[Mapbender-dev] Add New Layer
Astrid Emde
astrid.emde at wheregroup.com
Thu Oct 4 06:04:22 PDT 2018
Hello Antonio,
the problem is that you add the layer only to the OpenLayer Map-element.
But Mapbender has an additional Mapbender-modell that tells OpenLayer
what to show.
So you have to talk with the Mapbender Model.
Please check WMSLoader element to find out how it works.
See
https://doc.mapbender.org/en/functions/misc/wms_loader.html
and code at GitHub:
https://github.com/mapbender/mapbender/blob/master/src/Mapbender/WmsBundle/Element/WmsLoader.php
https://github.com/mapbender/mapbender/blob/master/src/Mapbender/WmsBundle/Resources/public/mapbender.element.wmsloader.js#L128
Greetings from Bonn & Berlin
Stefan & Astrid
Am 2018-09-27 08:10, schrieb Antonio de jesus hernandez Gomez:
> Hello,
> a few days ago i have been triying to add a new layer to the map.
> Firtly i add a own element, a search with cql because i use geoserver.
> i already add the layer but when i zoom in or zoom out in to the map
> the new layer not refresh. the layer just apear when the map is in
> the zoom in that i added the layer.
> i have the js of my element in this link
> https://github.com/SplashZK/search/blob/master/buscador.js
> and i add the layer in "buscar: function()"
> i don´t know if i add the layer in the correct form because is my
> first time using mapbender.--
> Antonio de Jesús Hernández Gómez
> Maestro en Ciencias de la Computación
> cel. 963 236 57 27
> e-mail: antonio_2093 at hotmail.com
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_dev
Mit freundlichen Grüßen
Astrid Emde
Senior GIS-Consultant
INTERGEO 2018
16.- 18. Oktober 2018 in Frankfurt am Main
Treffen Sie die WhereGroup an Stand 12.0A.29 in Halle 12.0
Astrid Emde
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 22
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
