[Mapbender-users] Mapbender und Geoserver
Uli Rothstein
uli.rothstein at ccgis.de
Tue Aug 22 10:12:55 EDT 2006
mapbender needs a boundingbox (map-extent) to initialise the client.
Your capabilities document contains a long list of srs, that's true, but only
one extent (4326):
>> <SRS>long list</SRS>
>> <LatLonBoundingBox minx="5.565041930901071"
>> miny="47.141817062783524" maxx="15.571502760545522"
>> maxy="55.05911195231699"/>
you need some additional BoundingBox-declarations to communicate mapbender in
which extent the map should be displayed.
For example:
<LatLonBoundingBox minx="6.11046" miny="48.9621" maxx="8.58886" maxy="50.9573"/>
<BoundingBox SRS="EPSG:31466" minx="2.50808e+06" miny="5.42784e+06"
maxx="2.68198e+06" maxy="5.64676e+06"/>
best regards
Uli
Christoph Ratke schrieb:
> Hello Daniel,
> It seems like Mapbender does not cope with the long list of possible srs.
> I would propose two things:
> 1. either save the capabilities file down to disk and edit the SRS
> elements manually. Then load this file into Mapbender with the Load
> Capabilities tool and type in something like
> "file:///<path_to_capabilities>/<capabilities.xml>"
> 2. or update the table layer_epsg directly and maybe wms_srs as well.
> But this seems to be very tricky, so you should better try the first
> option.
> Maybe someone got a better idea?
> Christoph
> Daniel Goetz schrieb:
>> Hi coummunity,
>> I am still struggling with the interaction of mapbender and geoserver
>> as an wms server.
>> In the geoserver admin tool I define a featuretype. Among others I set
>> the SRS the featuretype is in. In my case it's EPSG:31467. After
>> loading the capabilities in the mapbender database I configure the
>> "WMS GUI settings". There I want to set the "EPSG" in which mapbender
>> shall show the data. But I only have the option to select EPSG:4326
>> and there is no possibility to select the SRS I set in the geoserver
>> admin tool under config/data/featuretype. Why does mapbender only
>> offer the option to select "EPSG:4326" as my starting SRS although I
>> declared "EPSG:31467" as the SRS the WMS-layer is in (the mentioned
>> WMS-service onyl contains one layer/featuretype)?
>> Does anybody have an idea? Can somebody help me? would be very nice.
>> Thank you so much.
>> best regards
>> Daniel
>> P.S. Here is the GetCapabilities document of the WMS:
>> <?xml version="1.0" encoding="UTF-8"?>
>> <!DOCTYPE WMT_MS_Capabilities SYSTEM
>> "http://localhost:8080/geoserver/schemas/wms/1.1.1/WMS_MS_Capabilities.dtd">
>> <WMT_MS_Capabilities version="1.1.1">
>> <Service>
>> <Name>OGC:WMS</Name>
>> <Title>geoserv-brwk</Title>
>> <Abstract>bodenrichtwertkarte nuernberg </Abstract>
>> <KeywordList>
>> <Keyword>WFS</Keyword>
>> <Keyword>WMS</Keyword>
>> <Keyword>GEOSERVER</Keyword>
>> </KeywordList>
>> <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
>> xlink:type="simple"
>> xlink:href="http://geoserver.sourceforge.net/html/index.php"/>
>> <Fees>NONE</Fees>
>> <AccessConstraints>NONE</AccessConstraints>
>> </Service>
>> <Capability>
>> <Request>
>> <GetCapabilities>
>> <Format>application/vnd.ogc.wms_xml</Format>
>> <DCPType>
>> <HTTP>
>> <Get>
>> <OnlineResource
>> xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple"
>> xlink:href="http://localhost:8080/geoserver/wms?"/>
>> </Get>
>> <Post>
>> <OnlineResource
>> </Post>
>> </HTTP>
>> </DCPType>
>> </GetCapabilities>
>> <GetMap>
>> <Format>application/pdf</Format>
>> <Format>image/png</Format>
>> <Format>image/jpeg</Format>
>> <Format>application/vnd.google-earth.kmz</Format>
>> <Format>image/svg+xml</Format>
>> <Format>image/gif</Format>
>> <Format>application/vnd.google-earth.kml+xml</Format>
>> <DCPType>
>> <HTTP>
>> <Get>
>> <OnlineResource
>> </Get>
>> </HTTP>
>> </DCPType>
>> </GetMap>
>> <GetFeatureInfo>
>> <Format>text/plain</Format>
>> <Format>text/html</Format>
>> <Format>application/vnd.ogc.gml</Format>
>> <DCPType>
>> <HTTP>
>> <Get>
>> <OnlineResource
>> </Get>
>> <Post>
>> <OnlineResource
>> </Post>
>> </HTTP>
>> </DCPType>
>> </GetFeatureInfo>
>> <DescribeLayer>
>> <DCPType>
>> <HTTP>
>> <Get>
>> <OnlineResource
>> </Get>
>> </HTTP>
>> </DCPType>
>> </DescribeLayer>
>> <GetLegendGraphic>
>> <DCPType>
>> <HTTP>
>> <Get>
>> <OnlineResource
>> </Get>
>> </HTTP>
>> </DCPType>
>> </GetLegendGraphic>
>> </Request>
>> <Exception>
>> <Format>application/vnd.ogc.se_xml</Format>
>> </Exception>
>> <UserDefinedSymbolization SupportSLD="1" UserLayer="1"
>> UserStyle="1" RemoteWFS="0"/>
>> <Layer>
>> <!--common SRS:-->
>> <SRS>EPSG:31467</SRS>
>> <!--All supported EPSG projections:-->
>> <SRS>EPSG:100001</SRS>
>> <SRS>EPSG:100002</SRS>
>> <SRS>EPSG:104000</SRS>
>> <SRS>EPSG:104101</SRS>
>> <SRS>EPSG:104102</SRS>
>> <SRS>EPSG:104103</SRS>
>> <SRS>EPSG:104104</SRS>
>> <SRS>EPSG:104105</SRS>
>> <SRS>EPSG:104106</SRS>
>> <SRS>EPSG:104107</SRS>
>> <SRS>EPSG:104108</SRS>
>> <SRS>EPSG:104261</SRS>
>> <SRS>EPSG:104304</SRS>
>> <SRS>EPSG:104305</SRS>
>> <SRS>EPSG:18001</SRS>
>> <SRS>EPSG:2000</SRS>
>> <SRS>EPSG:20004</SRS>
>> <SRS>EPSG:20005</SRS>
>> <SRS>EPSG:20006</SRS>
>> <SRS>EPSG:20007</SRS>
>> <SRS>EPSG:20008</SRS>
>> <SRS>EPSG:20009</SRS>
>> <SRS>EPSG:2001</SRS>
>> <SRS>EPSG:20010</SRS>
>> <SRS>EPSG:20011</SRS>
>> <SRS>EPSG:20012</SRS>
>> <SRS>EPSG:20013</SRS>
>> <SRS>EPSG:20014</SRS>
>> <SRS>EPSG:20015</SRS>
>> <SRS>EPSG:20016</SRS>
>> <SRS>EPSG:20017</SRS>
>> <SRS>EPSG:20018</SRS>
>> <SRS>EPSG:20019</SRS>
>> <SRS>EPSG:2002</SRS>
>> <SRS>EPSG:20020</SRS>
>> <SRS>EPSG:20021</SRS>
>> <SRS>EPSG:20022</SRS>
>> <SRS>EPSG:20023</SRS>
>> <SRS>EPSG:20024</SRS>
>> <SRS>EPSG:20025</SRS>
>> <SRS>EPSG:20026</SRS>
>> <SRS>EPSG:20027</SRS>
>> <SRS>EPSG:20028</SRS>
>> <SRS>EPSG:20029</SRS>
>> <SRS>EPSG:2003</SRS>
>> <SRS>EPSG:20030</SRS>
>> <SRS>EPSG:20031</SRS>
>> <SRS>EPSG:20032</SRS>
>> <SRS>EPSG:2004</SRS>
>> <SRS>EPSG:2005</SRS>
>> <SRS>EPSG:2006</SRS>
>> <SRS>EPSG:20064</SRS>
>> <SRS>EPSG:20065</SRS>
>> <SRS>EPSG:20066</SRS>
>> <SRS>EPSG:20067</SRS>
>> <SRS>EPSG:20068</SRS>
>> <SRS>EPSG:20069</SRS>
>> <SRS>EPSG:2007</SRS>
>> <SRS>EPSG:20070</SRS>
>> <SRS>EPSG:20071</SRS>
>> <SRS>EPSG:20072</SRS>
>> <SRS>EPSG:20073</SRS>
>> <SRS>EPSG:20074</SRS>
>> <SRS>EPSG:20075</SRS>
>> <SRS>EPSG:20076</SRS>
>> <SRS>EPSG:20077</SRS>
>> <SRS>EPSG:20078</SRS>
>> <SRS>EPSG:20079</SRS>
>> <SRS>EPSG:2008</SRS>
>> <SRS>EPSG:20080</SRS>
>> <SRS>EPSG:20081</SRS>
>> <SRS>EPSG:20082</SRS>
>> <SRS>EPSG:20083</SRS>
>> <SRS>EPSG:20084</SRS>
>> <SRS>EPSG:20085</SRS>
>> <SRS>EPSG:20086</SRS>
>> <SRS>EPSG:20087</SRS>
>> <SRS>EPSG:20088</SRS>
>> <SRS>EPSG:20089</SRS>
>> <SRS>EPSG:2009</SRS>
>> <SRS>EPSG:20090</SRS>
>> <SRS>EPSG:20091</SRS>
>> <SRS>EPSG:20092</SRS>
>> <SRS>EPSG:2010</SRS>
>> <SRS>EPSG:2011</SRS>
>> <SRS>EPSG:2012</SRS>
>> <SRS>EPSG:2013</SRS>
>> <SRS>EPSG:20135</SRS>
>> <SRS>EPSG:20136</SRS>
>> <SRS>EPSG:20137</SRS>
>> <SRS>EPSG:20138</SRS>
>> <SRS>EPSG:2014</SRS>
>> <SRS>EPSG:2015</SRS>
>> <SRS>EPSG:2016</SRS>
>> <SRS>EPSG:2017</SRS>
>> <SRS>EPSG:2018</SRS>
>> <SRS>EPSG:2019</SRS>
>> <SRS>EPSG:2020</SRS>
>> <SRS>EPSG:2021</SRS>
>> <SRS>EPSG:2022</SRS>
>> <SRS>EPSG:2023</SRS>
>> <SRS>EPSG:2024</SRS>
>> <SRS>EPSG:20248</SRS>
>> <SRS>EPSG:20249</SRS>
>> <SRS>EPSG:2025</SRS>
>> <SRS>EPSG:20250</SRS>
>> <SRS>EPSG:20251</SRS>
>> <SRS>EPSG:20252</SRS>
>> <SRS>EPSG:20253</SRS>
>> <SRS>EPSG:20254</SRS>
>> <SRS>EPSG:20255</SRS>
>> <SRS>EPSG:20256</SRS>
>> <SRS>EPSG:20257</SRS>
>> <SRS>EPSG:20258</SRS>
>> <SRS>EPSG:2026</SRS>
>> <SRS>EPSG:2027</SRS>
>> <SRS>EPSG:2028</SRS>
>> <SRS>EPSG:2029</SRS>
>> <SRS>EPSG:2030</SRS>
>> <SRS>EPSG:2031</SRS>
>> <SRS>EPSG:2032</SRS>
>> <SRS>EPSG:2033</SRS>
>> <SRS>EPSG:2034</SRS>
>> <SRS>EPSG:20348</SRS>
>> <SRS>EPSG:20349</SRS>
>> <SRS>EPSG:2035</SRS>
>> <SRS>EPSG:20350</SRS>
>> <SRS>EPSG:20351</SRS>
>> <SRS>EPSG:20352</SRS>
>> <SRS>EPSG:20353</SRS>
>> <SRS>EPSG:20354</SRS>
>> <SRS>EPSG:20355</SRS>
>> <SRS>EPSG:20356</SRS>
>> <SRS>EPSG:20357</SRS>
>> <SRS>EPSG:20358</SRS>
>> <SRS>EPSG:2036</SRS>
>> <SRS>EPSG:2037</SRS>
>> <SRS>EPSG:2038</SRS>
>> <SRS>EPSG:2039</SRS>
>> <SRS>EPSG:2040</SRS>
>> <SRS>EPSG:2041</SRS>
>> <SRS>EPSG:2042</SRS>
>> <SRS>EPSG:2043</SRS>
>> <SRS>EPSG:20437</SRS>
>> <SRS>EPSG:20438</SRS>
>> <SRS>EPSG:20439</SRS>
>> <SRS>EPSG:2044</SRS>
>> <SRS>EPSG:2045</SRS>
>> <SRS>EPSG:2046</SRS>
>> <SRS>EPSG:2047</SRS>
>> <SRS>EPSG:2048</SRS>
>> <SRS>EPSG:2049</SRS>
>> <SRS>EPSG:20499</SRS>
>> <SRS>EPSG:2050</SRS>
>> <SRS>EPSG:2051</SRS>
>> <SRS>EPSG:2052</SRS>
>> <SRS>EPSG:2053</SRS>
>> <SRS>EPSG:20538</SRS>
>> <SRS>EPSG:20539</SRS>
>> <SRS>EPSG:2054</SRS>
>> <SRS>EPSG:2055</SRS>
>> <SRS>EPSG:2056</SRS>
>> <SRS>EPSG:2057</SRS>
>> <SRS>EPSG:2058</SRS>
>> <SRS>EPSG:2059</SRS>
>> <SRS>EPSG:2060</SRS>
>> <SRS>EPSG:2061</SRS>
>> <SRS>EPSG:2062</SRS>
>> <SRS>EPSG:2063</SRS>
>> <SRS>EPSG:2064</SRS>
>> <SRS>EPSG:2065</SRS>
>> <SRS>EPSG:2066</SRS>
>> <SRS>EPSG:2067</SRS>
>> <SRS>EPSG:2068</SRS>
>> <SRS>EPSG:2069</SRS>
>> <SRS>EPSG:2070</SRS>
>> <SRS>EPSG:2071</SRS>
>> <SRS>EPSG:2072</SRS>
>> <SRS>EPSG:2073</SRS>
>> <SRS>EPSG:2074</SRS>
>> <SRS>EPSG:2075</SRS>
>> <SRS>EPSG:2076</SRS>
>> <SRS>EPSG:2077</SRS>
>> <SRS>EPSG:2078</SRS>
>> <SRS>EPSG:2079</SRS>
>> <SRS>EPSG:20790</SRS>
>> <SRS>EPSG:20791</SRS>
>> <SRS>EPSG:2080</SRS>
>> <SRS>EPSG:2081</SRS>
>> <SRS>EPSG:2082</SRS>
>> <SRS>EPSG:20822</SRS>
>> <SRS>EPSG:20823</SRS>
>> <SRS>EPSG:20824</SRS>
>> <SRS>EPSG:2083</SRS>
>> <SRS>EPSG:2084</SRS>
>> <SRS>EPSG:2085</SRS>
>> <SRS>EPSG:2086</SRS>
>> <SRS>EPSG:2087</SRS>
>> <SRS>EPSG:2088</SRS>
>> <SRS>EPSG:2089</SRS>
>> <SRS>EPSG:2090</SRS>
>> <SRS>EPSG:2091</SRS>
>> <SRS>EPSG:2092</SRS>
>> <SRS>EPSG:2093</SRS>
>> <SRS>EPSG:20934</SRS>
>> <SRS>EPSG:20935</SRS>
>> <SRS>EPSG:20936</SRS>
>> <SRS>EPSG:2094</SRS>
>> <SRS>EPSG:2095</SRS>
>> <SRS>EPSG:2096</SRS>
>> <SRS>EPSG:2097</SRS>
>> <SRS>EPSG:2098</SRS>
>> <SRS>EPSG:2099</SRS>
>> <SRS>EPSG:2100</SRS>
>> <SRS>EPSG:2101</SRS>
>> <SRS>EPSG:2102</SRS>
>> <SRS>EPSG:2103</SRS>
>> <SRS>EPSG:21035</SRS>
>> <SRS>EPSG:21036</SRS>
>> <SRS>EPSG:21037</SRS>
>> <SRS>EPSG:2104</SRS>
>> <SRS>EPSG:2105</SRS>
>> <SRS>EPSG:2106</SRS>
>> <SRS>EPSG:2107</SRS>
>> <SRS>EPSG:2108</SRS>
>> <SRS>EPSG:2109</SRS>
>> <SRS>EPSG:21095</SRS>
>> <SRS>EPSG:21096</SRS>
>> <SRS>EPSG:21097</SRS>
>> <SRS>EPSG:2110</SRS>
>> <SRS>EPSG:21100</SRS>
>> <SRS>EPSG:2111</SRS>
>> <SRS>EPSG:2112</SRS>
>> <SRS>EPSG:2113</SRS>
>> <SRS>EPSG:2114</SRS>
>> <SRS>EPSG:21148</SRS>
>> <SRS>EPSG:21149</SRS>
>> <SRS>EPSG:2115</SRS>
>> <SRS>EPSG:21150</SRS>
>> <SRS>EPSG:2116</SRS>
>> <SRS>EPSG:2117</SRS>
>> <SRS>EPSG:2118</SRS>
>> <SRS>EPSG:2119</SRS>
>> <SRS>EPSG:2120</SRS>
>> <SRS>EPSG:2121</SRS>
>> <SRS>EPSG:2122</SRS>
>> <SRS>EPSG:2123</SRS>
>> <SRS>EPSG:2124</SRS>
>> <SRS>EPSG:2125</SRS>
>> <SRS>EPSG:2126</SRS>
>> <SRS>EPSG:2127</SRS>
>> <SRS>EPSG:2128</SRS>
>> <SRS>EPSG:2129</SRS>
>> <SRS>EPSG:21291</SRS>
>> <SRS>EPSG:21292</SRS>
>> <SRS>EPSG:2130</SRS>
>> <SRS>EPSG:2131</SRS>
>> <SRS>EPSG:2132</SRS>
>> <SRS>EPSG:2133</SRS>
>> <SRS>EPSG:2134</SRS>
>> <SRS>EPSG:2135</SRS>
>> <SRS>EPSG:2136</SRS>
>> <SRS>EPSG:2137</SRS>
>> <SRS>EPSG:2138</SRS>
>> <SRS>EPSG:2139</SRS>
>> <SRS>EPSG:2140</SRS>
>> <SRS>EPSG:2141</SRS>
>> <SRS>EPSG:21413</SRS>
>> <SRS>EPSG:21414</SRS>
>> <SRS>EPSG:21415</SRS>
>> <SRS>EPSG:21416</SRS>
>> <SRS>EPSG:21417</SRS>
>> <SRS>EPSG:21418</SRS>
>> <SRS>EPSG:21419</SRS>
>> <SRS>EPSG:2142</SRS>
>> <SRS>EPSG:21420</SRS>
>> <SRS>EPSG:21421</SRS>
>> <SRS>EPSG:21422</SRS>
>> <SRS>EPSG:21423</SRS>
>> <SRS>EPSG:2143</SRS>
>> <SRS>EPSG:2144</SRS>
>> <SRS>EPSG:2145</SRS>
>> <SRS>EPSG:21453</SRS>
>> <SRS>EPSG:21454</SRS>
>> <SRS>EPSG:21455</SRS>
>> <SRS>EPSG:21456</SRS>
>> <SRS>EPSG:21457</SRS>
>> <SRS>EPSG:21458</SRS>
>> <SRS>EPSG:21459</SRS>
>> <SRS>EPSG:2146</SRS>
>> <SRS>EPSG:21460</SRS>
>> <SRS>EPSG:21461</SRS>
>> <SRS>EPSG:21462</SRS>
>> <SRS>EPSG:21463</SRS>
>> <SRS>EPSG:2147</SRS>
>> <SRS>EPSG:21473</SRS>
>> <SRS>EPSG:21474</SRS>
>> <SRS>EPSG:21475</SRS>
>> <SRS>EPSG:21476</SRS>
>> <SRS>EPSG:21477</SRS>
>> <SRS>EPSG:21478</SRS>
>> <SRS>EPSG:21479</SRS>
>> <SRS>EPSG:2148</SRS>
>> <SRS>EPSG:21480</SRS>
>> <SRS>EPSG:21481</SRS>
>> <SRS>EPSG:21482</SRS>
>> <SRS>EPSG:21483</SRS>
>> <SRS>EPSG:2149</SRS>
>> <SRS>EPSG:2150</SRS>
>> <SRS>EPSG:21500</SRS>
>> <SRS>EPSG:2151</SRS>
>> <SRS>EPSG:2152</SRS>
>> <SRS>EPSG:2153</SRS>
>> <SRS>EPSG:2154</SRS>
>> <SRS>EPSG:2155</SRS>
>> <SRS>EPSG:2156</SRS>
>> <SRS>EPSG:2157</SRS>
>> <SRS>EPSG:2158</SRS>
>> <SRS>EPSG:2159</SRS>
>> <SRS>EPSG:2160</SRS>
>> <SRS>EPSG:2161</SRS>
>> <SRS>EPSG:2162</SRS>
>> <SRS>EPSG:2163</SRS>
>> <SRS>EPSG:2164</SRS>
>> <SRS>EPSG:2165</SRS>
>> <SRS>EPSG:2166</SRS>
>> <SRS>EPSG:2167</SRS>
>> <SRS>EPSG:2168</SRS>
>> <SRS>EPSG:2169</SRS>
>> <SRS>EPSG:2170</SRS>
>> <SRS>EPSG:2171</SRS>
>> <SRS>EPSG:2172</SRS>
>> <SRS>EPSG:2173</SRS>
>> <SRS>EPSG:2174</SRS>
>> <SRS>EPSG:2175</SRS>
>> <SRS>EPSG:2176</SRS>
>> <SRS>EPSG:2177</SRS>
>> <SRS>EPSG:2178</SRS>
>> <SRS>EPSG:21780</SRS>
>> <SRS>EPSG:21781</SRS>
>> <SRS>EPSG:2179</SRS>
>> <SRS>EPSG:2180</SRS>
>> <SRS>EPSG:21817</SRS>
>> <SRS>EPSG:21818</SRS>
>> <SRS>EPSG:2188</SRS>
>> <SRS>EPSG:2189</SRS>
>> <SRS>EPSG:21891</SRS>
>> <SRS>EPSG:21892</SRS>
>> <SRS>EPSG:21893</SRS>
>> <SRS>EPSG:21894</SRS>
>> <SRS>EPSG:2190</SRS>
>> <SRS>EPSG:2191</SRS>
>> <SRS>EPSG:2192</SRS>
>> <SRS>EPSG:2193</SRS>
>> <SRS>EPSG:2194</SRS>
>> <SRS>EPSG:2195</SRS>
>> <SRS>EPSG:2196</SRS>
>> <SRS>EPSG:2197</SRS>
>> <SRS>EPSG:2198</SRS>
>> <SRS>EPSG:2199</SRS>
>> <SRS>EPSG:2200</SRS>
>> <SRS>EPSG:2201</SRS>
>> <SRS>EPSG:2202</SRS>
>> <SRS>EPSG:2203</SRS>
>> <SRS>EPSG:22032</SRS>
>> <SRS>EPSG:22033</SRS>
>> <SRS>EPSG:2204</SRS>
>> <SRS>EPSG:2205</SRS>
>> <SRS>EPSG:2206</SRS>
>> <SRS>EPSG:2207</SRS>
>> <SRS>EPSG:2208</SRS>
>> <SRS>EPSG:2209</SRS>
>> <SRS>EPSG:22091</SRS>
>> <SRS>EPSG:22092</SRS>
>> <SRS>EPSG:2210</SRS>
>> <SRS>EPSG:2211</SRS>
>> <SRS>EPSG:2212</SRS>
>> <SRS>EPSG:2213</SRS>
>> <SRS>EPSG:2214</SRS>
>> <SRS>EPSG:2215</SRS>
>> <SRS>EPSG:2216</SRS>
>> <SRS>EPSG:2217</SRS>
>> <SRS>EPSG:2219</SRS>
>> <SRS>EPSG:22191</SRS>
>> <SRS>EPSG:22192</SRS>
>> <SRS>EPSG:22193</SRS>
>> <SRS>EPSG:22194</SRS>
>> <SRS>EPSG:22195</SRS>
>> <SRS>EPSG:22196</SRS>
>> <SRS>EPSG:22197</SRS>
>> <SRS>EPSG:2220</SRS>
>> <SRS>EPSG:2222</SRS>
>> <SRS>EPSG:2223</SRS>
>> <SRS>EPSG:22234</SRS>
>> <SRS>EPSG:22235</SRS>
>> <SRS>EPSG:22236</SRS>
>> <SRS>EPSG:2224</SRS>
>> <SRS>EPSG:2225</SRS>
>> <SRS>EPSG:2226</SRS>
>> <SRS>EPSG:2227</SRS>
>> <SRS>EPSG:22275</SRS>
>> <SRS>EPSG:22277</SRS>
>> <SRS>EPSG:22279</SRS>
>> <SRS>EPSG:2228</SRS>
>> <SRS>EPSG:22281</SRS>
>> <SRS>EPSG:22283</SRS>
>> <SRS>EPSG:22285</SRS>
>> <SRS>EPSG:22287</SRS>
>> <SRS>EPSG:22289</SRS>
>> <SRS>EPSG:2229</SRS>
>> <SRS>EPSG:22291</SRS>
>> <SRS>EPSG:22293</SRS>
>> <SRS>EPSG:2230</SRS>
>> <SRS>EPSG:22300</SRS>
>> <SRS>EPSG:2231</SRS>
>> <SRS>EPSG:2232</SRS>
>> <SRS>EPSG:2233</SRS>
>> <SRS>EPSG:22332</SRS>
>> <SRS>EPSG:2234</SRS>
>> <SRS>EPSG:2235</SRS>
>> <SRS>EPSG:2236</SRS>
>> <SRS>EPSG:2237</SRS>
>> <SRS>EPSG:2238</SRS>
>> <SRS>EPSG:2239</SRS>
>> <SRS>EPSG:22391</SRS>
>> <SRS>EPSG:22392</SRS>
>> <SRS>EPSG:2240</SRS>
>> <SRS>EPSG:2241</SRS>
>> <SRS>EPSG:2242</SRS>
>> <SRS>EPSG:2243</SRS>
>> <SRS>EPSG:2244</SRS>
>> <SRS>EPSG:2245</SRS>
>> <SRS>EPSG:2246</SRS>
>> <SRS>EPSG:2247</SRS>
>> <SRS>EPSG:2248</SRS>
>> <SRS>EPSG:2249</SRS>
>> <SRS>EPSG:2250</SRS>
>> <SRS>EPSG:2251</SRS>
>> <SRS>EPSG:2252</SRS>
>> <SRS>EPSG:22523</SRS>
>> <SRS>EPSG:22524</SRS>
>> <SRS>EPSG:2253</SRS>
>> <SRS>EPSG:2254</SRS>
>> <SRS>EPSG:2255</SRS>
>> <SRS>EPSG:2256</SRS>
>> <SRS>EPSG:2257</SRS>
>> <SRS>EPSG:2258</SRS>
>> <SRS>EPSG:2259</SRS>
>> <SRS>EPSG:2260</SRS>
>> <SRS>EPSG:2261</SRS>
>> <SRS>EPSG:2262</SRS>
>> <SRS>EPSG:2263</SRS>
>> <SRS>EPSG:2264</SRS>
>> <SRS>EPSG:2265</SRS>
>> <SRS>EPSG:2266</SRS>
>> <SRS>EPSG:2267</SRS>
>> <SRS>EPSG:2268</SRS>
>> <SRS>EPSG:2269</SRS>
>> <SRS>EPSG:2270</SRS>
>> <SRS>EPSG:22700</SRS>
>> <SRS>EPSG:2271</SRS>
>> <SRS>EPSG:2272</SRS>
>> <SRS>EPSG:2273</SRS>
>> <SRS>EPSG:2274</SRS>
>> <SRS>EPSG:2275</SRS>
>> <SRS>EPSG:2276</SRS>
>> <SRS>EPSG:2277</SRS>
>> <SRS>EPSG:22770</SRS>
>> <SRS>EPSG:2278</SRS>
>> <SRS>EPSG:22780</SRS>
>> <SRS>EPSG:2279</SRS>
>> <SRS>EPSG:2280</SRS>
>> <SRS>EPSG:2281</SRS>
>> <SRS>EPSG:2282</SRS>
>> <SRS>EPSG:2283</SRS>
>> <SRS>EPSG:22832</SRS>
>> <SRS>EPSG:2284</SRS>
>> <SRS>EPSG:2285</SRS>
>> <SRS>EPSG:2286</SRS>
>> <SRS>EPSG:2287</SRS>
>> <SRS>EPSG:2288</SRS>
>> <SRS>EPSG:2289</SRS>
>> <SRS>EPSG:2290</SRS>
>> <SRS>EPSG:2291</SRS>
>> <SRS>EPSG:2292</SRS>
>> <SRS>EPSG:2294</SRS>
>> <SRS>EPSG:2295</SRS>
>> <SRS>EPSG:22991</SRS>
>> <SRS>EPSG:22992</SRS>
>> <SRS>EPSG:22993</SRS>
>> <SRS>EPSG:22994</SRS>
>> <SRS>EPSG:23028</SRS>
>> <SRS>EPSG:23029</SRS>
>> <SRS>EPSG:23030</SRS>
>> <SRS>EPSG:23031</SRS>
>> <SRS>EPSG:23032</SRS>
>> <SRS>EPSG:23033</SRS>
>> <SRS>EPSG:23034</SRS>
>> <SRS>EPSG:23035</SRS>
>> <SRS>EPSG:23036</SRS>
>> <SRS>EPSG:23037</SRS>
>> <SRS>EPSG:23038</SRS>
>> <SRS>EPSG:2308</SRS>
>> <SRS>EPSG:2309</SRS>
>> <SRS>EPSG:23090</SRS>
>> <SRS>EPSG:23095</SRS>
>> <SRS>EPSG:2310</SRS>
>> <SRS>EPSG:2311</SRS>
>> <SRS>EPSG:2312</SRS>
>> <SRS>EPSG:2313</SRS>
>> <SRS>EPSG:2314</SRS>
>> <SRS>EPSG:2315</SRS>
>> <SRS>EPSG:2316</SRS>
>> <SRS>EPSG:2317</SRS>
>> <SRS>EPSG:2318</SRS>
>> <SRS>EPSG:2319</SRS>
>> <SRS>EPSG:2320</SRS>
>> <SRS>EPSG:2321</SRS>
>> <SRS>EPSG:2322</SRS>
>> <SRS>EPSG:2323</SRS>
>> <SRS>EPSG:23239</SRS>
>> <SRS>EPSG:2324</SRS>
>> <SRS>EPSG:23240</SRS>
>> <SRS>EPSG:2325</SRS>
>> <SRS>EPSG:2326</SRS>
>> <SRS>EPSG:2327</SRS>
>> <SRS>EPSG:2328</SRS>
>> <SRS>EPSG:2329</SRS>
>> <SRS>EPSG:2330</SRS>
>> <SRS>EPSG:2331</SRS>
>> <SRS>EPSG:2332</SRS>
>> <SRS>EPSG:2333</SRS>
>> <SRS>EPSG:2334</SRS>
>> <SRS>EPSG:2335</SRS>
>> <SRS>EPSG:2336</SRS>
>> <SRS>EPSG:2337</SRS>
>> <SRS>EPSG:2338</SRS>
>> <SRS>EPSG:2339</SRS>
>> <SRS>EPSG:2340</SRS>
>> <SRS>EPSG:2341</SRS>
>> <SRS>EPSG:2342</SRS>
>> <SRS>EPSG:2343</SRS>
>> <SRS>EPSG:23433</SRS>
>> <SRS>EPSG:2344</SRS>
>> <SRS>EPSG:2345</SRS>
>> <SRS>EPSG:2346</SRS>
>> <SRS>EPSG:2347</SRS>
>> <SRS>EPSG:2348</SRS>
>> <SRS>EPSG:2349</SRS>
>> <SRS>EPSG:2350</SRS>
>> <SRS>EPSG:2351</SRS>
>> <SRS>EPSG:2352</SRS>
>> <SRS>EPSG:2353</SRS>
>> <SRS>EPSG:2354</SRS>
>> <SRS>EPSG:2355</SRS>
>> <SRS>EPSG:2356</SRS>
>> <SRS>EPSG:2357</SRS>
>> <SRS>EPSG:2358</SRS>
>> <SRS>EPSG:2359</SRS>
>> <SRS>EPSG:2360</SRS>
>> <SRS>EPSG:2361</SRS>
>> <SRS>EPSG:2362</SRS>
>> <SRS>EPSG:2363</SRS>
>> <SRS>EPSG:2364</SRS>
>> <SRS>EPSG:2365</SRS>
>> <SRS>EPSG:2366</SRS>
>> <SRS>EPSG:2367</SRS>
>> <SRS>EPSG:2368</SRS>
>> <SRS>EPSG:2369</SRS>
>> <SRS>EPSG:2370</SRS>
>> <SRS>EPSG:23700</SRS>
>> <SRS>EPSG:2371</SRS>
>> <SRS>EPSG:2372</SRS>
>> <SRS>EPSG:2373</SRS>
>> <SRS>EPSG:2374</SRS>
>> <SRS>EPSG:2375</SRS>
>> <SRS>EPSG:2376</SRS>
>> <SRS>EPSG:2377</SRS>
>> <SRS>EPSG:2378</SRS>
>> <SRS>EPSG:2379</SRS>
>> <SRS>EPSG:2380</SRS>
>> <SRS>EPSG:2381</SRS>
>> <SRS>EPSG:2382</SRS>
>> <SRS>EPSG:2383</SRS>
>> <SRS>EPSG:2384</SRS>
>> <SRS>EPSG:23846</SRS>
>> <SRS>EPSG:23847</SRS>
>> <SRS>EPSG:23848</SRS>
>> <SRS>EPSG:23849</SRS>
>> <SRS>EPSG:2385</SRS>
>> <SRS>EPSG:23850</SRS>
>> <SRS>EPSG:23851</SRS>
>> <SRS>EPSG:23852</SRS>
>> <SRS>EPSG:23853</SRS>
>> <SRS>EPSG:2386</SRS>
>> <SRS>EPSG:2387</SRS>
>> <SRS>EPSG:2388</SRS>
>> <SRS>EPSG:23886</SRS>
>> <SRS>EPSG:23887</SRS>
>> <SRS>EPSG:23888</SRS>
>> <SRS>EPSG:23889</SRS>
>> <SRS>EPSG:2389</SRS>
>> <SRS>EPSG:23890</SRS>
>> <SRS>EPSG:23891</SRS>
>> <SRS>EPSG:23892</SRS>
>> <SRS>EPSG:23893</SRS>
>> <SRS>EPSG:23894</SRS>
>> <SRS>EPSG:2390</SRS>
>> <SRS>EPSG:2391</SRS>
>> <SRS>EPSG:2392</SRS>
>> <SRS>EPSG:2393</SRS>
>> <SRS>EPSG:2394</SRS>
>> <SRS>EPSG:23946</SRS>
>> <SRS>EPSG:23947</SRS>
>> <SRS>EPSG:23948</SRS>
>> <SRS>EPSG:2395</SRS>
>> <SRS>EPSG:2396</SRS>
>> <SRS>EPSG:2397</SRS>
>> <SRS>EPSG:2398</SRS>
>> <SRS>EPSG:2399</SRS>
>> <SRS>EPSG:2400</SRS>
>> <SRS>EPSG:2401</SRS>
>> <SRS>EPSG:2402</SRS>
>> <SRS>EPSG:2403</SRS>
>> <SRS>EPSG:2404</SRS>
>> <SRS>EPSG:24047</SRS>
>> <SRS>EPSG:24048</SRS>
>> <SRS>EPSG:2405</SRS>
>> <SRS>EPSG:2406</SRS>
>> <SRS>EPSG:2407</SRS>
>> <SRS>EPSG:2408</SRS>
>> <SRS>EPSG:2409</SRS>
>> <SRS>EPSG:2410</SRS>
>> <SRS>EPSG:24100</SRS>
>> <SRS>EPSG:2411</SRS>
>> <SRS>EPSG:2412</SRS>
>> <SRS>EPSG:2413</SRS>
>> <SRS>EPSG:2414</SRS>
>> <SRS>EPSG:2415</SRS>
>> <SRS>EPSG:2416</SRS>
>> <SRS>EPSG:2417</SRS>
>> <SRS>EPSG:2418</SRS>
>> <SRS>EPSG:2419</SRS>
>> <SRS>EPSG:2420</SRS>
>> <SRS>EPSG:24200</SRS>
>> <SRS>EPSG:2421</SRS>
>> <SRS>EPSG:2422</SRS>
>> <SRS>EPSG:2423</SRS>
>> <SRS>EPSG:2424</SRS>
>> <SRS>EPSG:2425</SRS>
>> <SRS>EPSG:2426</SRS>
>> <SRS>EPSG:2427</SRS>
>> <SRS>EPSG:2428</SRS>
>> <SRS>EPSG:2429</SRS>
>> <SRS>EPSG:2430</SRS>
>> <SRS>EPSG:24305</SRS>
>> <SRS>EPSG:24306</SRS>
>> <SRS>EPSG:2431</SRS>
>> <SRS>EPSG:24311</SRS>
>> <SRS>EPSG:24312</SRS>
>> <SRS>EPSG:24313</SRS>
>> <SRS>EPSG:2432</SRS>
>> <SRS>EPSG:2433</SRS>
>> <SRS>EPSG:2434</SRS>
>> <SRS>EPSG:24342</SRS>
>> <SRS>EPSG:24343</SRS>
>> <SRS>EPSG:24344</SRS>
>> <SRS>EPSG:24345</SRS>
>> <SRS>EPSG:24346</SRS>
>> <SRS>EPSG:24347</SRS>
>> <SRS>EPSG:2435</SRS>
>> <SRS>EPSG:2436</SRS>
>> <SRS>EPSG:2437</SRS>
>> <SRS>EPSG:24370</SRS>
>> <SRS>EPSG:24371</SRS>
>> <SRS>EPSG:24372</SRS>
>> <SRS>EPSG:24373</SRS>
>> <SRS>EPSG:24374</SRS>
>> <SRS>EPSG:24375</SRS>
>> <SRS>EPSG:24376</SRS>
>> <SRS>EPSG:24377</SRS>
>> <SRS>EPSG:24378</SRS>
>> <SRS>EPSG:24379</SRS>
>> <SRS>EPSG:2438</SRS>
>> <SRS>EPSG:24380</SRS>
>> <SRS>EPSG:24381</SRS>
>> <SRS>EPSG:24382</SRS>
>> <SRS>EPSG:24383</SRS>
>> <SRS>EPSG:2439</SRS>
>> <SRS>EPSG:2440</SRS>
>> <SRS>EPSG:2441</SRS>
>> <SRS>EPSG:2442</SRS>
>> <SRS>EPSG:2443</SRS>
>> <SRS>EPSG:2444</SRS>
>> <SRS>EPSG:2445</SRS>
>> <SRS>EPSG:2446</SRS>
>> <SRS>EPSG:2447</SRS>
>> <SRS>EPSG:2448</SRS>
>> <SRS>EPSG:2449</SRS>
>> <SRS>EPSG:2450</SRS>
>> <SRS>EPSG:24500</SRS>
>> <SRS>EPSG:2451</SRS>
>> <SRS>EPSG:2452</SRS>
>> <SRS>EPSG:2453</SRS>
>> <SRS>EPSG:2454</SRS>
>> <SRS>EPSG:24547</SRS>
>> <SRS>EPSG:24548</SRS>
>> <SRS>EPSG:2455</SRS>
>> <SRS>EPSG:2456</SRS>
>> <SRS>EPSG:2457</SRS>
>> <SRS>EPSG:24571</SRS>
>> <SRS>EPSG:2458</SRS>
>> <SRS>EPSG:2459</SRS>
>> <SRS>EPSG:2460</SRS>
>> <SRS>EPSG:24600</SRS>
>> <SRS>EPSG:2461</SRS>
>> <SRS>EPSG:2462</SRS>
>> <SRS>EPSG:2463</SRS>
>> <SRS>EPSG:2464</SRS>
>> <SRS>EPSG:2465</SRS>
>> <SRS>EPSG:2466</SRS>
>> <SRS>EPSG:2467</SRS>
>> <SRS>EPSG:2468</SRS>
>> <SRS>EPSG:2469</SRS>
>> <SRS>EPSG:2470</SRS>
>> <SRS>EPSG:2471</SRS>
>> <SRS>EPSG:24718</SRS>
>> <SRS>EPSG:24719</SRS>
>> <SRS>EPSG:2472</SRS>
>> <SRS>EPSG:24720</SRS>
>> <SRS>EPSG:2473</SRS>
>> <SRS>EPSG:2474</SRS>
>> <SRS>EPSG:2475</SRS>
>> <SRS>EPSG:2476</SRS>
>> <SRS>EPSG:2477</SRS>
>> <SRS>EPSG:2478</SRS>
>> <SRS>EPSG:2479</SRS>
>> <SRS>EPSG:2480</SRS>
>> <SRS>EPSG:2481</SRS>
>> <SRS>EPSG:24818</SRS>
>> <SRS>EPSG:24819</SRS>
>> <SRS>EPSG:2482</SRS>
>> <SRS>EPSG:24820</SRS>
>> <SRS>EPSG:24821</SRS>
>> <SRS>EPSG:2483</SRS>
>> <SRS>EPSG:2484</SRS>
>> <SRS>EPSG:2485</SRS>
>> <SRS>EPSG:2486</SRS>
>> <SRS>EPSG:2487</SRS>
>> <SRS>EPSG:24877</SRS>
>> <SRS>EPSG:24878</SRS>
>> <SRS>EPSG:24879</SRS>
>> <SRS>EPSG:2488</SRS>
>> <SRS>EPSG:24880</SRS>
>> <SRS>EPSG:24882</SRS>
>> <SRS>EPSG:2489</SRS>
>> <SRS>EPSG:24891</SRS>
>> <SRS>EPSG:24892</SRS>
>> <SRS>EPSG:24893</SRS>
>> <SRS>EPSG:2490</SRS>
>> <SRS>EPSG:2491</SRS>
>> <SRS>EPSG:2492</SRS>
>> <SRS>EPSG:2493</SRS>
>> <SRS>EPSG:2494</SRS>
>> <SRS>EPSG:2495</SRS>
>> <SRS>EPSG:2496</SRS>
>> <SRS>EPSG:2497</SRS>
>> <SRS>EPSG:2498</SRS>
>> <SRS>EPSG:2499</SRS>
>> <SRS>EPSG:2500</SRS>
>> <SRS>EPSG:25000</SRS>
>> <SRS>EPSG:2501</SRS>
>> <SRS>EPSG:2502</SRS>
>> <SRS>EPSG:2503</SRS>
>> <SRS>EPSG:2504</SRS>
>> <SRS>EPSG:2505</SRS>
>> <SRS>EPSG:2506</SRS>
>> <SRS>EPSG:2507</SRS>
>> <SRS>EPSG:2508</SRS>
>> <SRS>EPSG:2509</SRS>
>> <SRS>EPSG:2510</SRS>
>> <SRS>EPSG:2511</SRS>
>> <SRS>EPSG:2512</SRS>
>> <SRS>EPSG:2513</SRS>
>> <SRS>EPSG:2514</SRS>
>> <SRS>EPSG:2515</SRS>
>> <SRS>EPSG:2516</SRS>
>> <SRS>EPSG:2517</SRS>
>> <SRS>EPSG:2518</SRS>
>> <SRS>EPSG:2519</SRS>
>> <SRS>EPSG:2520</SRS>
>> <SRS>EPSG:2521</SRS>
>> <SRS>EPSG:2522</SRS>
>> <SRS>EPSG:2523</SRS>
>> <SRS>EPSG:25231</SRS>
>> <SRS>EPSG:2524</SRS>
>> <SRS>EPSG:2525</SRS>
>> <SRS>EPSG:2526</SRS>
>> <SRS>EPSG:2527</SRS>
>> <SRS>EPSG:2528</SRS>
>> <SRS>EPSG:2529</SRS>
>> <SRS>EPSG:2530</SRS>
>> <SRS>EPSG:2531</SRS>
>> <SRS>EPSG:2532</SRS>
>> <SRS>EPSG:2533</SRS>
>> <SRS>EPSG:2534</SRS>
>> <SRS>EPSG:2535</SRS>
>> <SRS>EPSG:2536</SRS>
>> <SRS>EPSG:2537</SRS>
>> <SRS>EPSG:2538</SRS>
>> <SRS>EPSG:2539</SRS>
>> <SRS>EPSG:25391</SRS>
>> <SRS>EPSG:25392</SRS>
>> <SRS>EPSG:25393</SRS>
>> <SRS>EPSG:25394</SRS>
>> <SRS>EPSG:25395</SRS>
>> <SRS>EPSG:2540</SRS>
>> <SRS>EPSG:2541</SRS>
>> <SRS>EPSG:2542</SRS>
>> <SRS>EPSG:2543</SRS>
>> <SRS>EPSG:2544</SRS>
>> <SRS>EPSG:2545</SRS>
>> <SRS>EPSG:2546</SRS>
>> <SRS>EPSG:2547</SRS>
>> <SRS>EPSG:2548</SRS>
>> <SRS>EPSG:2549</SRS>
>> <SRS>EPSG:2550</SRS>
>> <SRS>EPSG:2551</SRS>
>> <SRS>EPSG:2552</SRS>
>> <SRS>EPSG:2553</SRS>
>> <SRS>EPSG:2554</SRS>
>> <SRS>EPSG:2555</SRS>
>> <SRS>EPSG:2556</SRS>
>> <SRS>EPSG:2557</SRS>
>> <SRS>EPSG:2558</SRS>
>> <SRS>EPSG:2559</SRS>
>> <SRS>EPSG:2560</SRS>
>> <SRS>EPSG:2561</SRS>
>> <SRS>EPSG:2562</SRS>
>> <SRS>EPSG:2563</SRS>
>> <SRS>EPSG:2564</SRS>
>> <SRS>EPSG:2565</SRS>
>> <SRS>EPSG:2566</SRS>
>> <SRS>EPSG:2567</SRS>
>> <SRS>EPSG:2568</SRS>
>> <SRS>EPSG:2569</SRS>
>> <SRS>EPSG:2570</SRS>
>> <SRS>EPSG:25700</SRS>
>> <SRS>EPSG:2571</SRS>
>> <SRS>EPSG:2572</SRS>
>> <SRS>EPSG:2573</SRS>
>> <SRS>EPSG:2574</SRS>
>> <SRS>EPSG:2575</SRS>
>> <SRS>EPSG:2576</SRS>
>> <SRS>EPSG:2577</SRS>
>> <SRS>EPSG:2578</SRS>
>> <SRS>EPSG:2579</SRS>
>> <SRS>EPSG:2580</SRS>
>> <SRS>EPSG:2581</SRS>
>> <SRS>EPSG:2582</SRS>
>> <SRS>EPSG:25828</SRS>
>> <SRS>EPSG:25829</SRS>
>> <SRS>EPSG:2583</SRS>
>> <SRS>EPSG:25830</SRS>
>> <SRS>EPSG:25831</SRS>
>> <SRS>EPSG:25832</SRS>
>> <SRS>EPSG:25833</SRS>
>> <SRS>EPSG:25834</SRS>
>> <SRS>EPSG:25835</SRS>
>> <SRS>EPSG:25836</SRS>
>> <SRS>EPSG:25837</SRS>
>> <SRS>EPSG:25838</SRS>
>> <SRS>EPSG:2584</SRS>
>> <SRS>EPSG:2585</SRS>
>> <SRS>EPSG:2586</SRS>
>> <SRS>EPSG:2587</SRS>
>> <SRS>EPSG:2588</SRS>
>> <SRS>EPSG:25884</SRS>
>> <SRS>EPSG:2589</SRS>
>> <SRS>EPSG:2590</SRS>
>> <SRS>EPSG:2591</SRS>
>> <SRS>EPSG:2592</SRS>
>> <SRS>EPSG:2593</SRS>
>> <SRS>EPSG:25932</SRS>
>> <SRS>EPSG:2594</SRS>
>> <SRS>EPSG:2595</SRS>
>> <SRS>EPSG:2596</SRS>
>> <SRS>EPSG:2597</SRS>
>> <SRS>EPSG:2598</SRS>
>> <SRS>EPSG:2599</SRS>
>> <SRS>EPSG:2600</SRS>
>> <SRS>EPSG:2601</SRS>
>> <SRS>EPSG:2602</SRS>
>> <SRS>EPSG:2603</SRS>
>> <SRS>EPSG:2604</SRS>
>> <SRS>EPSG:2605</SRS>
>> <SRS>EPSG:2606</SRS>
>> <SRS>EPSG:2607</SRS>
>> <SRS>EPSG:2608</SRS>
>> <SRS>EPSG:2609</SRS>
>> <SRS>EPSG:2610</SRS>
>> <SRS>EPSG:2611</SRS>
>> <SRS>EPSG:2612</SRS>
>> <SRS>EPSG:2613</SRS>
>> <SRS>EPSG:2614</SRS>
>> <SRS>EPSG:2615</SRS>
>> <SRS>EPSG:2616</SRS>
>> <SRS>EPSG:2617</SRS>
>> <SRS>EPSG:2618</SRS>
>> <SRS>EPSG:2619</SRS>
>> <SRS>EPSG:26191</SRS>
>> <SRS>EPSG:26192</SRS>
>> <SRS>EPSG:26193</SRS>
>> <SRS>EPSG:26194</SRS>
>> <SRS>EPSG:26195</SRS>
>> <SRS>EPSG:2620</SRS>
>> <SRS>EPSG:2621</SRS>
>> <SRS>EPSG:2622</SRS>
>> <SRS>EPSG:2623</SRS>
>> <SRS>EPSG:26237</SRS>
>> <SRS>EPSG:2624</SRS>
>> <SRS>EPSG:2625</SRS>
>> <SRS>EPSG:2626</SRS>
>> <SRS>EPSG:2627</SRS>
>> <SRS>EPSG:2628</SRS>
>> <SRS>EPSG:2629</SRS>
>> <SRS>EPSG:2630</SRS>
>> <SRS>EPSG:2631</SRS>
>> <SRS>EPSG:2632</SRS>
>> <SRS>EPSG:2633</SRS>
>> <SRS>EPSG:26331</SRS>
>> <SRS>EPSG:26332</SRS>
>> <SRS>EPSG:2634</SRS>
>> <SRS>EPSG:2635</SRS>
>> <SRS>EPSG:2636</SRS>
>> <SRS>EPSG:2637</SRS>
>> <SRS>EPSG:2638</SRS>
>> <SRS>EPSG:2639</SRS>
>> <SRS>EPSG:26391</SRS>
>> <SRS>EPSG:26392</SRS>
>> <SRS>EPSG:26393</SRS>
>> <SRS>EPSG:2640</SRS>
>> <SRS>EPSG:2641</SRS>
>> <SRS>EPSG:2642</SRS>
>> <SRS>EPSG:2643</SRS>
>> <SRS>EPSG:26432</SRS>
>> <SRS>EPSG:2644</SRS>
>> <SRS>EPSG:2645</SRS>
>> <SRS>EPSG:2646</SRS>
>> <SRS>EPSG:2647</SRS>
>> <SRS>EPSG:2648</SRS>
>> <SRS>EPSG:2649</SRS>
>> <SRS>EPSG:2650</SRS>
>> <SRS>EPSG:2651</SRS>
>> <SRS>EPSG:2652</SRS>
>> <SRS>EPSG:2653</SRS>
>> <SRS>EPSG:2654</SRS>
>> <SRS>EPSG:2655</SRS>
>> <SRS>EPSG:2656</SRS>
>> <SRS>EPSG:2657</SRS>
>> <SRS>EPSG:2658</SRS>
>> <SRS>EPSG:2659</SRS>
>> <SRS>EPSG:26591</SRS>
>> <SRS>EPSG:26592</SRS>
>> <SRS>EPSG:2660</SRS>
>> <SRS>EPSG:2661</SRS>
>> <SRS>EPSG:2662</SRS>
>> <SRS>EPSG:2663</SRS>
>> <SRS>EPSG:26632</SRS>
>> <SRS>EPSG:2664</SRS>
>> <SRS>EPSG:2665</SRS>
>> <SRS>EPSG:2666</SRS>
>> <SRS>EPSG:2667</SRS>
>> <SRS>EPSG:2668</SRS>
>> <SRS>EPSG:2669</SRS>
>> <SRS>EPSG:26692</SRS>
>> <SRS>EPSG:2670</SRS>
>> <SRS>EPSG:26703</SRS>
>> <SRS>EPSG:26704</SRS>
>> <SRS>EPSG:26705</SRS>
>> <SRS>EPSG:26706</SRS>
>> <SRS>EPSG:26707</SRS>
>> <SRS>EPSG:26708</SRS>
>> <SRS>EPSG:26709</SRS>
>> <SRS>EPSG:2671</SRS>
>> <SRS>EPSG:26710</SRS>
>> <SRS>EPSG:26711</SRS>
>> <SRS>EPSG:26712</SRS>
>> <SRS>EPSG:26713</SRS>
>> <SRS>EPSG:26714</SRS>
>> <SRS>EPSG:26715</SRS>
>> <SRS>EPSG:26716</SRS>
>> <SRS>EPSG:26717</SRS>
>> <SRS>EPSG:26718</SRS>
>> <SRS>EPSG:26719</SRS>
>> <SRS>EPSG:2672</SRS>
>> <SRS>EPSG:26720</SRS>
>> <SRS>EPSG:26721</SRS>
>> <SRS>EPSG:26722</SRS>
>> <SRS>EPSG:26729</SRS>
>> <SRS>EPSG:2673</SRS>
>> <SRS>EPSG:26730</SRS>
>> <SRS>EPSG:26731</SRS>
>> <SRS>EPSG:26732</SRS>
>> <SRS>EPSG:26733</SRS>
>> <SRS>EPSG:26734</SRS>
>> <SRS>EPSG:26735</SRS>
>> <SRS>EPSG:26736</SRS>
>> <SRS>EPSG:26737</SRS>
>> <SRS>EPSG:26738</SRS>
>> <SRS>EPSG:26739</SRS>
>> <SRS>EPSG:2674</SRS>
>> <SRS>EPSG:26740</SRS>
>> <SRS>EPSG:26741</SRS>
>> <SRS>EPSG:26742</SRS>
>> <SRS>EPSG:26743</SRS>
>> <SRS>EPSG:26744</SRS>
>> <SRS>EPSG:26745</SRS>
>> <SRS>EPSG:26746</SRS>
>> <SRS>EPSG:26747</SRS>
>> <SRS>EPSG:26748</SRS>
>> <SRS>EPSG:26749</SRS>
>> <SRS>EPSG:2675</SRS>
>> <SRS>EPSG:26750</SRS>
>> <SRS>EPSG:26751</SRS>
>> <SRS>EPSG:26752</SRS>
>> <SRS>EPSG:26753</SRS>
>> <SRS>EPSG:26754</SRS>
>> <SRS>EPSG:26755</SRS>
>> <SRS>EPSG:26756</SRS>
>> <SRS>EPSG:26757</SRS>
>> <SRS>EPSG:26758</SRS>
>> <SRS>EPSG:26759</SRS>
>> <SRS>EPSG:2676</SRS>
>> <SRS>EPSG:26760</SRS>
>> <SRS>EPSG:26766</SRS>
>> <SRS>EPSG:26767</SRS>
>> <SRS>EPSG:26768</SRS>
>> <SRS>EPSG:26769</SRS>
>> <SRS>EPSG:2677</SRS>
>> <SRS>EPSG:26770</SRS>
>> <SRS>EPSG:26771</SRS>
>> <SRS>EPSG:26772</SRS>
>> <SRS>EPSG:26773</SRS>
>> <SRS>EPSG:26774</SRS>
>> <SRS>EPSG:26775</SRS>
>> <SRS>EPSG:26776</SRS>
>> <SRS>EPSG:26777</SRS>
>> <SRS>EPSG:26778</SRS>
>> <SRS>EPSG:26779</SRS>
>> <SRS>EPSG:2678</SRS>
>> <SRS>EPSG:26780</SRS>
>> <SRS>EPSG:26781</SRS>
>> <SRS>EPSG:26782</SRS>
>> <SRS>EPSG:26783</SRS>
>> <SRS>EPSG:26784</SRS>
>> <SRS>EPSG:26785</SRS>
>> <SRS>EPSG:26786</SRS>
>> <SRS>EPSG:26787</SRS>
>> <SRS>EPSG:2679</SRS>
>> <SRS>EPSG:26791</SRS>
>> <SRS>EPSG:26792</SRS>
>> <SRS>EPSG:26793</SRS>
>> <SRS>EPSG:26794</SRS>
>> <SRS>EPSG:26795</SRS>
>> <SRS>EPSG:26796</SRS>
>> <SRS>EPSG:26797</SRS>
>> <SRS>EPSG:26798</SRS>
>> <SRS>EPSG:2680</SRS>
>> <SRS>EPSG:26801</SRS>
>> <SRS>EPSG:26802</SRS>
>> <SRS>EPSG:26803</SRS>
>> <SRS>EPSG:2681</SRS>
>> <SRS>EPSG:26811</SRS>
>> <SRS>EPSG:26812</SRS>
>> <SRS>EPSG:26813</SRS>
>> <SRS>EPSG:2682</SRS>
>> <SRS>EPSG:2683</SRS>
>> <SRS>EPSG:2684</SRS>
>> <SRS>EPSG:2685</SRS>
>> <SRS>EPSG:2686</SRS>
>> <SRS>EPSG:2687</SRS>
>> <SRS>EPSG:2688</SRS>
>> <SRS>EPSG:2689</SRS>
>> <SRS>EPSG:2690</SRS>
>> <SRS>EPSG:26903</SRS>
>> <SRS>EPSG:26904</SRS>
>> <SRS>EPSG:26905</SRS>
>> <SRS>EPSG:26906</SRS>
>> <SRS>EPSG:26907</SRS>
>> <SRS>EPSG:26908</SRS>
>> <SRS>EPSG:26909</SRS>
>> <SRS>EPSG:2691</SRS>
>> <SRS>EPSG:26910</SRS>
>> <SRS>EPSG:26911</SRS>
>> <SRS>EPSG:26912</SRS>
>> <SRS>EPSG:26913</SRS>
>> <SRS>EPSG:26914</SRS>
>> <SRS>EPSG:26915</SRS>
>> <SRS>EPSG:26916</SRS>
>> <SRS>EPSG:26917</SRS>
>> <SRS>EPSG:26918</SRS>
>> <SRS>EPSG:26919</SRS>
>> <SRS>EPSG:2692</SRS>
>> <SRS>EPSG:26920</SRS>
>> <SRS>EPSG:26921</SRS>
>> <SRS>EPSG:26922</SRS>
>> <SRS>EPSG:26923</SRS>
>> <SRS>EPSG:26929</SRS>
>> <SRS>EPSG:2693</SRS>
>> <SRS>EPSG:26930</SRS>
>> <SRS>EPSG:26931</SRS>
>> <SRS>EPSG:26932</SRS>
>> <SRS>EPSG:26933</SRS>
>> <SRS>EPSG:26934</SRS>
>> <SRS>EPSG:26935</SRS>
>> <SRS>EPSG:26936</SRS>
>> <SRS>EPSG:26937</SRS>
>> <SRS>EPSG:26938</SRS>
>> <SRS>EPSG:26939</SRS>
>> <SRS>EPSG:2694</SRS>
>> <SRS>EPSG:26940</SRS>
>> <SRS>EPSG:26941</SRS>
>> <SRS>EPSG:26942</SRS>
>> <SRS>EPSG:26943</SRS>
>> <SRS>EPSG:26944</SRS>
>> <SRS>EPSG:26945</SRS>
>> <SRS>EPSG:26946</SRS>
>> <SRS>EPSG:26948</SRS>
>> <SRS>EPSG:26949</SRS>
>> <SRS>EPSG:2695</SRS>
>> <SRS>EPSG:26950</SRS>
>> <SRS>EPSG:26951</SRS>
>> <SRS>EPSG:26952</SRS>
>> <SRS>EPSG:26953</SRS>
>> <SRS>EPSG:26954</SRS>
>> <SRS>EPSG:26955</SRS>
>> <SRS>EPSG:26956</SRS>
>> <SRS>EPSG:26957</SRS>
>> <SRS>EPSG:26958</SRS>
>> <SRS>EPSG:26959</SRS>
>> <SRS>EPSG:2696</SRS>
>> <SRS>EPSG:26960</SRS>
>> <SRS>EPSG:26961</SRS>
>> <SRS>EPSG:26962</SRS>
>> <SRS>EPSG:26963</SRS>
>> <SRS>EPSG:26964</SRS>
>> <SRS>EPSG:26965</SRS>
>> <SRS>EPSG:26966</SRS>
>> <SRS>EPSG:26967</SRS>
>> <SRS>EPSG:26968</SRS>
>> <SRS>EPSG:26969</SRS>
>> <SRS>EPSG:2697</SRS>
>> <SRS>EPSG:26970</SRS>
>> <SRS>EPSG:26971</SRS>
>> <SRS>EPSG:26972</SRS>
>> <SRS>EPSG:26973</SRS>
>> <SRS>EPSG:26974</SRS>
>> <SRS>EPSG:26975</SRS>
>> <SRS>EPSG:26976</SRS>
>> <SRS>EPSG:26977</SRS>
>> <SRS>EPSG:26978</SRS>
>> <SRS>EPSG:26979</SRS>
>> <SRS>EPSG:2698</SRS>
>> <SRS>EPSG:26980</SRS>
>> <SRS>EPSG:26981</SRS>
>> <SRS>EPSG:26982</SRS>
>> <SRS>EPSG:26983</SRS>
>> <SRS>EPSG:26984</SRS>
>> <SRS>EPSG:26985</SRS>
>> <SRS>EPSG:26986</SRS>
>> <SRS>EPSG:26987</SRS>
>> <SRS>EPSG:26988</SRS>
>> <SRS>EPSG:26989</SRS>
>> <SRS>EPSG:2699</SRS>
>> <SRS>EPSG:26990</SRS>
>> <SRS>EPSG:26991</SRS>
>> <SRS>EPSG:26992</SRS>
>> <SRS>EPSG:26993</SRS>
>> <SRS>EPSG:26994</SRS>
>> <SRS>EPSG:26995</SRS>
>> <SRS>EPSG:26996</SRS>
>> <SRS>EPSG:26997</SRS>
>> <SRS>EPSG:26998</SRS>
>> <SRS>EPSG:2700</SRS>
>> <SRS>EPSG:2701</SRS>
>> <SRS>EPSG:2702</SRS>
>> <SRS>EPSG:2703</SRS>
>> <SRS>EPSG:27038</SRS>
>> <SRS>EPSG:27039</SRS>
>> <SRS>EPSG:2704</SRS>
>> <SRS>EPSG:27040</SRS>
>> <SRS>EPSG:2705</SRS>
>> <SRS>EPSG:2706</SRS>
>> <SRS>EPSG:2707</SRS>
>> <SRS>EPSG:2708</SRS>
>> <SRS>EPSG:2709</SRS>
>> <SRS>EPSG:2710</SRS>
>> <SRS>EPSG:2711</SRS>
>> <SRS>EPSG:2712</SRS>
>> <SRS>EPSG:27120</SRS>
>> <SRS>EPSG:2713</SRS>
>> <SRS>EPSG:2714</SRS>
>> <SRS>EPSG:2715</SRS>
>> <SRS>EPSG:2716</SRS>
>> <SRS>EPSG:2717</SRS>
>> <SRS>EPSG:2718</SRS>
>> <SRS>EPSG:2719</SRS>
>> <SRS>EPSG:2720</SRS>
>> <SRS>EPSG:27200</SRS>
>> <SRS>EPSG:27205</SRS>
>> <SRS>EPSG:27206</SRS>
>> <SRS>EPSG:27207</SRS>
>> <SRS>EPSG:27208</SRS>
>> <SRS>EPSG:27209</SRS>
>> <SRS>EPSG:2721</SRS>
>> <SRS>EPSG:27210</SRS>
>> <SRS>EPSG:27211</SRS>
>> <SRS>EPSG:27212</SRS>
>> <SRS>EPSG:27213</SRS>
>> <SRS>EPSG:27214</SRS>
>> <SRS>EPSG:27215</SRS>
>> <SRS>EPSG:27216</SRS>
>> <SRS>EPSG:27217</SRS>
>> <SRS>EPSG:27218</SRS>
>> <SRS>EPSG:27219</SRS>
>> <SRS>EPSG:2722</SRS>
>> <SRS>EPSG:27220</SRS>
>> <SRS>EPSG:27221</SRS>
>> <SRS>EPSG:27222</SRS>
>> <SRS>EPSG:27223</SRS>
>> <SRS>EPSG:27224</SRS>
>> <SRS>EPSG:27225</SRS>
>> <SRS>EPSG:27226</SRS>
>> <SRS>EPSG:27227</SRS>
>> <SRS>EPSG:27228</SRS>
>> <SRS>EPSG:27229</SRS>
>> <SRS>EPSG:2723</SRS>
>> <SRS>EPSG:27230</SRS>
>> <SRS>EPSG:27231</SRS>
>> <SRS>EPSG:27232</SRS>
>> <SRS>EPSG:2724</SRS>
>> <SRS>EPSG:2725</SRS>
>> <SRS>EPSG:27258</SRS>
>> <SRS>EPSG:27259</SRS>
>> <SRS>EPSG:2726</SRS>
>> <SRS>EPSG:27260</SRS>
>> <SRS>EPSG:2727</SRS>
>> <SRS>EPSG:2728</SRS>
>> <SRS>EPSG:2729</SRS>
>> <SRS>EPSG:27291</SRS>
>> <SRS>EPSG:27292</SRS>
>> <SRS>EPSG:2730</SRS>
>> <SRS>EPSG:2731</SRS>
>> <SRS>EPSG:2732</SRS>
>> <SRS>EPSG:2733</SRS>
>> <SRS>EPSG:2734</SRS>
>> <SRS>EPSG:2735</SRS>
>> <SRS>EPSG:2736</SRS>
>> <SRS>EPSG:2737</SRS>
>> <SRS>EPSG:2738</SRS>
>> <SRS>EPSG:2739</SRS>
>> <SRS>EPSG:27391</SRS>
>> <SRS>EPSG:27392</SRS>
>> <SRS>EPSG:27393</SRS>
>> <SRS>EPSG:27394</SRS>
>> <SRS>EPSG:27395</SRS>
>> <SRS>EPSG:27396</SRS>
>> <SRS>EPSG:27397</SRS>
>> <SRS>EPSG:27398</SRS>
>> <SRS>EPSG:2740</SRS>
>> <SRS>EPSG:2741</SRS>
>> <SRS>EPSG:2742</SRS>
>> <SRS>EPSG:27429</SRS>
>> <SRS>EPSG:2743</SRS>
>> <SRS>EPSG:2744</SRS>
>> <SRS>EPSG:2745</SRS>
>> <SRS>EPSG:2746</SRS>
>> <SRS>EPSG:2747</SRS>
>> <SRS>EPSG:2748</SRS>
>> <SRS>EPSG:2749</SRS>
>> <SRS>EPSG:27492</SRS>
>> <SRS>EPSG:2750</SRS>
>> <SRS>EPSG:27500</SRS>
>> <SRS>EPSG:2751</SRS>
>> <SRS>EPSG:2752</SRS>
>> <SRS>EPSG:2753</SRS>
>> <SRS>EPSG:2754</SRS>
>> <SRS>EPSG:2755</SRS>
>> <SRS>EPSG:2756</SRS>
>> <SRS>EPSG:27561</SRS>
>> <SRS>EPSG:27562</SRS>
>> <SRS>EPSG:27563</SRS>
>> <SRS>EPSG:27564</SRS>
>> <SRS>EPSG:2757</SRS>
>> <SRS>EPSG:27571</SRS>
>> <SRS>EPSG:27572</SRS>
>> <SRS>EPSG:27573</SRS>
>> <SRS>EPSG:27574</SRS>
>> <SRS>EPSG:2758</SRS>
>> <SRS>EPSG:27581</SRS>
>> <SRS>EPSG:27582</SRS>
>> <SRS>EPSG:27583</SRS>
>> <SRS>EPSG:27584</SRS>
>> <SRS>EPSG:2759</SRS>
>> <SRS>EPSG:27591</SRS>
>> <SRS>EPSG:27592</SRS>
>> <SRS>EPSG:27593</SRS>
>> <SRS>EPSG:27594</SRS>
>> <SRS>EPSG:2760</SRS>
>> <SRS>EPSG:2761</SRS>
>> <SRS>EPSG:2762</SRS>
>> <SRS>EPSG:2763</SRS>
>> <SRS>EPSG:2764</SRS>
>> <SRS>EPSG:2765</SRS>
>> <SRS>EPSG:2766</SRS>
>> <SRS>EPSG:2767</SRS>
>> <SRS>EPSG:2768</SRS>
>> <SRS>EPSG:2769</SRS>
>> <SRS>EPSG:2770</SRS>
>> <SRS>EPSG:27700</SRS>
>> <SRS>EPSG:2771</SRS>
>> <SRS>EPSG:2772</SRS>
>> <SRS>EPSG:2773</SRS>
>> <SRS>EPSG:2774</SRS>
>> <SRS>EPSG:2775</SRS>
>> <SRS>EPSG:2776</SRS>
>> <SRS>EPSG:2777</SRS>
>> <SRS>EPSG:2778</SRS>
>> <SRS>EPSG:2779</SRS>
>> <SRS>EPSG:2780</SRS>
>> <SRS>EPSG:2781</SRS>
>> <SRS>EPSG:2782</SRS>
>> <SRS>EPSG:2783</SRS>
>> <SRS>EPSG:2784</SRS>
>> <SRS>EPSG:2785</SRS>
>> <SRS>EPSG:2786</SRS>
>> <SRS>EPSG:2787</SRS>
>> <SRS>EPSG:2788</SRS>
>> <SRS>EPSG:2789</SRS>
>> <SRS>EPSG:2790</SRS>
>> <SRS>EPSG:2791</SRS>
>> <SRS>EPSG:2792</SRS>
>> <SRS>EPSG:2793</SRS>
>> <SRS>EPSG:2794</SRS>
>> <SRS>EPSG:2795</SRS>
>> <SRS>EPSG:2796</SRS>
>> <SRS>EPSG:2797</SRS>
>> <SRS>EPSG:2798</SRS>
>> <SRS>EPSG:2799</SRS>
>> <SRS>EPSG:2800</SRS>
>> <SRS>EPSG:2801</SRS>
>> <SRS>EPSG:2802</SRS>
>> <SRS>EPSG:2803</SRS>
>> <SRS>EPSG:2804</SRS>
>> <SRS>EPSG:2805</SRS>
>> <SRS>EPSG:2806</SRS>
>> <SRS>EPSG:2807</SRS>
>> <SRS>EPSG:2808</SRS>
>> <SRS>EPSG:2809</SRS>
>> <SRS>EPSG:2810</SRS>
>> <SRS>EPSG:2811</SRS>
>> <SRS>EPSG:2812</SRS>
>> <SRS>EPSG:2813</SRS>
>> <SRS>EPSG:2814</SRS>
>> <SRS>EPSG:2815</SRS>
>> <SRS>EPSG:2816</SRS>
>> <SRS>EPSG:2817</SRS>
>> <SRS>EPSG:2818</SRS>
>> <SRS>EPSG:2819</SRS>
>> <SRS>EPSG:28191</SRS>
>> <SRS>EPSG:28192</SRS>
>> <SRS>EPSG:28193</SRS>
>> <SRS>EPSG:2820</SRS>
>> <SRS>EPSG:2821</SRS>
>> <SRS>EPSG:2822</SRS>
>> <SRS>EPSG:2823</SRS>
>> <SRS>EPSG:28232</SRS>
>> <SRS>EPSG:2824</SRS>
>> <SRS>EPSG:2825</SRS>
>> <SRS>EPSG:2826</SRS>
>> <SRS>EPSG:2827</SRS>
>> <SRS>EPSG:2828</SRS>
>> <SRS>EPSG:2829</SRS>
>> <SRS>EPSG:2830</SRS>
>> <SRS>EPSG:2831</SRS>
>> <SRS>EPSG:2832</SRS>
>> <SRS>EPSG:2833</SRS>
>> <SRS>EPSG:2834</SRS>
>> <SRS>EPSG:28348</SRS>
>> <SRS>EPSG:28349</SRS>
>> <SRS>EPSG:2835</SRS>
>> <SRS>EPSG:28350</SRS>
>> <SRS>EPSG:28351</SRS>
>> <SRS>EPSG:28352</SRS>
>> <SRS>EPSG:28353</SRS>
>> <SRS>EPSG:28354</SRS>
>> <SRS>EPSG:28355</SRS>
>> <SRS>EPSG:28356</SRS>
>> <SRS>EPSG:28357</SRS>
>> <SRS>EPSG:28358</SRS>
>> <SRS>EPSG:2836</SRS>
>> <SRS>EPSG:2837</SRS>
>> <SRS>EPSG:2838</SRS>
>> <SRS>EPSG:2839</SRS>
>> <SRS>EPSG:2840</SRS>
>> <SRS>EPSG:28402</SRS>
>> <SRS>EPSG:28403</SRS>
>> <SRS>EPSG:28404</SRS>
>> <SRS>EPSG:28405</SRS>
>> <SRS>EPSG:28406</SRS>
>> <SRS>EPSG:28407</SRS>
>> <SRS>EPSG:28408</SRS>
>> <SRS>EPSG:28409</SRS>
>> <SRS>EPSG:2841</SRS>
>> <SRS>EPSG:28410</SRS>
>> <SRS>EPSG:28411</SRS>
>> <SRS>EPSG:28412</SRS>
>> <SRS>EPSG:28413</SRS>
>> <SRS>EPSG:28414</SRS>
>> <SRS>EPSG:28415</SRS>
>> <SRS>EPSG:28416</SRS>
>> <SRS>EPSG:28417</SRS>
>> <SRS>EPSG:28418</SRS>
>> <SRS>EPSG:28419</SRS>
>> <SRS>EPSG:2842</SRS>
>> <SRS>EPSG:28420</SRS>
>> <SRS>EPSG:28421</SRS>
>> <SRS>EPSG:28422</SRS>
>> <SRS>EPSG:28423</SRS>
>> <SRS>EPSG:28424</SRS>
>> <SRS>EPSG:28425</SRS>
>> <SRS>EPSG:28426</SRS>
>> <SRS>EPSG:28427</SRS>
>> <SRS>EPSG:28428</SRS>
>> <SRS>EPSG:28429</SRS>
>> <SRS>EPSG:2843</SRS>
>> <SRS>EPSG:28430</SRS>
>> <SRS>EPSG:28431</SRS>
>> <SRS>EPSG:28432</SRS>
>> <SRS>EPSG:2844</SRS>
>> <SRS>EPSG:2845</SRS>
>> <SRS>EPSG:2846</SRS>
>> <SRS>EPSG:28462</SRS>
>> <SRS>EPSG:28463</SRS>
>> <SRS>EPSG:28464</SRS>
>> <SRS>EPSG:28465</SRS>
>> <SRS>EPSG:28466</SRS>
>> <SRS>EPSG:28467</SRS>
>> <SRS>EPSG:28468</SRS>
>> <SRS>EPSG:28469</SRS>
>> <SRS>EPSG:2847</SRS>
>> <SRS>EPSG:28470</SRS>
>> <SRS>EPSG:28471</SRS>
>> <SRS>EPSG:28472</SRS>
>> <SRS>EPSG:28473</SRS>
>> <SRS>EPSG:28474</SRS>
>> <SRS>EPSG:28475</SRS>
>> <SRS>EPSG:28476</SRS>
>> <SRS>EPSG:28477</SRS>
>> <SRS>EPSG:28478</SRS>
>> <SRS>EPSG:28479</SRS>
>> <SRS>EPSG:2848</SRS>
>> <SRS>EPSG:28480</SRS>
>> <SRS>EPSG:28481</SRS>
>> <SRS>EPSG:28482</SRS>
>> <SRS>EPSG:28483</SRS>
>> <SRS>EPSG:28484</SRS>
>> <SRS>EPSG:28485</SRS>
>> <SRS>EPSG:28486</SRS>
>> <SRS>EPSG:28487</SRS>
>> <SRS>EPSG:28488</SRS>
>> <SRS>EPSG:28489</SRS>
>> <SRS>EPSG:2849</SRS>
>> <SRS>EPSG:28490</SRS>
>> <SRS>EPSG:28491</SRS>
>> <SRS>EPSG:28492</SRS>
>> <SRS>EPSG:2850</SRS>
>> <SRS>EPSG:2851</SRS>
>> <SRS>EPSG:2852</SRS>
>> <SRS>EPSG:2853</SRS>
>> <SRS>EPSG:2854</SRS>
>> <SRS>EPSG:2855</SRS>
>> <SRS>EPSG:2856</SRS>
>> <SRS>EPSG:2857</SRS>
>> <SRS>EPSG:2858</SRS>
>> <SRS>EPSG:2859</SRS>
>> <SRS>EPSG:2860</SRS>
>> <SRS>EPSG:28600</SRS>
>> <SRS>EPSG:2861</SRS>
>> <SRS>EPSG:2862</SRS>
>> <SRS>EPSG:2863</SRS>
>> <SRS>EPSG:2864</SRS>
>> <SRS>EPSG:2865</SRS>
>> <SRS>EPSG:2866</SRS>
>> <SRS>EPSG:2867</SRS>
>> <SRS>EPSG:2868</SRS>
>> <SRS>EPSG:2869</SRS>
>> <SRS>EPSG:2870</SRS>
>> <SRS>EPSG:2871</SRS>
>> <SRS>EPSG:2872</SRS>
>> <SRS>EPSG:2873</SRS>
>> <SRS>EPSG:2874</SRS>
>> <SRS>EPSG:2875</SRS>
>> <SRS>EPSG:2876</SRS>
>> <SRS>EPSG:2877</SRS>
>> <SRS>EPSG:2878</SRS>
>> <SRS>EPSG:2879</SRS>
>> <SRS>EPSG:2880</SRS>
>> <SRS>EPSG:2881</SRS>
>> <SRS>EPSG:2882</SRS>
>> <SRS>EPSG:2883</SRS>
>> <SRS>EPSG:2884</SRS>
>> <SRS>EPSG:2885</SRS>
>> <SRS>EPSG:2886</SRS>
>> <SRS>EPSG:2887</SRS>
>> <SRS>EPSG:2888</SRS>
>> <SRS>EPSG:2889</SRS>
>> <SRS>EPSG:2890</SRS>
>> <SRS>EPSG:2891</SRS>
>> <SRS>EPSG:2892</SRS>
>> <SRS>EPSG:2893</SRS>
>> <SRS>EPSG:2894</SRS>
>> <SRS>EPSG:2895</SRS>
>> <SRS>EPSG:2896</SRS>
>> <SRS>EPSG:2897</SRS>
>> <SRS>EPSG:2898</SRS>
>> <SRS>EPSG:2899</SRS>
>> <SRS>EPSG:28991</SRS>
>> <SRS>EPSG:28992</SRS>
>> <SRS>EPSG:2900</SRS>
>> <SRS>EPSG:2901</SRS>
>> <SRS>EPSG:2902</SRS>
>> <SRS>EPSG:2903</SRS>
>> <SRS>EPSG:2904</SRS>
>> <SRS>EPSG:2905</SRS>
>> <SRS>EPSG:2906</SRS>
>> <SRS>EPSG:2907</SRS>
>> <SRS>EPSG:2908</SRS>
>> <SRS>EPSG:2909</SRS>
>> <SRS>EPSG:2910</SRS>
>> <SRS>EPSG:29100</SRS>
>> <SRS>EPSG:29101</SRS>
>> <SRS>EPSG:2911</SRS>
>> <SRS>EPSG:29118</SRS>
>> <SRS>EPSG:29119</SRS>
>> <SRS>EPSG:2912</SRS>
>> <SRS>EPSG:29120</SRS>
>> <SRS>EPSG:29121</SRS>
>> <SRS>EPSG:29122</SRS>
>> <SRS>EPSG:2913</SRS>
>> <SRS>EPSG:2914</SRS>
>> <SRS>EPSG:2915</SRS>
>> <SRS>EPSG:2916</SRS>
>> <SRS>EPSG:29168</SRS>
>> <SRS>EPSG:29169</SRS>
>> <SRS>EPSG:2917</SRS>
>> <SRS>EPSG:29170</SRS>
>> <SRS>EPSG:29171</SRS>
>> <SRS>EPSG:29172</SRS>
>> <SRS>EPSG:29177</SRS>
>> <SRS>EPSG:29178</SRS>
>> <SRS>EPSG:29179</SRS>
>> <SRS>EPSG:2918</SRS>
>> <SRS>EPSG:29180</SRS>
>> <SRS>EPSG:29181</SRS>
>> <SRS>EPSG:29182</SRS>
>> <SRS>EPSG:29183</SRS>
>> <SRS>EPSG:29184</SRS>
>> <SRS>EPSG:29185</SRS>
>> <SRS>EPSG:29187</SRS>
>> <SRS>EPSG:29188</SRS>
>> <SRS>EPSG:29189</SRS>
>> <SRS>EPSG:2919</SRS>
>> <SRS>EPSG:29190</SRS>
>> <SRS>EPSG:29191</SRS>
>> <SRS>EPSG:29192</SRS>
>> <SRS>EPSG:29193</SRS>
>> <SRS>EPSG:29194</SRS>
>> <SRS>EPSG:29195</SRS>
>> <SRS>EPSG:2920</SRS>
>> <SRS>EPSG:2921</SRS>
>> <SRS>EPSG:2922</SRS>
>> <SRS>EPSG:29220</SRS>
>> <SRS>EPSG:29221</SRS>
>> <SRS>EPSG:2923</SRS>
>> <SRS>EPSG:2924</SRS>
>> <SRS>EPSG:2925</SRS>
>> <SRS>EPSG:2926</SRS>
>> <SRS>EPSG:2927</SRS>
>> <SRS>EPSG:2928</SRS>
>> <SRS>EPSG:2929</SRS>
>> <SRS>EPSG:2930</SRS>
>> <SRS>EPSG:2931</SRS>
>> <SRS>EPSG:2932</SRS>
>> <SRS>EPSG:2933</SRS>
>> <SRS>EPSG:29333</SRS>
>> <SRS>EPSG:2934</SRS>
>> <SRS>EPSG:2935</SRS>
>> <SRS>EPSG:2936</SRS>
>> <SRS>EPSG:2937</SRS>
>> <SRS>EPSG:29371</SRS>
>> <SRS>EPSG:29373</SRS>
>> <SRS>EPSG:29375</SRS>
>> <SRS>EPSG:29377</SRS>
>> <SRS>EPSG:29379</SRS>
>> <SRS>EPSG:2938</SRS>
>> <SRS>EPSG:29381</SRS>
>> <SRS>EPSG:29383</SRS>
>> <SRS>EPSG:29385</SRS>
>> <SRS>EPSG:2939</SRS>
>> <SRS>EPSG:2940</SRS>
>> <SRS>EPSG:2941</SRS>
>> <SRS>EPSG:2942</SRS>
>> <SRS>EPSG:2943</SRS>
>> <SRS>EPSG:2944</SRS>
>> <SRS>EPSG:2945</SRS>
>> <SRS>EPSG:2946</SRS>
>> <SRS>EPSG:2947</SRS>
>> <SRS>EPSG:2948</SRS>
>> <SRS>EPSG:2949</SRS>
>> <SRS>EPSG:2950</SRS>
>> <SRS>EPSG:2951</SRS>
>> <SRS>EPSG:2952</SRS>
>> <SRS>EPSG:2953</SRS>
>> <SRS>EPSG:2954</SRS>
>> <SRS>EPSG:2955</SRS>
>> <SRS>EPSG:2956</SRS>
>> <SRS>EPSG:2957</SRS>
>> <SRS>EPSG:2958</SRS>
>> <SRS>EPSG:2959</SRS>
>> <SRS>EPSG:2960</SRS>
>> <SRS>EPSG:2961</SRS>
>> <SRS>EPSG:2962</SRS>
>> <SRS>EPSG:29635</SRS>
>> <SRS>EPSG:29636</SRS>
>> <SRS>EPSG:2964</SRS>
>> <SRS>EPSG:2965</SRS>
>> <SRS>EPSG:2966</SRS>
>> <SRS>EPSG:2967</SRS>
>> <SRS>EPSG:2968</SRS>
>> <SRS>EPSG:2969</SRS>
>> <SRS>EPSG:2970</SRS>
>> <SRS>EPSG:29700</SRS>
>> <SRS>EPSG:2971</SRS>
>> <SRS>EPSG:2972</SRS>
>> <SRS>EPSG:2973</SRS>
>> <SRS>EPSG:29738</SRS>
>> <SRS>EPSG:29739</SRS>
>> <SRS>EPSG:2975</SRS>
>> <SRS>EPSG:2976</SRS>
>> <SRS>EPSG:2977</SRS>
>> <SRS>EPSG:2978</SRS>
>> <SRS>EPSG:2979</SRS>
>> <SRS>EPSG:2980</SRS>
>> <SRS>EPSG:2981</SRS>
>> <SRS>EPSG:2982</SRS>
>> <SRS>EPSG:2983</SRS>
>> <SRS>EPSG:2984</SRS>
>> <SRS>EPSG:29849</SRS>
>> <SRS>EPSG:29850</SRS>
>> <SRS>EPSG:2987</SRS>
>> <SRS>EPSG:29871</SRS>
>> <SRS>EPSG:29872</SRS>
>> <SRS>EPSG:29873</SRS>
>> <SRS>EPSG:2988</SRS>
>> <SRS>EPSG:2989</SRS>
>> <SRS>EPSG:2990</SRS>
>> <SRS>EPSG:29900</SRS>
>> <SRS>EPSG:29901</SRS>
>> <SRS>EPSG:29902</SRS>
>> <SRS>EPSG:29903</SRS>
>> <SRS>EPSG:2991</SRS>
>> <SRS>EPSG:2992</SRS>
>> <SRS>EPSG:2993</SRS>
