[Mapbender-dev] Mapbender Release 3.0.8.6 LTS - 2020-09-23
Jeff McKenna jmckenna at gatewaygeomatics.com
Fri Oct 9 11:36:59 PDT 2020
3.0.8.6 is also now available to the MS4W (Windows) community directly
through the installer, or as a separate download at:
https://ms4w.com/download.html
Of course you can also just run the Mapbender 3.0.8.6 application on the
official MS4W demo server (which is running MS4W version 4.0.4 on a
Windows enterprise server) at: https://ms4w.dev/mapbender/app.php/
Thank-you for using MS4W.
"MS4W: open doors as well as windows"
-jeff
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
On 2020-10-09 6:40 a.m., Olaf Knopp (WhereGroup) wrote:
> See English Version below
> =Deutsch=
> Hallo Mapbender-Community,
> am 23.09.2020 hat das Mapbender-Team die LTS-Version 3.0.8.6 mit vielen
> Bugfixes veröffentlicht. Herzlichen Dank an alle Beteiligten.
> Sie steht unter den bekannten Links zum Download bereit:
> * https://github.com/mapbender/mapbender/releases
> * https://mapbender.org/builds/
> * https://github.com/mapbender/mapbender-starter/archive/v3.0.8.6.tar.gz
> Das Mapbender-Team wünscht viel Spaß mit der neuen Version
> =English=
> Hello Mapbender-Community,
> on 2020-09-23 the Mapbender team released the LTS version 3.0.8.6 with
> many bugfixes. Thank you to everyone involved.
> You can download the release via the known links:
> The Mapbender team wishes you a lot of fun with the new version
More information about the Mapbender_dev mailing list
