[Mapbender-dev] (no subject)
eric rasamoelina eric eerriicc8181 at gmail.com
Sun Mar 3 10:37:30 PST 2019
Thank so much for your advanced!,,,,, If I open
https://localhost/mapbender/app_dev.php/ ,, I see :
InvalidArgumentException in YamlFileLoader.php line 366
The file "c:\ms4w\apps\mapbender3-starter-3.0.7.7\app/
config/config_dev.yml" does not contain valid YAML.
On Feb 28, 2019 9:55 AM, "Astrid Emde (WhereGroup)" <
astrid.emde at wheregroup.com> wrote:
> Hello Eric,
> it looks like Mapbender can't connect to your database.
> Your config files look fine
> your search database is: database2_name search_db
> Did you try the app_dev.php mode?
> http://your-server/mapbender/app_dev.php
> It will offer you more details in the developer tools response
> Also make sure that you empty the cache mapbender/app/cache as changes in
> the config files are cached in productive mode.
> Astrid
> Am 2019-02-27 19:07, schrieb eric rasamoelina eric:
>> Dear Mapbender community
>> thank you very much!!
>> If i open the application in a browser i receive the following error:
>> Feature API query error.”<!DOCTYPE html>\n<html>\n <head>\n <meta
>> charset=\”UTF-8\” />\n <titel>An Error Occured: Internal Server
>> Error</titel>\n </head>\n <body>\n <h1>Oops! An Error Occurred</h1>\n
>> <h2>The server returned a \”500 Internal Server Error\”.</h2>\n\n
>> <div>\n Something is broken. Please let us know what you were doing
>> when this error occurred.\n We will fix it as soon as possible. Sorry
>> for any inconvenience caused.\n </div>\n </body>\n</html>\n”
>> Down below, there are the parameters.yml and config.yml. Do anybody
>> know how to solve these problems?
>> Thank you for your help and best regards,
>> Eric
>> I've this script
>> config.yml
>> imports: - { resource: parameters.yml } - { resource: security.yml }
>> framework: #esi: ~ translator: { fallback: %fallback_locale% } secret:
>> %secret% router: resource: "%kernel.root_dir%/config/routing.yml"
>> strict_requirements: %kernel.debug% form: true csrf_protection: true
>> validation: { enable_annotations: true } templating: { engines:
>> ['twig'] } #assets_version: SomeVersionScheme default_locale: %locale%
>> session: cookie_httponly: true cookie_secure: %cookie_secure%
>> cookie_lifetime: %cookie_lifetime% # Twig Configuration twig: debug:
>> %kernel.debug% strict_variables: %kernel.debug% globals: fom: %fom%
>> form: resources: - 'FOMCoreBundle:Form:fields.html.twig' # Assetic
>> Configuration assetic: debug: %kernel.debug% use_controller: true
>> filters: cssrewrite: ~ sass: ~ # Doctrine Configuration doctrine:
>> dbal: default_connection: default connections: default: driver:
>> "%database_driver%" host: "%database_host%" port: "%database_port%"
>> dbname: "%database_name%" path: "%database_path%" user:
>> "%database_user%" password: "%database_password%" #persistent: true
>> (nodekomantena) charset: UTF8 logging: %kernel.debug% profiling:
>> %kernel.debug% #second database search_db: driver:
>> "%database2_driver%" host: "%database2_host%" port: "%database2_port%"
>> dbname: "%database2_name%" path: "%database2_path%" user:
>> "%database2_user%" password: "%database2_password%" charset: UTF8
>> logging: "%kernel.debug%" profiling: "%kernel.debug%" orm:
>> auto_generate_proxy_classes: %kernel.debug% auto_mapping: true #
>> Swiftmailer Configuration swiftmailer: transport: %mailer_transport%
>> host: %mailer_host% username: %mailer_user% password:
