[Mapbender-users] the mapbender installation stuck on half way
Manfred Meier
m.meier at spiekermann.de
Thu Aug 10 08:13:10 EDT 2006
in my mapbender 2.2 installation there where after login as root a list
with several gui's, some of them with the message you described and some
of them with data from several WMS sites.
You can create a new gui over the admin-guis.
As far as I know, you need a wms service that delivers the images to
your gui. Can you describe, what you want to do? Do you have shapefiles?
Do you have umn mapserver running?
Manfred
smithveg schrieb:
> Ok, thanks for your helps. I can login now and see a table.
> Then i try to click any of it in the table, it give me the error as below:
> This GUI is an OGC service catalog container and does not provide a map
> user interface. Please use the ( back) link to select another GUI form
> your list or log off to log on using another account (identity).
> Diese GUI ist ein OGC Service Katalog Behälter (Eimer, Container, nimm
> was Du meinst) und beinhaltet keine Kartenoberfläche. Verwenden Sie
> diesen (back) Verweis, um aus der Liste eine andere GUI auszuwählen oder
> melden Sie sich ab, um sich mit einer anderen Kennung anzumelden.
> in addition, the insert statement as below correct or not?
> postgres=# INSERT INTO
> mb_user(mb_user_id,mb_user_name,mb_user_password,mb_user_
> owner,mb_user_description,mb_user_login_count)
> VALUES(5,'admin1','admin1',1,'adm
> in',5);
> INSERT 0 1
> postgres=#-
> On 8/10/06, Jan Peters-Anders <petersja at gmx.at <mailto:petersja at gmx.at>>
> wrote:
> Smithveg,
> set the count to 0, not 10 or 100!
> Jan
> smithveg schrieb:
> > still the same error "login failed 3 times", after i set the count to
> > 100 or 10
> > I did try to insert a new user bye the following insert
> statement. But
> > nothing was added in the table
> > in',5);
> > INSERT 0 1
> > postgres=#
> > Even i do not insert the primary key (mb_user_id), it also cannot
> add...
> > On 8/10/06, *Manfred Meier* < m.meier at spiekermann.de
> <mailto:m.meier at spiekermann.de>
> > <mailto:m.meier at spiekermann.de <mailto:m.meier at spiekermann.de>>>
> wrote:
> > in table mb_user field mb_user_login_count.
> > Manfred
> > smithveg schrieb:
> > > oh my god!
> > > I did tried it, 'roor' for username and password. I also cannot
> > walk.
> > > By now, i prompt me the error as below:
> > > Permission denied. Login failed 3 times. Your account has been
> > > deactivated. Please contact your administrator!
> > > Where can i reset it....
> > To unsubscribe, e-mail: users-unsubscribe at mapbender.osgeo.org
> <mailto:users-unsubscribe at mapbender.osgeo.org>
> <mailto:users-unsubscribe at mapbender.osgeo.org>>
> > For additional commands, e-mail:
> users-help at mapbender.osgeo.org <mailto:users-help at mapbender.osgeo.org>
> <mailto:users-help at mapbender.osgeo.org>>
> > smithveg
> For additional commands, e-mail: users-help at mapbender.osgeo.org
> smithveg
More information about the Mapbender_users