>> <SRS>EPSG:2994</SRS>
>> <SRS>EPSG:2995</SRS>
>> <SRS>EPSG:2996</SRS>
>> <SRS>EPSG:2997</SRS>
>> <SRS>EPSG:2998</SRS>
>> <SRS>EPSG:2999</SRS>
>> <SRS>EPSG:3000</SRS>
>> <SRS>EPSG:3001</SRS>
>> <SRS>EPSG:3002</SRS>
>> <SRS>EPSG:3003</SRS>
>> <SRS>EPSG:3004</SRS>
>> <SRS>EPSG:3005</SRS>
>> <SRS>EPSG:3006</SRS>
>> <SRS>EPSG:3007</SRS>
>> <SRS>EPSG:3008</SRS>
>> <SRS>EPSG:3009</SRS>
>> <SRS>EPSG:3010</SRS>
>> <SRS>EPSG:3011</SRS>
>> <SRS>EPSG:3012</SRS>
>> <SRS>EPSG:3013</SRS>
>> <SRS>EPSG:3014</SRS>
>> <SRS>EPSG:3015</SRS>
>> <SRS>EPSG:3016</SRS>
>> <SRS>EPSG:30161</SRS>
>> <SRS>EPSG:30162</SRS>
>> <SRS>EPSG:30163</SRS>
>> <SRS>EPSG:30164</SRS>
>> <SRS>EPSG:30165</SRS>
>> <SRS>EPSG:30166</SRS>
>> <SRS>EPSG:30167</SRS>
>> <SRS>EPSG:30168</SRS>
>> <SRS>EPSG:30169</SRS>
>> <SRS>EPSG:3017</SRS>
>> <SRS>EPSG:30170</SRS>
>> <SRS>EPSG:30171</SRS>
>> <SRS>EPSG:30172</SRS>
>> <SRS>EPSG:30173</SRS>
>> <SRS>EPSG:30174</SRS>
>> <SRS>EPSG:30175</SRS>
>> <SRS>EPSG:30176</SRS>
>> <SRS>EPSG:30177</SRS>
>> <SRS>EPSG:30178</SRS>
>> <SRS>EPSG:30179</SRS>
>> <SRS>EPSG:3018</SRS>
>> <SRS>EPSG:3019</SRS>
>> <SRS>EPSG:3020</SRS>
>> <SRS>EPSG:30200</SRS>
>> <SRS>EPSG:3021</SRS>
>> <SRS>EPSG:3022</SRS>
>> <SRS>EPSG:3023</SRS>
>> <SRS>EPSG:3024</SRS>
>> <SRS>EPSG:3025</SRS>
>> <SRS>EPSG:3026</SRS>
>> <SRS>EPSG:3027</SRS>
>> <SRS>EPSG:3028</SRS>
>> <SRS>EPSG:3029</SRS>
>> <SRS>EPSG:3030</SRS>
>> <SRS>EPSG:3033</SRS>
>> <SRS>EPSG:30339</SRS>
>> <SRS>EPSG:3034</SRS>
>> <SRS>EPSG:30340</SRS>
>> <SRS>EPSG:3035</SRS>
>> <SRS>EPSG:3036</SRS>
>> <SRS>EPSG:3037</SRS>
>> <SRS>EPSG:3038</SRS>
>> <SRS>EPSG:3039</SRS>
>> <SRS>EPSG:3040</SRS>
>> <SRS>EPSG:3041</SRS>
>> <SRS>EPSG:3042</SRS>
>> <SRS>EPSG:3043</SRS>
>> <SRS>EPSG:3044</SRS>
>> <SRS>EPSG:3045</SRS>
>> <SRS>EPSG:3046</SRS>
>> <SRS>EPSG:3047</SRS>
>> <SRS>EPSG:3048</SRS>
>> <SRS>EPSG:3049</SRS>
>> <SRS>EPSG:30491</SRS>
>> <SRS>EPSG:30492</SRS>
>> <SRS>EPSG:30493</SRS>
>> <SRS>EPSG:30494</SRS>
>> <SRS>EPSG:3050</SRS>
>> <SRS>EPSG:3051</SRS>
>> <SRS>EPSG:3054</SRS>
>> <SRS>EPSG:3055</SRS>
>> <SRS>EPSG:3056</SRS>
>> <SRS>EPSG:3057</SRS>
>> <SRS>EPSG:3058</SRS>
>> <SRS>EPSG:3059</SRS>
>> <SRS>EPSG:3060</SRS>
>> <SRS>EPSG:3061</SRS>
>> <SRS>EPSG:3062</SRS>
>> <SRS>EPSG:3063</SRS>
>> <SRS>EPSG:3064</SRS>
>> <SRS>EPSG:3065</SRS>
>> <SRS>EPSG:30729</SRS>
>> <SRS>EPSG:30730</SRS>
>> <SRS>EPSG:30731</SRS>
>> <SRS>EPSG:30732</SRS>
>> <SRS>EPSG:30791</SRS>
>> <SRS>EPSG:30792</SRS>
>> <SRS>EPSG:30800</SRS>
>> <SRS>EPSG:31028</SRS>
>> <SRS>EPSG:3110</SRS>
>> <SRS>EPSG:3111</SRS>
>> <SRS>EPSG:3112</SRS>
>> <SRS>EPSG:31121</SRS>
>> <SRS>EPSG:31154</SRS>
>> <SRS>EPSG:31170</SRS>
>> <SRS>EPSG:31171</SRS>
>> <SRS>EPSG:31265</SRS>
>> <SRS>EPSG:31266</SRS>
>> <SRS>EPSG:31267</SRS>
>> <SRS>EPSG:31268</SRS>
>> <SRS>EPSG:31275</SRS>
>> <SRS>EPSG:31276</SRS>
>> <SRS>EPSG:31277</SRS>
>> <SRS>EPSG:31278</SRS>
>> <SRS>EPSG:31279</SRS>
>> <SRS>EPSG:31281</SRS>
>> <SRS>EPSG:31282</SRS>
>> <SRS>EPSG:31283</SRS>
>> <SRS>EPSG:31284</SRS>
>> <SRS>EPSG:31285</SRS>
>> <SRS>EPSG:31286</SRS>
>> <SRS>EPSG:31287</SRS>
>> <SRS>EPSG:31288</SRS>
>> <SRS>EPSG:31289</SRS>
>> <SRS>EPSG:31290</SRS>
>> <SRS>EPSG:31291</SRS>
>> <SRS>EPSG:31292</SRS>
>> <SRS>EPSG:31293</SRS>
>> <SRS>EPSG:31294</SRS>
>> <SRS>EPSG:31295</SRS>
>> <SRS>EPSG:31296</SRS>
>> <SRS>EPSG:31297</SRS>
>> <SRS>EPSG:31300</SRS>
>> <SRS>EPSG:31370</SRS>
>> <SRS>EPSG:31461</SRS>
>> <SRS>EPSG:31462</SRS>
>> <SRS>EPSG:31463</SRS>
>> <SRS>EPSG:31464</SRS>
>> <SRS>EPSG:31465</SRS>
>> <SRS>EPSG:31466</SRS>
>> <SRS>EPSG:31468</SRS>
>> <SRS>EPSG:31469</SRS>
>> <SRS>EPSG:3148</SRS>
>> <SRS>EPSG:3149</SRS>
>> <SRS>EPSG:31528</SRS>
>> <SRS>EPSG:31529</SRS>
>> <SRS>EPSG:31600</SRS>
>> <SRS>EPSG:31700</SRS>
>> <SRS>EPSG:3176</SRS>
>> <SRS>EPSG:31838</SRS>
>> <SRS>EPSG:31839</SRS>
>> <SRS>EPSG:31900</SRS>
>> <SRS>EPSG:31986</SRS>
>> <SRS>EPSG:31987</SRS>
>> <SRS>EPSG:31988</SRS>
>> <SRS>EPSG:31989</SRS>
>> <SRS>EPSG:31990</SRS>
>> <SRS>EPSG:31991</SRS>
>> <SRS>EPSG:31992</SRS>
>> <SRS>EPSG:31993</SRS>
>> <SRS>EPSG:31994</SRS>
>> <SRS>EPSG:31995</SRS>
>> <SRS>EPSG:31996</SRS>
>> <SRS>EPSG:31997</SRS>
>> <SRS>EPSG:31998</SRS>
>> <SRS>EPSG:31999</SRS>
>> <SRS>EPSG:3200</SRS>
>> <SRS>EPSG:32000</SRS>
>> <SRS>EPSG:32001</SRS>
>> <SRS>EPSG:32002</SRS>
>> <SRS>EPSG:32003</SRS>
>> <SRS>EPSG:32005</SRS>
>> <SRS>EPSG:32006</SRS>
>> <SRS>EPSG:32007</SRS>
>> <SRS>EPSG:32008</SRS>
>> <SRS>EPSG:32009</SRS>
>> <SRS>EPSG:32010</SRS>
>> <SRS>EPSG:32011</SRS>
>> <SRS>EPSG:32012</SRS>
>> <SRS>EPSG:32013</SRS>
>> <SRS>EPSG:32014</SRS>
>> <SRS>EPSG:32015</SRS>
>> <SRS>EPSG:32016</SRS>
>> <SRS>EPSG:32017</SRS>
>> <SRS>EPSG:32018</SRS>
>> <SRS>EPSG:32019</SRS>
>> <SRS>EPSG:32020</SRS>
>> <SRS>EPSG:32021</SRS>
>> <SRS>EPSG:32022</SRS>
>> <SRS>EPSG:32023</SRS>
>> <SRS>EPSG:32024</SRS>
>> <SRS>EPSG:32025</SRS>
>> <SRS>EPSG:32026</SRS>
>> <SRS>EPSG:32027</SRS>
>> <SRS>EPSG:32028</SRS>
>> <SRS>EPSG:32029</SRS>
>> <SRS>EPSG:32030</SRS>
>> <SRS>EPSG:32031</SRS>
>> <SRS>EPSG:32033</SRS>
>> <SRS>EPSG:32034</SRS>
>> <SRS>EPSG:32035</SRS>
>> <SRS>EPSG:32036</SRS>
>> <SRS>EPSG:32037</SRS>
>> <SRS>EPSG:32038</SRS>
>> <SRS>EPSG:32039</SRS>
>> <SRS>EPSG:32040</SRS>
>> <SRS>EPSG:32041</SRS>
>> <SRS>EPSG:32042</SRS>
>> <SRS>EPSG:32043</SRS>
>> <SRS>EPSG:32044</SRS>
>> <SRS>EPSG:32045</SRS>
>> <SRS>EPSG:32046</SRS>
>> <SRS>EPSG:32047</SRS>
>> <SRS>EPSG:32048</SRS>
>> <SRS>EPSG:32049</SRS>
>> <SRS>EPSG:32050</SRS>
>> <SRS>EPSG:32051</SRS>
>> <SRS>EPSG:32052</SRS>
>> <SRS>EPSG:32053</SRS>
>> <SRS>EPSG:32054</SRS>
>> <SRS>EPSG:32055</SRS>
>> <SRS>EPSG:32056</SRS>
>> <SRS>EPSG:32057</SRS>
>> <SRS>EPSG:32058</SRS>
>> <SRS>EPSG:32061</SRS>
>> <SRS>EPSG:32062</SRS>
>> <SRS>EPSG:32064</SRS>
>> <SRS>EPSG:32065</SRS>
>> <SRS>EPSG:32066</SRS>
>> <SRS>EPSG:32067</SRS>
>> <SRS>EPSG:32074</SRS>
>> <SRS>EPSG:32075</SRS>
>> <SRS>EPSG:32076</SRS>
>> <SRS>EPSG:32077</SRS>
>> <SRS>EPSG:32081</SRS>
>> <SRS>EPSG:32082</SRS>
>> <SRS>EPSG:32083</SRS>
>> <SRS>EPSG:32084</SRS>
>> <SRS>EPSG:32085</SRS>
>> <SRS>EPSG:32086</SRS>
>> <SRS>EPSG:32098</SRS>
>> <SRS>EPSG:32100</SRS>
>> <SRS>EPSG:32104</SRS>
>> <SRS>EPSG:32107</SRS>
>> <SRS>EPSG:32108</SRS>
>> <SRS>EPSG:32109</SRS>
>> <SRS>EPSG:32110</SRS>
>> <SRS>EPSG:32111</SRS>
>> <SRS>EPSG:32112</SRS>
>> <SRS>EPSG:32113</SRS>
>> <SRS>EPSG:32114</SRS>
>> <SRS>EPSG:32115</SRS>
>> <SRS>EPSG:32116</SRS>
>> <SRS>EPSG:32117</SRS>
>> <SRS>EPSG:32118</SRS>
>> <SRS>EPSG:32119</SRS>
>> <SRS>EPSG:32120</SRS>
>> <SRS>EPSG:32121</SRS>
>> <SRS>EPSG:32122</SRS>
>> <SRS>EPSG:32123</SRS>
>> <SRS>EPSG:32124</SRS>
>> <SRS>EPSG:32125</SRS>
>> <SRS>EPSG:32126</SRS>
>> <SRS>EPSG:32127</SRS>
>> <SRS>EPSG:32128</SRS>
>> <SRS>EPSG:32129</SRS>
>> <SRS>EPSG:32130</SRS>
>> <SRS>EPSG:32133</SRS>
>> <SRS>EPSG:32134</SRS>
>> <SRS>EPSG:32135</SRS>
>> <SRS>EPSG:32136</SRS>
>> <SRS>EPSG:32137</SRS>
>> <SRS>EPSG:32138</SRS>
>> <SRS>EPSG:32139</SRS>
>> <SRS>EPSG:32140</SRS>
>> <SRS>EPSG:32141</SRS>
>> <SRS>EPSG:32142</SRS>
>> <SRS>EPSG:32143</SRS>
>> <SRS>EPSG:32144</SRS>
>> <SRS>EPSG:32145</SRS>
>> <SRS>EPSG:32146</SRS>
>> <SRS>EPSG:32147</SRS>
>> <SRS>EPSG:32148</SRS>
>> <SRS>EPSG:32149</SRS>
>> <SRS>EPSG:32150</SRS>
>> <SRS>EPSG:32151</SRS>
>> <SRS>EPSG:32152</SRS>
>> <SRS>EPSG:32153</SRS>
>> <SRS>EPSG:32154</SRS>
>> <SRS>EPSG:32155</SRS>
>> <SRS>EPSG:32156</SRS>
>> <SRS>EPSG:32157</SRS>
>> <SRS>EPSG:32158</SRS>
>> <SRS>EPSG:32161</SRS>
>> <SRS>EPSG:32180</SRS>
>> <SRS>EPSG:32181</SRS>
>> <SRS>EPSG:32182</SRS>
>> <SRS>EPSG:32183</SRS>
>> <SRS>EPSG:32184</SRS>
>> <SRS>EPSG:32185</SRS>
>> <SRS>EPSG:32186</SRS>
>> <SRS>EPSG:32187</SRS>
>> <SRS>EPSG:32188</SRS>
>> <SRS>EPSG:32189</SRS>
>> <SRS>EPSG:32190</SRS>
>> <SRS>EPSG:32191</SRS>
>> <SRS>EPSG:32192</SRS>
>> <SRS>EPSG:32193</SRS>
>> <SRS>EPSG:32194</SRS>
>> <SRS>EPSG:32195</SRS>
>> <SRS>EPSG:32196</SRS>
>> <SRS>EPSG:32197</SRS>
>> <SRS>EPSG:32198</SRS>
>> <SRS>EPSG:32201</SRS>
>> <SRS>EPSG:32202</SRS>
>> <SRS>EPSG:32203</SRS>
>> <SRS>EPSG:32204</SRS>
>> <SRS>EPSG:32205</SRS>
>> <SRS>EPSG:32206</SRS>
>> <SRS>EPSG:32207</SRS>
>> <SRS>EPSG:32208</SRS>
>> <SRS>EPSG:32209</SRS>
>> <SRS>EPSG:32210</SRS>
>> <SRS>EPSG:32211</SRS>
>> <SRS>EPSG:32212</SRS>
>> <SRS>EPSG:32213</SRS>
>> <SRS>EPSG:32214</SRS>
>> <SRS>EPSG:32215</SRS>
>> <SRS>EPSG:32216</SRS>
>> <SRS>EPSG:32217</SRS>
>> <SRS>EPSG:32218</SRS>
>> <SRS>EPSG:32219</SRS>
>> <SRS>EPSG:32220</SRS>
>> <SRS>EPSG:32221</SRS>
>> <SRS>EPSG:32222</SRS>
>> <SRS>EPSG:32223</SRS>
>> <SRS>EPSG:32224</SRS>
>> <SRS>EPSG:32225</SRS>
>> <SRS>EPSG:32226</SRS>
>> <SRS>EPSG:32227</SRS>
>> <SRS>EPSG:32228</SRS>
>> <SRS>EPSG:32229</SRS>
>> <SRS>EPSG:32230</SRS>
>> <SRS>EPSG:32231</SRS>
>> <SRS>EPSG:32232</SRS>
>> <SRS>EPSG:32233</SRS>
>> <SRS>EPSG:32234</SRS>
>> <SRS>EPSG:32235</SRS>
>> <SRS>EPSG:32236</SRS>
>> <SRS>EPSG:32237</SRS>
>> <SRS>EPSG:32238</SRS>
>> <SRS>EPSG:32239</SRS>
>> <SRS>EPSG:32240</SRS>
>> <SRS>EPSG:32241</SRS>
>> <SRS>EPSG:32242</SRS>
>> <SRS>EPSG:32243</SRS>
>> <SRS>EPSG:32244</SRS>
>> <SRS>EPSG:32245</SRS>
>> <SRS>EPSG:32246</SRS>
>> <SRS>EPSG:32247</SRS>
>> <SRS>EPSG:32248</SRS>
>> <SRS>EPSG:32249</SRS>
>> <SRS>EPSG:32250</SRS>
>> <SRS>EPSG:32251</SRS>
