[Mapbender-dev] Error digitizer
Charlotte Toma charlotte.toma at wheregroup.com
Fri Mar 8 01:26:01 PST 2019
the developer mode is enabled for the use via localhost - to enable the
access for yourself you need to add your ip or uncomment the code-block
with the restriction. Open the file mapbender/web/app_dev.php and do one
of the following steps:
 1. Add your IP in line 16 -> array('127.0.0.1', 'fe80::1',
    '::1','your_ip_number'))
 2. Uncomment the restriction ->  /* line 14-20 */
Be aware that the safer way is to add your ip, cause the dev-mode gives
informations like passwords
Wishes
Charly
Am 08.03.19 um 10:17 schrieb janab:
> The App_dev Mode does not work. I can't log in, the following error massages:
> https://localhost/app_dev.php :
> You are not allowed to access this file. Check app_dev.php for more
> information.
> https://localhost/mapbender/app_dev.php:
> Oops! An Error Occurred
> The server returned a "404 Not Found".
> Something is broken. Please let us know what you were doing when this error
> occurred. We will fix it as soon as possible. Sorry for any inconvenience
> caused.
> Sent from: http://osgeo-org.1560.x6.nabble.com/mapbender-dev-f4217603.html
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_dev
URL: <http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20190308/49584c74/attachment.html>
More information about the Mapbender_dev mailing list
