[Mapbender-dev] [Mapbender] #894: Switching OWSPROXY on/off has no effect on cached GUIs
mapbender_dev at lists.osgeo.org
Wed Mar 20 06:50:23 PDT 2013
Reporter: FrankJaeger | Owner: dev
Type: defect | Status: new
Priority: minor | Milestone: 2.7.4 release
Component: administration | Version: 2.7.3
Keywords: OWSPROXY Cache |
When OWSPROXY is switched between 'on' and 'off' in
admin_XX_services/OWSPROXY this has no effect for the usage of this WMS in
a cached GUI (mapframe1 has 'loadFromCache'=1).
Workaround:[[BR]]
You have to remove (all) files in /mapbender/cache/-directory before
reloading the GUI.
Solution would be:[[BR]]
After changing WMS/OWSPROXY remove all GUI-Caches which use this WMS.
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/894>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev
