[Mapbender-dev] composer update fails due to toooni/fpdf package
Axel Schaefer
axel.schaefer at wheregroup.com
Mon May 30 06:11:57 PDT 2016
Dear all,
the soluting is ready. Please take a look at github:
https://github.com/mapbender/mapbender/issues/423
Regards,
Andriy (and Axel)
Am 25.05.2016 um 13:19 schrieb Axel Schaefer:
> Dear Mapbender developers (cc/x-post: mapbender_users)
> If you want to do a composer update you'll notice an error concerning
> the package: toooni/fpdf. The package cannot be found and used.
> The package is referenced in composer.json:
> "toooni/fpdf": "dev-master",
> We are looking for a solution how to prevent that issue and will provide
> a hotfix for that.
> Project-specific builds, that some users use are not affected by this.
> Although if you do a composer update or composer install for yourself
> you'll run into this error.
> Regards,
> Axel
Axel Schaefer
WhereGroup GmbH & Co. KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 31
Fax: +49 (0)228 / 90 90 38 - 11
www.meldemax.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
