.
Setting Layer-Priority Layer by Layer in many GUIs for WMS with many
layers costs a lot of time.
To sort the Layers in the Order of a ''fresh uploaded WMS'' you can use
the following SQL-Statement.
It may be usefull to insert an new Button in "WMS application settings" in
the Head of the [[BR]]
column: "Prio"[[BR]]
row: "Sublayer off" | off | on ...
SQL:
UPDATE gui_layer g SET gui_layer_priority =
( SELECT layer_pos FROM layer l WHERE g.fkey_layer_id = l.layer_id
AND g.gui_layer_wms_id = l.fkey_wms_id)
WHERE g.fkey_gui_id = $1 AND g.gui_layer_wms_id = $2 ;
$1 = gui_id
$2 = wms_id
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/891>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev
