[Mapbender-users] Mapbender Fehlermeldung
smithveg
smithveg at gmail.com
Fri Aug 11 05:10:53 EDT 2006
http://babel.altavista.com
I'm not sure what's the error with 'preg_match()'. Could you provides more
information, how you get the error, any steps? So that we may helps you.
Basically, the error is the solutions. I means the error something will tell
you what to do.
Hopes this helps....
Are you new to mapbender?
smith
On 8/11/06, ProAlp - Gotthard <scalet.gotthard at proalp.at> wrote:
> Hallo,
> Beim Starten des Mapbender unter FreeBsd bekomme ich folgende
> fehlermeldung:
> Fatal error: Call to undefined function preg_match() in
> /usr/local/www/data-dist/mapbender/http/php/mb_validateInput.php on line
> 26
> Was kann da die Ursache sein?
> Gotthard
> To unsubscribe, e-mail: users-unsubscribe at mapbender.osgeo.org
> For additional commands, e-mail: users-help at mapbender.osgeo.org
smithveg
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20060811/d9874f7d/attachment.html
More information about the Mapbender_users
