[Mapbender-dev] [Mapbender] #915: text css as element-var
Mapbender mapbender_dev at lists.osgeo.org
Wed Jun 11 11:18:13 PDT 2014
 Reporter:  marcm           |       Owner:  dev
     Type:  defect          |      Status:  new
 Priority:  major           |   Milestone:  2.7.4 release
Component:  administration  |     Version:  2.7.3
 Keywords:                  |
 Since Mapbender 2.7 the "text/css" statements in element-var doesnt work.
 (File/css works fine)
 The reason is in a comment block (<!-- ) in index.php before the text css
 is produced.
 see:
 <style type="text/css">
         <?php
                 $sql = <<<SQL
         SELECT DISTINCT e_id, e_element, var_value, var_name, var_type
 FROM gui_element, gui_element_vars
         WHERE
                 e_id = fkey_e_id
                 AND e_element <> 'iframe'
                 AND gui_element.fkey_gui_id = $1
                 AND gui_element_vars.fkey_gui_id = $1
                 AND var_type = 'text/css'
         ORDER BY var_name
         SQL;
                 $v = array($gui_id);
                 $t = array('s');
                 $res = db_prep_query($sql,$v,$t);
                 $cnt = 0;
                 while($row = db_fetch_array($res)){
                         echo $row["var_value"] . "\n";
         </style>
 With Mapbender 2.6 everything worked fine.
 Maybe the different Doctype declaration...?.
 MB2.6=
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
 MB2.7=
 http://www.w3.org/TR/html4/loose.dtd">
 I think deleting the comment statement should solve this.
 (I hope this causes no other Browser incompatibility... :-) )
 What do you think?
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/915>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