>> <SRS>EPSG:32252</SRS>
>> <SRS>EPSG:32253</SRS>
>> <SRS>EPSG:32254</SRS>
>> <SRS>EPSG:32255</SRS>
>> <SRS>EPSG:32256</SRS>
>> <SRS>EPSG:32257</SRS>
>> <SRS>EPSG:32258</SRS>
>> <SRS>EPSG:32259</SRS>
>> <SRS>EPSG:32260</SRS>
>> <SRS>EPSG:32301</SRS>
>> <SRS>EPSG:32302</SRS>
>> <SRS>EPSG:32303</SRS>
>> <SRS>EPSG:32304</SRS>
>> <SRS>EPSG:32305</SRS>
>> <SRS>EPSG:32306</SRS>
>> <SRS>EPSG:32307</SRS>
>> <SRS>EPSG:32308</SRS>
>> <SRS>EPSG:32309</SRS>
>> <SRS>EPSG:32310</SRS>
>> <SRS>EPSG:32311</SRS>
>> <SRS>EPSG:32312</SRS>
>> <SRS>EPSG:32313</SRS>
>> <SRS>EPSG:32314</SRS>
>> <SRS>EPSG:32315</SRS>
>> <SRS>EPSG:32316</SRS>
>> <SRS>EPSG:32317</SRS>
>> <SRS>EPSG:32318</SRS>
>> <SRS>EPSG:32319</SRS>
>> <SRS>EPSG:32320</SRS>
>> <SRS>EPSG:32321</SRS>
>> <SRS>EPSG:32322</SRS>
>> <SRS>EPSG:32323</SRS>
>> <SRS>EPSG:32324</SRS>
>> <SRS>EPSG:32325</SRS>
>> <SRS>EPSG:32326</SRS>
>> <SRS>EPSG:32327</SRS>
>> <SRS>EPSG:32328</SRS>
>> <SRS>EPSG:32329</SRS>
>> <SRS>EPSG:32330</SRS>
>> <SRS>EPSG:32331</SRS>
>> <SRS>EPSG:32332</SRS>
>> <SRS>EPSG:32333</SRS>
>> <SRS>EPSG:32334</SRS>
>> <SRS>EPSG:32335</SRS>
>> <SRS>EPSG:32336</SRS>
>> <SRS>EPSG:32337</SRS>
>> <SRS>EPSG:32338</SRS>
>> <SRS>EPSG:32339</SRS>
>> <SRS>EPSG:32340</SRS>
>> <SRS>EPSG:32341</SRS>
>> <SRS>EPSG:32342</SRS>
>> <SRS>EPSG:32343</SRS>
>> <SRS>EPSG:32344</SRS>
>> <SRS>EPSG:32345</SRS>
>> <SRS>EPSG:32346</SRS>
>> <SRS>EPSG:32347</SRS>
>> <SRS>EPSG:32348</SRS>
>> <SRS>EPSG:32349</SRS>
>> <SRS>EPSG:32350</SRS>
>> <SRS>EPSG:32351</SRS>
>> <SRS>EPSG:32352</SRS>
>> <SRS>EPSG:32353</SRS>
>> <SRS>EPSG:32354</SRS>
>> <SRS>EPSG:32355</SRS>
>> <SRS>EPSG:32356</SRS>
>> <SRS>EPSG:32357</SRS>
>> <SRS>EPSG:32358</SRS>
>> <SRS>EPSG:32359</SRS>
>> <SRS>EPSG:32360</SRS>
>> <SRS>EPSG:32401</SRS>
>> <SRS>EPSG:32402</SRS>
>> <SRS>EPSG:32403</SRS>
>> <SRS>EPSG:32404</SRS>
>> <SRS>EPSG:32405</SRS>
>> <SRS>EPSG:32406</SRS>
>> <SRS>EPSG:32407</SRS>
>> <SRS>EPSG:32408</SRS>
>> <SRS>EPSG:32409</SRS>
>> <SRS>EPSG:32410</SRS>
>> <SRS>EPSG:32411</SRS>
>> <SRS>EPSG:32412</SRS>
>> <SRS>EPSG:32413</SRS>
>> <SRS>EPSG:32414</SRS>
>> <SRS>EPSG:32415</SRS>
>> <SRS>EPSG:32416</SRS>
>> <SRS>EPSG:32417</SRS>
>> <SRS>EPSG:32418</SRS>
>> <SRS>EPSG:32419</SRS>
>> <SRS>EPSG:32420</SRS>
>> <SRS>EPSG:32421</SRS>
>> <SRS>EPSG:32422</SRS>
>> <SRS>EPSG:32423</SRS>
>> <SRS>EPSG:32424</SRS>
>> <SRS>EPSG:32425</SRS>
>> <SRS>EPSG:32426</SRS>
>> <SRS>EPSG:32427</SRS>
>> <SRS>EPSG:32428</SRS>
>> <SRS>EPSG:32429</SRS>
>> <SRS>EPSG:32430</SRS>
>> <SRS>EPSG:32431</SRS>
>> <SRS>EPSG:32432</SRS>
>> <SRS>EPSG:32433</SRS>
>> <SRS>EPSG:32434</SRS>
>> <SRS>EPSG:32435</SRS>
>> <SRS>EPSG:32436</SRS>
>> <SRS>EPSG:32437</SRS>
>> <SRS>EPSG:32438</SRS>
>> <SRS>EPSG:32439</SRS>
>> <SRS>EPSG:32440</SRS>
>> <SRS>EPSG:32441</SRS>
>> <SRS>EPSG:32442</SRS>
>> <SRS>EPSG:32443</SRS>
>> <SRS>EPSG:32444</SRS>
>> <SRS>EPSG:32445</SRS>
>> <SRS>EPSG:32446</SRS>
>> <SRS>EPSG:32447</SRS>
>> <SRS>EPSG:32448</SRS>
>> <SRS>EPSG:32449</SRS>
>> <SRS>EPSG:32450</SRS>
>> <SRS>EPSG:32451</SRS>
>> <SRS>EPSG:32452</SRS>
>> <SRS>EPSG:32453</SRS>
>> <SRS>EPSG:32454</SRS>
>> <SRS>EPSG:32455</SRS>
>> <SRS>EPSG:32456</SRS>
>> <SRS>EPSG:32457</SRS>
>> <SRS>EPSG:32458</SRS>
>> <SRS>EPSG:32459</SRS>
>> <SRS>EPSG:32460</SRS>
>> <SRS>EPSG:32501</SRS>
>> <SRS>EPSG:32502</SRS>
>> <SRS>EPSG:32503</SRS>
>> <SRS>EPSG:32504</SRS>
>> <SRS>EPSG:32505</SRS>
>> <SRS>EPSG:32506</SRS>
>> <SRS>EPSG:32507</SRS>
>> <SRS>EPSG:32508</SRS>
>> <SRS>EPSG:32509</SRS>
>> <SRS>EPSG:32510</SRS>
>> <SRS>EPSG:32511</SRS>
>> <SRS>EPSG:32512</SRS>
>> <SRS>EPSG:32513</SRS>
>> <SRS>EPSG:32514</SRS>
>> <SRS>EPSG:32515</SRS>
>> <SRS>EPSG:32516</SRS>
>> <SRS>EPSG:32517</SRS>
>> <SRS>EPSG:32518</SRS>
>> <SRS>EPSG:32519</SRS>
>> <SRS>EPSG:32520</SRS>
>> <SRS>EPSG:32521</SRS>
>> <SRS>EPSG:32522</SRS>
>> <SRS>EPSG:32523</SRS>
>> <SRS>EPSG:32524</SRS>
>> <SRS>EPSG:32525</SRS>
>> <SRS>EPSG:32526</SRS>
>> <SRS>EPSG:32527</SRS>
>> <SRS>EPSG:32528</SRS>
>> <SRS>EPSG:32529</SRS>
>> <SRS>EPSG:32530</SRS>
>> <SRS>EPSG:32531</SRS>
>> <SRS>EPSG:32532</SRS>
>> <SRS>EPSG:32533</SRS>
>> <SRS>EPSG:32534</SRS>
>> <SRS>EPSG:32535</SRS>
>> <SRS>EPSG:32536</SRS>
>> <SRS>EPSG:32537</SRS>
>> <SRS>EPSG:32538</SRS>
>> <SRS>EPSG:32539</SRS>
>> <SRS>EPSG:32540</SRS>
>> <SRS>EPSG:32541</SRS>
>> <SRS>EPSG:32542</SRS>
>> <SRS>EPSG:32543</SRS>
>> <SRS>EPSG:32544</SRS>
>> <SRS>EPSG:32545</SRS>
>> <SRS>EPSG:32546</SRS>
>> <SRS>EPSG:32547</SRS>
>> <SRS>EPSG:32548</SRS>
>> <SRS>EPSG:32549</SRS>
>> <SRS>EPSG:32550</SRS>
>> <SRS>EPSG:32551</SRS>
>> <SRS>EPSG:32552</SRS>
>> <SRS>EPSG:32553</SRS>
>> <SRS>EPSG:32554</SRS>
>> <SRS>EPSG:32555</SRS>
>> <SRS>EPSG:32556</SRS>
>> <SRS>EPSG:32557</SRS>
>> <SRS>EPSG:32558</SRS>
>> <SRS>EPSG:32559</SRS>
>> <SRS>EPSG:32560</SRS>
>> <SRS>EPSG:32601</SRS>
>> <SRS>EPSG:32602</SRS>
>> <SRS>EPSG:32603</SRS>
>> <SRS>EPSG:32604</SRS>
>> <SRS>EPSG:32605</SRS>
>> <SRS>EPSG:32606</SRS>
>> <SRS>EPSG:32607</SRS>
>> <SRS>EPSG:32608</SRS>
>> <SRS>EPSG:32609</SRS>
>> <SRS>EPSG:32610</SRS>
>> <SRS>EPSG:32611</SRS>
>> <SRS>EPSG:32612</SRS>
>> <SRS>EPSG:32613</SRS>
>> <SRS>EPSG:32614</SRS>
>> <SRS>EPSG:32615</SRS>
>> <SRS>EPSG:32616</SRS>
>> <SRS>EPSG:32617</SRS>
>> <SRS>EPSG:32618</SRS>
>> <SRS>EPSG:32619</SRS>
>> <SRS>EPSG:32620</SRS>
>> <SRS>EPSG:32621</SRS>
>> <SRS>EPSG:32622</SRS>
>> <SRS>EPSG:32623</SRS>
>> <SRS>EPSG:32624</SRS>
>> <SRS>EPSG:32625</SRS>
>> <SRS>EPSG:32626</SRS>
>> <SRS>EPSG:32627</SRS>
>> <SRS>EPSG:32628</SRS>
>> <SRS>EPSG:32629</SRS>
>> <SRS>EPSG:32630</SRS>
>> <SRS>EPSG:32631</SRS>
>> <SRS>EPSG:32632</SRS>
>> <SRS>EPSG:32633</SRS>
>> <SRS>EPSG:32634</SRS>
>> <SRS>EPSG:32635</SRS>
>> <SRS>EPSG:32636</SRS>
>> <SRS>EPSG:32637</SRS>
>> <SRS>EPSG:32638</SRS>
>> <SRS>EPSG:32639</SRS>
>> <SRS>EPSG:32640</SRS>
>> <SRS>EPSG:32641</SRS>
>> <SRS>EPSG:32642</SRS>
>> <SRS>EPSG:32643</SRS>
>> <SRS>EPSG:32644</SRS>
>> <SRS>EPSG:32645</SRS>
>> <SRS>EPSG:32646</SRS>
>> <SRS>EPSG:32647</SRS>
>> <SRS>EPSG:32648</SRS>
>> <SRS>EPSG:32649</SRS>
>> <SRS>EPSG:32650</SRS>
>> <SRS>EPSG:32651</SRS>
>> <SRS>EPSG:32652</SRS>
>> <SRS>EPSG:32653</SRS>
>> <SRS>EPSG:32654</SRS>
>> <SRS>EPSG:32655</SRS>
>> <SRS>EPSG:32656</SRS>
>> <SRS>EPSG:32657</SRS>
>> <SRS>EPSG:32658</SRS>
>> <SRS>EPSG:32659</SRS>
>> <SRS>EPSG:32660</SRS>
>> <SRS>EPSG:32661</SRS>
>> <SRS>EPSG:32701</SRS>
>> <SRS>EPSG:32702</SRS>
>> <SRS>EPSG:32703</SRS>
>> <SRS>EPSG:32704</SRS>
>> <SRS>EPSG:32705</SRS>
>> <SRS>EPSG:32706</SRS>
>> <SRS>EPSG:32707</SRS>
>> <SRS>EPSG:32708</SRS>
>> <SRS>EPSG:32709</SRS>
>> <SRS>EPSG:32710</SRS>
>> <SRS>EPSG:32711</SRS>
>> <SRS>EPSG:32712</SRS>
>> <SRS>EPSG:32713</SRS>
>> <SRS>EPSG:32714</SRS>
>> <SRS>EPSG:32715</SRS>
>> <SRS>EPSG:32716</SRS>
>> <SRS>EPSG:32717</SRS>
>> <SRS>EPSG:32718</SRS>
>> <SRS>EPSG:32719</SRS>
>> <SRS>EPSG:32720</SRS>
>> <SRS>EPSG:32721</SRS>
>> <SRS>EPSG:32722</SRS>
>> <SRS>EPSG:32723</SRS>
>> <SRS>EPSG:32724</SRS>
>> <SRS>EPSG:32725</SRS>
>> <SRS>EPSG:32726</SRS>
>> <SRS>EPSG:32727</SRS>
>> <SRS>EPSG:32728</SRS>
>> <SRS>EPSG:32729</SRS>
>> <SRS>EPSG:32730</SRS>
>> <SRS>EPSG:32731</SRS>
>> <SRS>EPSG:32732</SRS>
>> <SRS>EPSG:32733</SRS>
>> <SRS>EPSG:32734</SRS>
>> <SRS>EPSG:32735</SRS>
>> <SRS>EPSG:32736</SRS>
>> <SRS>EPSG:32737</SRS>
>> <SRS>EPSG:32738</SRS>
>> <SRS>EPSG:32739</SRS>
>> <SRS>EPSG:32740</SRS>
>> <SRS>EPSG:32741</SRS>
>> <SRS>EPSG:32742</SRS>
>> <SRS>EPSG:32743</SRS>
>> <SRS>EPSG:32744</SRS>
>> <SRS>EPSG:32745</SRS>
>> <SRS>EPSG:32746</SRS>
>> <SRS>EPSG:32747</SRS>
>> <SRS>EPSG:32748</SRS>
>> <SRS>EPSG:32749</SRS>
>> <SRS>EPSG:32750</SRS>
>> <SRS>EPSG:32751</SRS>
>> <SRS>EPSG:32752</SRS>
>> <SRS>EPSG:32753</SRS>
>> <SRS>EPSG:32754</SRS>
>> <SRS>EPSG:32755</SRS>
>> <SRS>EPSG:32756</SRS>
>> <SRS>EPSG:32757</SRS>
>> <SRS>EPSG:32758</SRS>
>> <SRS>EPSG:32759</SRS>
>> <SRS>EPSG:32760</SRS>
>> <SRS>EPSG:32761</SRS>
>> <SRS>EPSG:32766</SRS>
>> <SRS>EPSG:3300</SRS>
>> <SRS>EPSG:3301</SRS>
>> <SRS>EPSG:3439</SRS>
>> <SRS>EPSG:3440</SRS>
>> <SRS>EPSG:3561</SRS>
>> <SRS>EPSG:3562</SRS>
>> <SRS>EPSG:3563</SRS>
>> <SRS>EPSG:3564</SRS>
>> <SRS>EPSG:3565</SRS>
>> <SRS>EPSG:3920</SRS>
>> <SRS>EPSG:3991</SRS>
>> <SRS>EPSG:3992</SRS>
>> <SRS>EPSG:4001</SRS>
>> <SRS>EPSG:4002</SRS>
>> <SRS>EPSG:4003</SRS>
>> <SRS>EPSG:4004</SRS>
>> <SRS>EPSG:4005</SRS>
>> <SRS>EPSG:4006</SRS>
>> <SRS>EPSG:4007</SRS>
>> <SRS>EPSG:4008</SRS>
>> <SRS>EPSG:4009</SRS>
>> <SRS>EPSG:4010</SRS>
>> <SRS>EPSG:4011</SRS>
>> <SRS>EPSG:4012</SRS>
>> <SRS>EPSG:4013</SRS>
>> <SRS>EPSG:4014</SRS>
>> <SRS>EPSG:4015</SRS>
>> <SRS>EPSG:4016</SRS>
>> <SRS>EPSG:4018</SRS>
>> <SRS>EPSG:4019</SRS>
>> <SRS>EPSG:4020</SRS>
>> <SRS>EPSG:4021</SRS>
>> <SRS>EPSG:4022</SRS>
>> <SRS>EPSG:4024</SRS>
>> <SRS>EPSG:4025</SRS>
>> <SRS>EPSG:4027</SRS>
>> <SRS>EPSG:4028</SRS>
>> <SRS>EPSG:4029</SRS>
>> <SRS>EPSG:4030</SRS>
>> <SRS>EPSG:4031</SRS>
>> <SRS>EPSG:4032</SRS>
>> <SRS>EPSG:4033</SRS>
>> <SRS>EPSG:4034</SRS>
>> <SRS>EPSG:4035</SRS>
>> <SRS>EPSG:4036</SRS>
>> <SRS>EPSG:4041</SRS>
>> <SRS>EPSG:4042</SRS>
>> <SRS>EPSG:4043</SRS>
>> <SRS>EPSG:4044</SRS>
>> <SRS>EPSG:4045</SRS>
>> <SRS>EPSG:4047</SRS>
>> <SRS>EPSG:41001</SRS>
>> <SRS>EPSG:4120</SRS>
>> <SRS>EPSG:4121</SRS>
