[Mapbender-dev] [Mapbender] #920: failed initialization of EPSG from address search
Mapbender mapbender_dev at lists.osgeo.org
Mon Aug 5 09:31:34 PDT 2019
 Reporter:  SvenLVGL  |      Owner:  dev
     Type:  defect    |     Status:  new
 Priority:  minor     |  Milestone:
Component:  core      |    Version:  2.7.3
 Keywords:            |
 == Describe the bug
 The map viewer throws error messages and does not work as intended when
 opened directly from the address search if it was not initialized before.
 == To Reproduce
 Steps to reproduce the behavior:
 1. Close your browser.
 2. Open your browser in a private window (no cache/cookies/etc.)
 3. Go directly to the address search, without opening the map viewer
 before
 4. Search a valid address and open the resulting link to view it on the
 mal
 5. See error similar to the attached screenshots.
 == Expected behavior
 The map viewer should zoom to the addresses location on the map and
 display a dot to indicate the location.
 == Screenshots
 == Desktop
 Has been tested with
  - Google Chrome
  - Mozilla Firefox
  - Microsoft Internet Explorer
  - Microsoft Edge
 == Additional context
 The fix seems to be found already. The issue is in the file
 **mapbender/http/javascripts/initWmcObj.php**.
 The following line seems to produce the problem, if the ''epsg'' has not
 been initialized in this session before.
 {{{#!php
 $currentEpsg = Mapbender::session()->get("epsg");
 The solution could look like this:
 {{{#!php
         if (!$currentEpsg) {
             $currentEpsg = $DEFAULT_EPSG;
 With `DEFAULT_EPSG` being defined in a configuration file that's included.
Ticket URL: <https://trac.osgeo.org/mapbender/ticket/920>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
