[Mapbender-dev] Error digitizer
Charlotte Toma
charlotte.toma at wheregroup.com
Fri Mar 8 00:50:10 PST 2019
Hello Jana-Teresa,
could you try it with the developer mode?
There you should see the problem in a red box at the right corner of
your application and in the logfiel at /mapbender/app/logs/dev.log
(perhaps wrong databasename in your connection, error in yaml-definition
or else).
More about the developer mode (https://localhost/mapbender/app_dev.php)
is here:
https://doc.mapbender.org/en/installation/configuration.html?highlight=developer%20mode#production-and-development-environment-and-caching-app-php-and-app-dev-php
If you can't fix it, then write us your error messages from the dev-mode
Best wishes,
Charly
Mit freundlichen Grüßen
Charlotte Toma
GIS-Consultant
FOSS Academy Kompaktkurs "Winterschule 2019"
Grundwissen zum Aufbau von Geodateninfrastrukturen mit Open-Source-Software
https://foss-academy.com/kompaktkurse
Charlotte Toma
WhereGroup GmbH & Co.KG
Eifelstraße 7
53119 Bonn
Germany
Fon: +49(0)228 90 90 38 - 24
Fax: +49(0)228 90 90 38 - 11
info at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Am 08.03.19 um 09:34 schrieb Jana-Teresa Bauer:
> Hi,
> I have a problem with my digitizer tool. When the digitizer is turned
> on, an error message appears:
> Feature API: Abfrage fehlgeschlagen. "<!Doctype
> html>\n<html>\n<head>\n<meta charset=\"UTF-8\"/>\n<title>An Error
> Occured: Internal Server Error </title>\n</head>\n<body>\n<h1>Oops! An
> Error Occured </h1>\n<h2>The server returned a \"500 Internal Server
> Error\".</h2>\n\n <div>\n Something is broken. Please let us know what
> you where doing when this error occured.\n We will fix it as soon as
> possible. Sorry for any inconvenience caused. \n
> </div>\n</body>\n</html>\n"
> Unfortunately, I do not know what the error is, the coordinate system
> is correctly stated.
More information about the Mapbender_dev