>> <SRS>EPSG:4122</SRS>
>> <SRS>EPSG:4123</SRS>
>> <SRS>EPSG:4124</SRS>
>> <SRS>EPSG:4125</SRS>
>> <SRS>EPSG:4126</SRS>
>> <SRS>EPSG:4127</SRS>
>> <SRS>EPSG:4128</SRS>
>> <SRS>EPSG:4129</SRS>
>> <SRS>EPSG:4130</SRS>
>> <SRS>EPSG:4131</SRS>
>> <SRS>EPSG:4132</SRS>
>> <SRS>EPSG:4133</SRS>
>> <SRS>EPSG:4134</SRS>
>> <SRS>EPSG:4135</SRS>
>> <SRS>EPSG:4136</SRS>
>> <SRS>EPSG:4137</SRS>
>> <SRS>EPSG:4138</SRS>
>> <SRS>EPSG:4139</SRS>
>> <SRS>EPSG:4140</SRS>
>> <SRS>EPSG:4141</SRS>
>> <SRS>EPSG:4142</SRS>
>> <SRS>EPSG:4143</SRS>
>> <SRS>EPSG:4144</SRS>
>> <SRS>EPSG:4145</SRS>
>> <SRS>EPSG:4146</SRS>
>> <SRS>EPSG:4147</SRS>
>> <SRS>EPSG:4148</SRS>
>> <SRS>EPSG:4149</SRS>
>> <SRS>EPSG:4150</SRS>
>> <SRS>EPSG:4151</SRS>
>> <SRS>EPSG:4152</SRS>
>> <SRS>EPSG:4153</SRS>
>> <SRS>EPSG:4154</SRS>
>> <SRS>EPSG:4155</SRS>
>> <SRS>EPSG:4156</SRS>
>> <SRS>EPSG:4157</SRS>
>> <SRS>EPSG:4158</SRS>
>> <SRS>EPSG:4159</SRS>
>> <SRS>EPSG:4160</SRS>
>> <SRS>EPSG:4161</SRS>
>> <SRS>EPSG:4162</SRS>
>> <SRS>EPSG:4163</SRS>
>> <SRS>EPSG:4164</SRS>
>> <SRS>EPSG:4165</SRS>
>> <SRS>EPSG:4166</SRS>
>> <SRS>EPSG:4167</SRS>
>> <SRS>EPSG:4168</SRS>
>> <SRS>EPSG:4169</SRS>
>> <SRS>EPSG:4170</SRS>
>> <SRS>EPSG:4171</SRS>
>> <SRS>EPSG:4172</SRS>
>> <SRS>EPSG:4173</SRS>
>> <SRS>EPSG:4174</SRS>
>> <SRS>EPSG:4175</SRS>
>> <SRS>EPSG:4176</SRS>
>> <SRS>EPSG:4178</SRS>
>> <SRS>EPSG:4179</SRS>
>> <SRS>EPSG:4180</SRS>
>> <SRS>EPSG:4181</SRS>
>> <SRS>EPSG:4182</SRS>
>> <SRS>EPSG:4183</SRS>
>> <SRS>EPSG:4184</SRS>
>> <SRS>EPSG:4185</SRS>
>> <SRS>EPSG:4188</SRS>
>> <SRS>EPSG:4189</SRS>
>> <SRS>EPSG:4190</SRS>
>> <SRS>EPSG:4191</SRS>
>> <SRS>EPSG:4192</SRS>
>> <SRS>EPSG:4193</SRS>
>> <SRS>EPSG:4194</SRS>
>> <SRS>EPSG:4195</SRS>
>> <SRS>EPSG:4196</SRS>
>> <SRS>EPSG:4197</SRS>
>> <SRS>EPSG:4198</SRS>
>> <SRS>EPSG:4199</SRS>
>> <SRS>EPSG:4200</SRS>
>> <SRS>EPSG:4201</SRS>
>> <SRS>EPSG:4202</SRS>
>> <SRS>EPSG:4203</SRS>
>> <SRS>EPSG:4204</SRS>
>> <SRS>EPSG:4205</SRS>
>> <SRS>EPSG:4206</SRS>
>> <SRS>EPSG:4207</SRS>
>> <SRS>EPSG:4208</SRS>
>> <SRS>EPSG:4209</SRS>
>> <SRS>EPSG:4210</SRS>
>> <SRS>EPSG:42101</SRS>
>> <SRS>EPSG:42102</SRS>
>> <SRS>EPSG:42103</SRS>
>> <SRS>EPSG:42104</SRS>
>> <SRS>EPSG:42105</SRS>
>> <SRS>EPSG:42106</SRS>
>> <SRS>EPSG:4211</SRS>
>> <SRS>EPSG:4212</SRS>
>> <SRS>EPSG:4213</SRS>
>> <SRS>EPSG:4214</SRS>
>> <SRS>EPSG:4215</SRS>
>> <SRS>EPSG:4216</SRS>
>> <SRS>EPSG:4218</SRS>
>> <SRS>EPSG:4219</SRS>
>> <SRS>EPSG:4220</SRS>
>> <SRS>EPSG:4221</SRS>
>> <SRS>EPSG:4222</SRS>
>> <SRS>EPSG:4223</SRS>
>> <SRS>EPSG:4224</SRS>
>> <SRS>EPSG:4225</SRS>
>> <SRS>EPSG:4226</SRS>
>> <SRS>EPSG:4227</SRS>
>> <SRS>EPSG:4228</SRS>
>> <SRS>EPSG:4229</SRS>
>> <SRS>EPSG:4230</SRS>
>> <SRS>EPSG:42301</SRS>
>> <SRS>EPSG:42302</SRS>
>> <SRS>EPSG:42303</SRS>
>> <SRS>EPSG:42304</SRS>
>> <SRS>EPSG:42305</SRS>
>> <SRS>EPSG:42306</SRS>
>> <SRS>EPSG:42307</SRS>
>> <SRS>EPSG:42308</SRS>
>> <SRS>EPSG:42309</SRS>
>> <SRS>EPSG:4231</SRS>
>> <SRS>EPSG:42310</SRS>
>> <SRS>EPSG:42311</SRS>
>> <SRS>EPSG:4232</SRS>
>> <SRS>EPSG:4233</SRS>
>> <SRS>EPSG:4234</SRS>
>> <SRS>EPSG:4235</SRS>
>> <SRS>EPSG:4236</SRS>
>> <SRS>EPSG:4237</SRS>
>> <SRS>EPSG:4238</SRS>
>> <SRS>EPSG:4239</SRS>
>> <SRS>EPSG:4240</SRS>
>> <SRS>EPSG:4241</SRS>
>> <SRS>EPSG:4242</SRS>
>> <SRS>EPSG:4243</SRS>
>> <SRS>EPSG:4244</SRS>
>> <SRS>EPSG:4245</SRS>
>> <SRS>EPSG:4246</SRS>
>> <SRS>EPSG:4247</SRS>
>> <SRS>EPSG:4248</SRS>
>> <SRS>EPSG:4249</SRS>
>> <SRS>EPSG:4250</SRS>
>> <SRS>EPSG:4251</SRS>
>> <SRS>EPSG:4252</SRS>
>> <SRS>EPSG:4253</SRS>
>> <SRS>EPSG:4254</SRS>
>> <SRS>EPSG:4255</SRS>
>> <SRS>EPSG:4256</SRS>
>> <SRS>EPSG:4257</SRS>
>> <SRS>EPSG:4258</SRS>
>> <SRS>EPSG:4259</SRS>
>> <SRS>EPSG:4260</SRS>
>> <SRS>EPSG:4261</SRS>
>> <SRS>EPSG:4262</SRS>
>> <SRS>EPSG:4263</SRS>
>> <SRS>EPSG:4264</SRS>
>> <SRS>EPSG:4265</SRS>
>> <SRS>EPSG:4266</SRS>
>> <SRS>EPSG:4267</SRS>
>> <SRS>EPSG:4268</SRS>
>> <SRS>EPSG:4269</SRS>
>> <SRS>EPSG:4270</SRS>
>> <SRS>EPSG:4271</SRS>
>> <SRS>EPSG:4272</SRS>
>> <SRS>EPSG:4273</SRS>
>> <SRS>EPSG:4274</SRS>
>> <SRS>EPSG:4275</SRS>
>> <SRS>EPSG:4276</SRS>
>> <SRS>EPSG:4277</SRS>
>> <SRS>EPSG:4278</SRS>
>> <SRS>EPSG:4279</SRS>
>> <SRS>EPSG:4280</SRS>
>> <SRS>EPSG:4281</SRS>
>> <SRS>EPSG:4282</SRS>
>> <SRS>EPSG:4283</SRS>
>> <SRS>EPSG:4284</SRS>
>> <SRS>EPSG:4285</SRS>
>> <SRS>EPSG:4286</SRS>
>> <SRS>EPSG:4287</SRS>
>> <SRS>EPSG:4288</SRS>
>> <SRS>EPSG:4289</SRS>
>> <SRS>EPSG:4291</SRS>
>> <SRS>EPSG:4292</SRS>
>> <SRS>EPSG:4293</SRS>
>> <SRS>EPSG:4294</SRS>
>> <SRS>EPSG:4295</SRS>
>> <SRS>EPSG:4296</SRS>
>> <SRS>EPSG:4297</SRS>
>> <SRS>EPSG:4298</SRS>
>> <SRS>EPSG:4299</SRS>
>> <SRS>EPSG:4300</SRS>
>> <SRS>EPSG:4301</SRS>
>> <SRS>EPSG:4302</SRS>
>> <SRS>EPSG:4303</SRS>
>> <SRS>EPSG:4304</SRS>
>> <SRS>EPSG:4306</SRS>
>> <SRS>EPSG:4307</SRS>
>> <SRS>EPSG:4308</SRS>
>> <SRS>EPSG:4309</SRS>
>> <SRS>EPSG:4310</SRS>
>> <SRS>EPSG:4311</SRS>
>> <SRS>EPSG:4312</SRS>
>> <SRS>EPSG:4313</SRS>
>> <SRS>EPSG:4314</SRS>
>> <SRS>EPSG:4315</SRS>
>> <SRS>EPSG:4316</SRS>
>> <SRS>EPSG:4317</SRS>
>> <SRS>EPSG:4318</SRS>
>> <SRS>EPSG:4319</SRS>
>> <SRS>EPSG:4322</SRS>
>> <SRS>EPSG:4324</SRS>
>> <SRS>EPSG:4326</SRS>
>> <SRS>EPSG:4600</SRS>
>> <SRS>EPSG:4601</SRS>
>> <SRS>EPSG:4602</SRS>
>> <SRS>EPSG:4603</SRS>
>> <SRS>EPSG:4604</SRS>
>> <SRS>EPSG:4605</SRS>
>> <SRS>EPSG:4606</SRS>
>> <SRS>EPSG:4607</SRS>
>> <SRS>EPSG:4608</SRS>
>> <SRS>EPSG:4609</SRS>
>> <SRS>EPSG:4610</SRS>
>> <SRS>EPSG:4611</SRS>
>> <SRS>EPSG:4612</SRS>
>> <SRS>EPSG:4613</SRS>
>> <SRS>EPSG:4614</SRS>
>> <SRS>EPSG:4615</SRS>
>> <SRS>EPSG:4616</SRS>
>> <SRS>EPSG:4617</SRS>
>> <SRS>EPSG:4618</SRS>
>> <SRS>EPSG:4619</SRS>
>> <SRS>EPSG:4620</SRS>
>> <SRS>EPSG:4621</SRS>
>> <SRS>EPSG:4622</SRS>
>> <SRS>EPSG:4623</SRS>
>> <SRS>EPSG:4624</SRS>
>> <SRS>EPSG:4625</SRS>
>> <SRS>EPSG:4626</SRS>
>> <SRS>EPSG:4627</SRS>
>> <SRS>EPSG:4628</SRS>
>> <SRS>EPSG:4629</SRS>
>> <SRS>EPSG:4630</SRS>
>> <SRS>EPSG:4631</SRS>
>> <SRS>EPSG:4632</SRS>
>> <SRS>EPSG:4633</SRS>
>> <SRS>EPSG:4634</SRS>
>> <SRS>EPSG:4635</SRS>
>> <SRS>EPSG:4636</SRS>
>> <SRS>EPSG:4637</SRS>
>> <SRS>EPSG:4638</SRS>
>> <SRS>EPSG:4639</SRS>
>> <SRS>EPSG:4640</SRS>
>> <SRS>EPSG:4641</SRS>
>> <SRS>EPSG:4642</SRS>
>> <SRS>EPSG:4643</SRS>
>> <SRS>EPSG:4644</SRS>
>> <SRS>EPSG:4645</SRS>
>> <SRS>EPSG:4646</SRS>
>> <SRS>EPSG:4657</SRS>
>> <SRS>EPSG:4658</SRS>
>> <SRS>EPSG:4659</SRS>
>> <SRS>EPSG:4660</SRS>
>> <SRS>EPSG:4661</SRS>
>> <SRS>EPSG:4662</SRS>
>> <SRS>EPSG:4663</SRS>
>> <SRS>EPSG:4664</SRS>
>> <SRS>EPSG:4665</SRS>
>> <SRS>EPSG:4666</SRS>
>> <SRS>EPSG:4667</SRS>
>> <SRS>EPSG:4668</SRS>
>> <SRS>EPSG:4669</SRS>
>> <SRS>EPSG:4670</SRS>
>> <SRS>EPSG:4671</SRS>
>> <SRS>EPSG:4801</SRS>
>> <SRS>EPSG:4802</SRS>
>> <SRS>EPSG:4803</SRS>
>> <SRS>EPSG:4804</SRS>
>> <SRS>EPSG:4805</SRS>
>> <SRS>EPSG:4806</SRS>
>> <SRS>EPSG:4807</SRS>
>> <SRS>EPSG:4808</SRS>
>> <SRS>EPSG:4809</SRS>
>> <SRS>EPSG:4810</SRS>
>> <SRS>EPSG:4811</SRS>
>> <SRS>EPSG:4813</SRS>
>> <SRS>EPSG:4814</SRS>
>> <SRS>EPSG:4815</SRS>
>> <SRS>EPSG:4816</SRS>
>> <SRS>EPSG:4817</SRS>
>> <SRS>EPSG:4818</SRS>
>> <SRS>EPSG:4819</SRS>
>> <SRS>EPSG:4820</SRS>
>> <SRS>EPSG:4821</SRS>
>> <SRS>EPSG:4901</SRS>
>> <SRS>EPSG:4902</SRS>
>> <SRS>EPSG:4903</SRS>
>> <SRS>EPSG:4904</SRS>
>> <LatLonBoundingBox minx="5.565041930901071"
>> miny="47.141817062783524" maxx="15.571502760545522"
>> maxy="55.05911195231699"/>
>> <Layer queryable="1">
>> <Name>daniel:bundeslaender</Name>
>> <Title>bundeslaender_Type</Title>
>> <Abstract>Generated from dan_shape01</Abstract>
>> <KeywordList>
>> <Keyword>bundeslaender dan_shape01</Keyword>
>> </KeywordList>
>> <!--WKT definition of this CRS:
>> PROJCS["DHDN / Gauss-Kruger zone 3",
>> GEOGCS["DHDN",
>> DATUM["Deutsches_Hauptdreiecksnetz",
>> SPHEROID["Bessel 1841", 6377397.155, 299.1528128,
>> AUTHORITY["EPSG","7004"]],
>> AUTHORITY["EPSG","6314"]],
>> PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
>> UNIT["degree", 0.017453292519943295],
>> AXIS["Lon", EAST],
>> AXIS["Lat", NORTH],
>> AUTHORITY["EPSG","4314"]],
>> PROJECTION["Transverse_Mercator"],
>> PARAMETER["central_meridian", 9.0],
>> PARAMETER["latitude_of_origin", 0.0],
>> PARAMETER["scale_factor", 1.0],
>> PARAMETER["false_easting", 3500000.0],
>> PARAMETER["false_northing", 0.0],
>> UNIT["m", 1.0],
>> AXIS["x", EAST],
>> AXIS["y", NORTH],
>> AUTHORITY["EPSG","31467"]]-->
>> <Style>
>> <Name>polygon</Name>
>> <Title>A boring default style</Title>
>> <Abstract>A sample style that just prints out a transparent
>> red interior with a red outline</Abstract>
>> <LegendURL width="20" height="20">
>> <Format>image/png</Format>
>> <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
>> xlink:type="simple"
>> xlink:href="http://localhost:8080/geoserver/wms/GetLegendGraphic?VERSION=1.0.0&FORMAT=image/png&WIDTH=20&HEIGHT=20&LAYER=daniel:bundeslaender"/>
>> </LegendURL>
>> </Style>
>> </Layer>
>> </Layer>
>> </Capability>
>> </WMT_MS_Capabilities>
Ulrich Rothstein
CCGIS GbR
Siemensstraße 8
53121 Bonn
GERMANY
uli.rothstein at ccgis.de
www.ccgis.de
www.mapbender.org
Zentrale: ++49 (0) 228 90826 0
Durchwahl: ++49 (0) 228 90826 17
Fax: ++49 (0) 228 90826 11
More information about the Mapbender_users