>> %mailer_password% spool: { type: memory } # FOM Manager Configuration
>> fom_manager: route_prefix: /manager # FOM User Configuration fom_user:
>> selfregister: false reset_password: true max_registration_time: 1
>> max_reset_time: 1 mail_from_address: wizard at oz.net mail_from_name:
>> Wizard of Oz profile_entity: FOM\UserBundle\Entity\BasicProfile
>> profile_formtype: FOM\UserBundle\Form\Type\BasicProfileType
>> profile_template: FOMUserBundle:User:basic_profile.html.twig
>> self_registration_groups: - Self Registered - Demo Group # Allow to
>> create user log table on the fly if the table doesn't exits. #
>> Default: true auto_create_log_table: false # Time between to check
>> login tries login_check_log_time: "-5 minutes" # Login attemps before
>> delay starts login_attempts_before_delay: 3 # Login delay after all
>> attemps are failed login_delay_after_fail: 5 # Seconds # OWSProxy
>> Configuration ows_proxy3_core: logging: %ows_proxy3_logging%
>> obfuscate_client_ip: %ows_proxy3_obfuscate_client_ip% proxy: host:
>> %ows_proxy3_host% port: %ows_proxy3_port% connecttimeout:
>> %ows_proxy3_connecttimeout% timeout: %ows_proxy3_timeout% user:
>> %ows_proxy3_user% password: %ows_proxy3_password% checkssl: true
>> noproxy: %ows_proxy3_noproxy% # Mapbender Configuration
>> mapbender_core: ~
>> parameters.yml
>> parameters: # database-connection "default" database_driver: pdo_pgsql
>> database_host: localhost database_port: 5432 database_name:
>> JDElectricite database_path: ~ database_user: postgres
>> database_password: post # database-connection "search_db"
>> database2_driver: pdo_pgsql database2_host: localhost database2_port:
>> 5432 database2_name: search_db database2_path: ~ database2_user:
>> postgres database2_password: post
>>  #database_driver: pdo_sqlite #database_host: ~ #database_port: ~
>> #database_name: ~ #database_path: %kernel.root_dir%/db/demo.sqlite
>> #database_user: ~ #database_password: ~ mailer_transport: smtp
>> mailer_host: localhost mailer_user: ~ mailer_password: ~ # locale en,
>> de, it, es, ru, nl, pt are available fallback_locale: en locale: en
>> secret: ThisTokenIsNotSoSecretChangeIt fom: server_name: Mapbender3
>> server_version: 3.0.6.3 server_logo:
>> bundles/mapbendercore/image/logo_mb3.png # framework :
>> http://symfony.com/doc/2.8/reference/configuration/framework
>> .html#cookie-lifetime
>> cookie_secure: false cookie_lifetime: 3600 # OWSProxy Configuration
>> ows_proxy3_logging: false ows_proxy3_obfuscate_client_ip: true
>> ows_proxy3_host: ~ ows_proxy3_port: ~ ows_proxy3_connecttimeout: 60
>> ows_proxy3_timeout: 90 ows_proxy3_user: ~ ows_proxy3_password: ~
>> ows_proxy3_noproxy: ~
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_dev
> Mit freundlichen Grüßen
> Astrid Emde
> GIS-Consultant
> FOSS Academy Kompaktkurs "Winterschule 2019"
> Grundwissen zum Aufbau von Geodateninfrastrukturen mit
> Open-Source-Software https://foss-academy.com/kompaktkurse
>   Astrid Emde
>   WhereGroup GmbH & Co.KG
>   Eifelstraße 7
>   53119 Bonn
>   Germany
>   Fon: +49(0)228 90 90 38 - 22
>   Fax: +49(0)228 90 90 38 - 11
>   www.wheregroup.com
>   Folgen Sie der WhereGroup auf twitter:
> http://twitter.com/WhereGroup_com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
URL: <http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20190303/327b419e/attachment.html>
More information about the Mapbender_dev mailing list
