[Mapbender-users] document.getElementById(tab_ids[i])
Astrid Emde astrid.emde at ccgis.de
Wed Apr 12 11:28:00 EDT 2006
Anna S. schrieb:
> I've tried to create a treeGDE folder using treeConfGDE in Mapbender 2.2.2
> but now I've problems with displaying any layer in the mapframe. The
> Javascipt Console reports the following error:
> "document.getElementById(tab_ids[i]) has no properties"
> If I try to redraw the mapframe: there comes a map, however the Javascipt
> Console notifies:
> "mb_mapObj(ind) has no properties"
> "mb_button(ind) has no properties"
> I've even defined some layers with "sel_default" in "Edit GUI-WMS". When I
> try to check a layer directly in the treeConfGDE tool it doesn't work.
Hi Anna,
  do you use the element tabs in your gui?
The error document.getElementById(tab_ids[i]) looks like.
Have a look at the element vars of the element tabs (go to an admin gui
- select your gui - go to edit gui elements  - klick on the link of the
element tabs)
tabs:
  There you find the tab_ids of the elements you want to be part of the
tabs. Maybe your "old" treeGDE is still mentioned in one of the tab_ids.
replace it with your treeConfGDE
Also you have to set the treeConfGDE-element hidden.
Hope I could help
Astrid Emde
  Astrid Emde
  CCGIS GbR
  Siemensstraße 8
  53121 Bonn
  Germany
          www.ccgis.de
  Tel.:      ++49 (0) 228 90826 19
  Fax.:      ++49 (0) 228 90826 11
  Zentrale:  ++49 (0) 228 90826 0
More information about the Mapbender_users mailing list
