AW: [Mapbender-users] Mapbender Fehlermeldung
Lars-Hendrik Schneider schneider at terrestris.de
Fri Aug 11 05:39:37 EDT 2006
ProAlp - Gotthard schrieb:
> hy,
> This is the whole Screen, there is no more!!
> On my Windows System when i klick the Link the mapbender Login Site is
> opening, but on the FreeBsd System the Error is comming.
preg_match() is part of the PHP, so the error seems to have nothing to
do with Mapbender. It is part of the PCRE (= stands for Perl Compatible
Regular Expressions), which uses Mapbender.
Please check your system setup.
Have a look here: http://www.bsdforen.de/showthread.php?t=6325
This is a thread dealing with it (a little bit older but perhaps you get
a hint here).
Regards,
Lars-Hendrik
> *Von:* smithveg [mailto:smithveg at gmail.com]
> *Gesendet:* Freitag, 11. August 2006 11:30
> *An:* users at mapbender.osgeo.org
> *Betreff:* Re: [Mapbender-users] Mapbender Fehlermeldung
> since u have already print the screen, can you print whole screen for
> us, to check it all..
> I still can't understand whatis the error u get.... where it come
> from... the easiest way is print whole screen from
> mapbender/tools/mapbender_setup.php to us...
> thanks...
More information about the Mapbender_users mailing list
